Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
Dynamic bitrate change issue
fei_y_
I failed to use MFXVideoENCODE.reset to change the bitrate dynamically. I flushed the frames in buffer and used GetVideoParam to retrieve the parameter. After change the TargetKbps and reset, it returned code 5 with leaving bitrate unchanged. I used CBR ratecontrol. Any suggestion?
fei_y_
I have turned off hrd compliance.
Anthony_P_Intel
If Reset returned 5 (MFX_WRN_INCOMPATIBLE_VIDEO_PARAM), then you can call GetVideoParam after the Reset call to see what parameter had to be changed.  If nothing at all changed, than the new TargetKbps is not a usable value for the other parameters set (maybe too high for the profile/level?)
