DirectShow filters using Media SDK
farrell__douglas
I found this article with samples covering how to implement the Media SDK in a transcode filter.
https://software.intel.com/en-us/articles/media-transcoding-sample-using-microsoft-directshow
My question is why were the DShow filter samples removed/deprecated from the media samples or tutorial samples?  For my application, I'm stuck using DirectShow and those samples did almost exactly what we need.  YUV ==> H264 ==> mux with AAC audio ==> .MP4.
Is this still a valid solution for me, or would you suggest a different/better approach?
Doug
Windows 10 -- Intel(R) Media SDK 2018 R2 -- VS2015
Mark_L_Intel1
Hi Doug,
From the early years, Media SDK is focusing on hardware codec solution to video stream, so both audio and mux support were removed from the release.
I have other article to use FFMpeg to do the same thing if this can be a solution for you.
https://software.intel.com/en-us/articles/quick-start-on-integrating-ffmpeg-libraries ;
Hope this helps and sorry for the inconvenience and I would be appreciated if you could give me some feedback about our decision.
Mark
