A new white paper is available:
Displaying Stereoscopic 3D (S3D) with Intel HD Graphics
This document describes how to display S3D content and set standard and S3D modes of many 3D-capable monitors and TVs using a library that is available in the Intel Media SDK 3.0 (currently Beta 3).
Hi.. Yes. Displaying a still image is possible :)
Yes ... you have to use VideoProcessBlt(). That is how you chose Left or Right use pLEFTVideoProcessor->VideoProcessBlt() for left, and pRIGHTVideoProcessor->VideoProcessBlt() for right.
Each processor object will blit to their correct L or R surface (assuming you had set m_pS3DControl->SelectLeftView() when creating the L processor, and m_pS3DControl->SelecRightView() when creating the R processor.
You can think of it as pD3dDevice->GetBackBuffer() getting you a big super-surface (big enough to hold both Left and Right). The VideoProcessor object you use will make the Blt go to the correct place in that super-surface.
Right now, RightProcessor->VideoProcessBlt() the only way you change the bits that are seen by the right eye.
some questions:
0. you mention in whitepaper requeriment to link to dxva libs will be droped in the future?
1. are you working on a dx10 and dx11 (similar to amd quad buffer sdk) (for ivb or using dx_10 level device creation) similar api so it's usfeul for modern games?
2. some option for poor OGL users to expose OGL quad buffered rendering (would be awesome as Nvidia AMD require profesional cards)
3. Windows 8 developer preview supports standariced stereo rendering.. are you working to expose in some beta Windows 8 driver..
Hi there,
I'll try to answer some of your question: :)
I don't recall the whitepaper mentioning anything about what will be dropped or supported in the future.
I can't comment on future features or support. Sorry.
The paper, and MSDK S3D library are for Microsoft Windows 7 only.
As far as I understand it, since the primary usage via the SDK is video, the new S3D control API exposed via the library does not provide any specific features to control still image use case.
One way to display a still image, albeit a bit crude would be to just use the same method as in the S3D sample but feed the same left and right surface into the renderer repeatedly.
Another question: Does this library support all HDMI 1.4 3D formats? For example, I have a 3D monitor that takes Over/Under, Side-by-Side and Interlaced formats and claims to be HDMI 1.4 compatible (and it seems to be, in that 3D Blu-ray players work fine when connected to it). Will this library also work with this monitor (and negotiate one of those supportedformats "under the covers")?
I'm asking since my simple test app (that just draws a green rectangle to the left view and a red rectable to the right view) is only displaying the red rectangle (right view), even though the calls to SwitchTo3D is reporting success (as are all the other calls, made in the same order as the Media SDK example code).
Thanks!
-Don
Thank you very muchfor this information. I have verified that the device is being created after switching to 3D, and that the SelectView calls come afterwards. In walking through the sample_decode.cpp and RTF files, it appears that we are doing everything in the same order as the sample_decode project.
Of course, the next obvious step is for us to run the sample_decode project with our hardwareto see if that is working correctly with the 3D monitor and/or 3D TV we have available here for development & testing.
In order to accomplish that, we needed access to S3D video content in MVC format since that is the only format that sample_decode will render to a stereo device. Such media files seem hard to come by on the web (looking via a Google search). We mainly do CG and can easily construct separateleft & right video output files, so we used the sample_encode executable to create our own stereo MVC file from our own left/right views.
With that, it appears that the sample_decode executable works just like our app -- it returns success from all method calls yet it only displays the right view. So, most likely that means that we need to find other 3D display hardware. But note: we are using a late model LG 3D TV and it works fine with the various 3D Bluray players, and it claims to be HDMI 1.4a compatible, so perhaps further documentation for the IGFX3D_Control is necessary if if doesn't work with this type of 3D TV.
One possible weakness in our analysis: We created our own stereo 3D MVC file but really have no way to verify if we created it correctly. Could you perhaps point me to a place where I can download some sample/test stereo 3D MVC file(s)? With those in hand, we can rerun our sample_decode test and verify with certainty whether the IGFX3D_Control is working with our LG 3D TV or not.
Thanks again,
-Don
It turned out to be a case of needing to explicitly set the desktop size & refresh to 720p60 or 1080p24 before running the code. I'm still trying to figure out why the auto-setcode to choosean acceptable size & refresh isn't working, but that is a "minor" problem compared to actually having stereo 3d output working properly.
Thanks again for your support.
-Don
PS It works with both the LG Cinema 3D monitor and the LG 3D TV once the refresh rates are correctly set.
I'll take this opportunity to add my 2cents for an API method or extension to allow and app to directly write to the left/right portion of the bigger stereo backbuffer. For real time applications like ours, this saves two big framebuffer copies, since we could then just render to the left and rightportions of the backbuffer rather than to offscreen buffers followed by blits. (BTW, thisis how AMD's HD3D implementation works under the covers so we know from experience that it is more efficient for our type of application.)
Thanks again for your help!
-Don
It turns out that the GetS3DCaps method returns a list of supported 3D display modes that includes 1080p60hz. But this mode doesn't really support stereo 3D output!
Our program was finding that mode (as the closest -- well, exact -- match to our desktop settings) and hence was trying to use that, getting SUCCESS return codes, but not producing 3D output.
There is a comment on one of the RTF files in the SDK saying that 1080p24, 720p50, and 720p60 are the only valid/supported 3D modes (and I have confirmed that they work). But if that is the case, then the GetS3DCaps method should really only return those values.
-Don
