Hi, i need help in adding to sample_multi_transcode VPP 10bit (P010) conversion because working VPP feature on sample_decode is working but need too much space on disk and i preffer pay a developer to add this feature and dont upgrade server disks, can u help me?
In the latest driver version VPP (P010) conversion its working with hardware implementation, what i need is a conversion like sample_decode have, i think its possible right? If sample_decode Works i think sample_multi_transcode can be added
- Tags:
- Development Tools
- Graphics
- Intel® Media SDK
- Intel® Media Server Studio
- Media Processing
- Optimization
Hi Celio,
If you look at the following code, we might already have it. Could you confirm by running this code?
Basically, VPP itself should not care about 8 bits or 10 bits.
Mark
Yes i know for software hevc encoding but for hardware encoding it always return not supported when u add -ec::p010 to comand line
Hi Celio,
Could you give me your environment so I could try it?
Based on our latest code, we never report "no support" in our recent sample, see the following code:
It doesn't check for HW or SW either.
Mark
Here is my encoding command line
