Error Return of SyncOperation
James_C_5
Hi all,
I encounter a return error MFX_ERR_DEVICE_FAILED from SyncOperation during 264 long time encode.
There is also no bitstream output when error appears.
Below is the platform info.
Is this a known issue on this platform?
OS: Windows 7 Ultimate sp1 64bit
Motherboard : Intel DH61AG
BIOS version : ACRSYS - 28
Processor : Intel(R) Core(TM) i5-3470S CPU @ 2.90GHz
RAM : 6 GB
Graphic Driver version : 10.18.10.3945
James
Surbhi_M_Intel
Hi James,
We need little more more information about the test environment and the variables. For that, can you send us the following files to debug -
  • ​We need a reproducer, it would be best if you can reproduce this issue with our existing sample or tutorial.
  • Can you provide system analyzer and media SDK tracer logs? Details can be found here.
  • Which Media SDK or Media Server Studio release are you using?
Surbhi
James_C_5
Hi Surbhi,
Thank you for your reply. I will provide the information you mentioned.
James
hlevring
Hi James, did you ever find the cause of the problem ?
We also experiance the exact same issue.
-It does not happen on Laptops with Intel CPU but only on Desktops.
-It seems mostly reproducible on Intel HD 4600 where it can happen anytime between 30 min and several hours.
-I believe we are using Media SDK 2014 and absolutely latest Intel HD drivers.
Will try to get technical team to post more details.
Sravanthi_K_Intel
Hello there,
Can you please send more details on the issue you are observing? We should surely want to investigate this issue, and details as explained here https://software.intel.com/en-us/forums/topic/531083 can be really helpful.
Also, would you kindly start a new thread for this topic? We want to track these issues individually.
James_C_5
Hi hlevring,
I haven't found the cause of this issue.
It only happens on Intel® Desktop Board DH61AG in our experience.
It happens between 2x minutes and several hours every time.
James_C_5
Hi SRAVANTHI,
I will take a look at the page and send more details on this issue.
James
Vladimir_H_
Some more information.
1. We made QuickSync plugin implementation based on Intel sample code. Currently we made our own plugin with different architecture and have same issue still. I have laptop with Intel HD 4600 and build my own desktop with i7-4790K and Intel HD 4600. I can not reproduce this issue on both. But we have computers in development center where this issue can be reproduced and I tried to make everything possible to work around this issue. Also I seen some report in forum that someone can reproduce this issue on exactly same CPU - i7-4790K. So it seems not every computer have that issue.
2. This issue seems doesn't depend if QS uses D3D9 or D3D11.
3. We usually just run XSplit Broadcaster. make new presentation, run some benchmark. For example, Unigine Tropics. Capture it as game and stream/record with QuickSync. In about 30 minutes SyncOperation call returns -17 (MFX_ERR_DEVICE_FAILED). If you have DbgView running you will see corresponding logs and encoding restart.
You can find more information in following forum thread: https://support.xsplit.com/forum/viewtopic.php?f=92&t=27971
If you have some idea how I can work around this issue - this will be very helpful. Maybe encoder don't like something and it is good to avoid to do that. I will also ask our testers to follow up with computer specs that have this issue.
Geminiano_L_
I'm a colleague of the poster. I've attached the dxdiag report on our system configs. whereas we saw the issue to be prevalent in  Intel(R) Core(TM) i7-4770 and Intel(R) Core(TM) i7-3770K test beds even on the latest drivers. However, we haven't seen the issue to happen with the older Intel(R) Core(TM) i5-2500K.
Tommy_Y_
I also have the same problem.
Only happened when I connect the monitor to the NVidia card( GTX650), but when I connect to Intel HD 4600(Intel i5-4430), it's no problem.
MediaSDK version 6.0.0.349 (1.15).
Only one thread, MFX_IMPL_HARDWARE_ANY|MFX_IMPL_VIA_D3D11, each time MFXVideoENCODE_EncodeFrameAsync then wait MFXVideoCORE_SyncOperation INFINITE to get the result.
Once MFXVideoCORE_SyncOperation return MFX_ERR_DEVICE_FAILED, MFXVideoENCODE_EncodeFrameAsync always MFX_WRN_DEVICE_BUSY.
Please advice!
Vladimir_H_
It seems not all applications affected. Our testers tried some ffmpeg qsv encoder that works in same way like you mentioned (in single thread) and there no issues. And some other applications that we tested also works fine. In our new implementation we send frames to worker thread and worker thread calls MFXVideoENCODE_EncodeFrameAsync and MFXVideoCORE_SyncOperation without waiting. So we also call both functions in single thread but we have some more advanced logic.
Tommy_Y_
Hi Vladimir:
Thanks very much for the quick replay.
We here have 3 test pcs have the same problem (Need connect monitor to NVIDIA to reproduce), Two pcs are Win8.1 and one is Win10. All HD Graphics 4600.
Test file: 1280*720 50pfs 9min48s
pc Win 8.1:
i7-4700 (HD4600) NVIDIA GeForce GTX 750Ti, libmfxhw32.dll (File version 6.15.2.20, Product version6.0.1535.342)
Not always reproduced, have to try several times encoder the test file.
pc Win10:
i5-4430 (HD4600) NVIDIA GeForce GTX 650, libmfxhw32.dll (File version 6.15.6.25, Product version6.0.1540.399)
Reproduced every time, any source.
James_B_9
Just a thought, does everyone who is experiencing this problem also have a discrete Nvidia GPU installed on the same motherboard, with the default graphics adapter set to automatic? If so could it be an Nvidia Optimus issue?  Does the problem still persist if you force the Intel GPU to be the default adapter through the Nvidia control panel?
I am having the same problem with sync on decoding but it is really infrequently, so I am just restarting the decoder, I understand this is not really an option when encoding.
James.
Vladimir_H_
AFAIK this can be reproduced on laptops and desktops. But I personally can not reproduce it on my laptop. In our software I sure we run QS encoder in separate process that we force to run on Intel. But I will check and come back with updates if I mistake somewhere.
James_C_5
Hi SRAVANTHI,
This issue can reproduce with sample_encode of Intel Media Samples 6.0.0.68 + media_sdk_6.0.0.349 under Intel INDE 2015 Update 2.
It can reproduce with any input content.
Below is media sdk system analyzer log of my platform.
This platform is HM77 chipset.
Intel Media SDK System Analyzer (64 bit)
The following versions of Media SDK API are supported by platform/driver:
        Version Target  Supported       Dec     Enc
        1.0     HW      Yes             X       X
        1.0     SW      Yes             X       X
        1.1     HW      Yes             X       X
        1.1     SW      Yes             X       X
        1.3     HW      Yes             X       X
        1.3     SW      Yes             X       X
        1.4     HW      Yes             X       X
        1.4     SW      Yes             X       X
        1.5     HW      Yes             X       X
        1.5     SW      Yes             X       X
        1.6     HW      Yes             X       X
        1.6     SW      Yes             X       X
        1.7     HW      Yes             X       X
        1.7     SW      Yes             X       X
        1.8     HW      Yes             X       X
        1.8     SW      No
Graphics Devices:
        Name                                         Version             State
        Intel(R) HD Graphics 4000                    10.18.10.4226       Active
System info:
        CPU:    Intel(R) Core(TM) i5-3427U CPU @ 1.80GHz
        OS:     Microsoft Windows 7 Ultimate
        Arch:   64-bit
Installed Media SDK packages (be patient...processing takes some time):
        Intel?INDE Media SDK for Windows 6.0.0.349
Installed Media SDK DirectShow filters:
Installed Intel Media Foundation Transforms:
  Intel?Hardware M-JPEG Decoder MFT : {00C69F81-0524-48C0-A353-4DD9D54F9A6E}
  Intel?Hardware VC-1 Decoder MFT : {059A5BAE-5D7A-4C5E-8F7A-BFD57D1D6AAA}
  Intel?Hardware H.264 Decoder MFT : {45E5CE07-5AC7-4509-94E9-62DB27CF8F96}
  Intel?Hardware MPEG-2 Decoder MFT : {CD5BA7FF-9071-40E9-A462-8DC5152B1776}
  Intel?Quick Sync Video H.264 Encoder MFT : {4BE8D3C0-0515-4A37-AD55-E4BAE19AF
471}
  Intel?Hardware Preprocessing MFT : {EE69B504-1CBF-4EA6-8137-BB10F806B014}
Analysis complete... [press ENTER]
This issue appears on only H61, HM77 and HM76 chipset in our experiences.
It seems to be reproduced easily on Mini-ITX and laptop board.
Since there is no tracer.log output from tracer.exe of media_sdk_6.0.0.349, I can't attach tracer.log.
This tracer problem could be an issue as below link.
https://software.intel.com/en-us/forums/topic/564373
I am trying to get tracer log with media sdk of old version. So I don't create a new thread for this issue.
James
Geminiano_L_
Since this forum is talking about chipsets, I just want to add specify the test machines that are affected.
TM1 is on MSI Z87-GD65 GAMING (MS-7845) with Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz (8 CPUs), ~3.4GHz (Intel HD 4600)
TM2 is on MSI Z87M Express Chipset GAMING with Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz (8 CPUs), ~3.5GHz (Intel HD 4600)
TM3 is on MSI Z77A-G45 Chipset with Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz (8 CPUs), ~3.5GHz (Intel HD 4000)
James_C_5
Hi SRAVANTHI,
Here is a tracer log about this issue reproduced by other platform.
Processor Type:
Intel(R) Core(TM) i7-3632QM CPU @ 2.20GHz
Driver Version:
10.18.10.3345
Operating System:
Microsoft Windows 7 Ultimate 64-bit
Media SDK System Analyzer:
        1.0     HW      Yes             X       X
        1.0     SW      Yes             X       X
        1.1     HW      Yes             X       X
        1.1     SW      Yes             X       X
        1.3     HW      Yes             X       X
        1.3     SW      Yes             X       X
        1.4     HW      Yes             X       X
        1.4     SW      Yes             X       X
        1.5     HW      Yes             X       X
        1.5     SW      Yes             X       X
        1.6     HW      Yes             X       X
        1.6     SW      Yes             X       X
        1.7     HW      Yes             X       X
        1.7     SW      Yes             X       X
        1.8     HW      Yes             X       X
        1.8     SW      Yes             X       X
Graphics Devices:
        Name                                         Version             State
        Intel(R) HD Graphics 4000                    10.18.10.3345       Active
System info:
        CPU:    Intel(R) Core(TM) i7-3632QM CPU @ 2.20GHz
        Arch:   64-bit
        Intel?INDE Media SDK for Windows 6.0.0.308
471}
Quick Reproducer Code:
Concise Description of the Issue:
Return error MFX_ERR_DEVICE_FAILED from SyncOperation when 264 long time encode.
Priority:
High
Input File:
Any 1920 x 1080 content
Tracer log(if required):
(null)
=====05:53:23 08/21/15====
SDK_ANALYZER loaded at: C:\Intel\INDE\media_sdk_6.0.0.308\tools\mediasdk_tracer\tracer_core32.dll
PROCESS: sample_encode  h264 -i test1.yuv -o output.h264 -w 1920 -h 1080 -b 10000 -f 30 -u speed -hw
Acquiring named mutex mediasdk_tracer_lock : GetLastError()= Cannot create a file when that file already exists.
INFO :MFXInit (impl=MFX_IMPL_HARDWARE|MFX_IMPL_VIA_D3D9, pVer=1.1 session=0x004A0FA8
INFO :Required API version is 1.1
INFO :Inspecting HKEY_CURRENT_USER\Software\Intel\MediaSDK\Dispatch
INFO :found subkey: tracer32_hw0_v1.1
INFO :opened key: tracer32_hw0_v1.1
INFO :loaded VendorID : 0x8086
INFO :loaded DeviceID : 0x166
INFO :loaded Merit : 1
INFO :loaded Path : C:\Intel\INDE\media_sdk_6.0.0.308\tools\mediasdk_tracer\tracer_core32.dll
INFO :Library type is MFX_LIB_HARDWARE
INFO :found subkey: tracer32_hw0_v1.10
INFO :opened key: tracer32_hw0_v1.10
INFO :merit conflict: lastMerit = 0x7fffffff, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 1
INFO :found subkey: tracer32_hw0_v1.11
INFO :opened key: tracer32_hw0_v1.11
INFO :merit conflict: lastMerit = 0x7fffffff, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 2
INFO :found subkey: tracer32_hw0_v1.2
INFO :opened key: tracer32_hw0_v1.2
INFO :merit conflict: lastMerit = 0x7fffffff, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 3
INFO :found subkey: tracer32_hw0_v1.3
INFO :opened key: tracer32_hw0_v1.3
INFO :merit conflict: lastMerit = 0x7fffffff, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 4
INFO :found subkey: tracer32_hw0_v1.4
INFO :opened key: tracer32_hw0_v1.4
INFO :merit conflict: lastMerit = 0x7fffffff, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 5
INFO :found subkey: tracer32_hw0_v1.6
INFO :opened key: tracer32_hw0_v1.6
INFO :merit conflict: lastMerit = 0x7fffffff, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 6
INFO :found subkey: tracer32_hw0_v1.7
INFO :opened key: tracer32_hw0_v1.7
INFO :merit conflict: lastMerit = 0x7fffffff, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 7
INFO :found subkey: tracer32_hw0_v1.8
INFO :opened key: tracer32_hw0_v1.8
INFO :merit conflict: lastMerit = 0x7fffffff, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 8
INFO :found subkey: tracer32_hw0_v1.9
INFO :opened key: tracer32_hw0_v1.9
INFO :merit conflict: lastMerit = 0x7fffffff, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 9
INFO :found subkey: tracer32_hw1_v1.1
INFO :opened key: tracer32_hw1_v1.1
INFO :loaded VendorID : 0x0
INFO :loaded DeviceID : 0x0
INFO :VendorID conflict, actual = 0x8086 : required = 0x0
INFO :found subkey: tracer32_hw1_v1.10
INFO :opened key: tracer32_hw1_v1.10
INFO :found subkey: tracer32_hw1_v1.11
INFO :opened key: tracer32_hw1_v1.11
INFO :found subkey: tracer32_hw1_v1.2
INFO :opened key: tracer32_hw1_v1.2
INFO :found subkey: tracer32_hw1_v1.3
INFO :opened key: tracer32_hw1_v1.3
INFO :found subkey: tracer32_hw1_v1.4
INFO :opened key: tracer32_hw1_v1.4
INFO :found subkey: tracer32_hw1_v1.6
INFO :opened key: tracer32_hw1_v1.6
INFO :found subkey: tracer32_hw1_v1.7
INFO :opened key: tracer32_hw1_v1.7
INFO :found subkey: tracer32_hw1_v1.8
INFO :opened key: tracer32_hw1_v1.8
INFO :found subkey: tracer32_hw1_v1.9
INFO :opened key: tracer32_hw1_v1.9
INFO :found subkey: tracer64_hw0_v1.1
INFO :opened key: tracer64_hw0_v1.1
INFO :merit conflict: lastMerit = 0x7fffffff, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 20
INFO :found subkey: tracer64_hw0_v1.10
INFO :opened key: tracer64_hw0_v1.10
INFO :merit conflict: lastMerit = 0x7fffffff, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 21
INFO :found subkey: tracer64_hw0_v1.11
INFO :opened key: tracer64_hw0_v1.11
INFO :merit conflict: lastMerit = 0x7fffffff, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 22
INFO :found subkey: tracer64_hw0_v1.2
INFO :opened key: tracer64_hw0_v1.2
INFO :merit conflict: lastMerit = 0x7fffffff, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 23
INFO :found subkey: tracer64_hw0_v1.3
INFO :opened key: tracer64_hw0_v1.3
INFO :merit conflict: lastMerit = 0x7fffffff, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 24
INFO :found subkey: tracer64_hw0_v1.4
INFO :opened key: tracer64_hw0_v1.4
INFO :merit conflict: lastMerit = 0x7fffffff, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 25
INFO :found subkey: tracer64_hw0_v1.6
INFO :opened key: tracer64_hw0_v1.6
INFO :merit conflict: lastMerit = 0x7fffffff, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 26
INFO :found subkey: tracer64_hw0_v1.7
INFO :opened key: tracer64_hw0_v1.7
INFO :merit conflict: lastMerit = 0x7fffffff, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 27
INFO :found subkey: tracer64_hw0_v1.8
INFO :opened key: tracer64_hw0_v1.8
INFO :merit conflict: lastMerit = 0x7fffffff, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 28
INFO :found subkey: tracer64_hw0_v1.9
INFO :opened key: tracer64_hw0_v1.9
INFO :merit conflict: lastMerit = 0x7fffffff, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 29
INFO :found subkey: tracer64_hw1_v1.1
INFO :opened key: tracer64_hw1_v1.1
INFO :found subkey: tracer64_hw1_v1.10
INFO :opened key: tracer64_hw1_v1.10
INFO :found subkey: tracer64_hw1_v1.11
INFO :opened key: tracer64_hw1_v1.11
INFO :found subkey: tracer64_hw1_v1.2
INFO :opened key: tracer64_hw1_v1.2
INFO :found subkey: tracer64_hw1_v1.3
INFO :opened key: tracer64_hw1_v1.3
INFO :found subkey: tracer64_hw1_v1.4
INFO :opened key: tracer64_hw1_v1.4
INFO :found subkey: tracer64_hw1_v1.6
INFO :opened key: tracer64_hw1_v1.6
INFO :found subkey: tracer64_hw1_v1.7
INFO :opened key: tracer64_hw1_v1.7
INFO :found subkey: tracer64_hw1_v1.8
INFO :opened key: tracer64_hw1_v1.8
INFO :found subkey: tracer64_hw1_v1.9
INFO :opened key: tracer64_hw1_v1.9
INFO :[WINREG]: EnumKey with index=40: RegEnumKeyExW()==0x103
INFO :no more subkeys : RegEnumKeyExA()==0x0
INFO :loading library C:\Intel\INDE\media_sdk_6.0.0.308\tools\mediasdk_tracer\tracer_core32.dll
INFO :invoking LoadLibrary(C:\Intel\INDE\media_sdk_6.0.0.308\tools\mediasdk_tracer\tracer_core32.dll)
INFO :loaded module C:\Intel\INDE\media_sdk_6.0.0.308\tools\mediasdk_tracer\tracer_core32.dll
INFO :MFXInit(MFX_IMPL_HARDWARE|MFX_IMPL_VIA_D3D9,ver=1.1,session=0x0049D368)
INFO :library can't be load. MFXInit returned MFX_ERR_UNSUPPORTED
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 0, index = 0
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 2
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 3
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 4
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 5
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 6
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 7
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 8
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 9
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 20
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 21
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 22
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 23
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 24
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 25
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 26
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 27
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 28
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 0, index = 29
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 1, index = 0
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 1, index = 1
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 1, index = 3
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 1, index = 4
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 1, index = 5
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 1, index = 6
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 1, index = 7
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 1, index = 8
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 1, index = 9
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 1, index = 20
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 1, index = 21
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 1, index = 22
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 1, index = 23
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 1, index = 24
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 1, index = 25
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 1, index = 26
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 1, index = 27
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 1, index = 28
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 1, index = 29
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 2, index = 0
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 2, index = 1
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 2, index = 2
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 2, index = 4
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 2, index = 5
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 2, index = 6
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 2, index = 7
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 2, index = 8
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 2, index = 9
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 2, index = 20
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 2, index = 21
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 2, index = 22
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 2, index = 23
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 2, index = 24
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 2, index = 25
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 2, index = 26
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 2, index = 27
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 2, index = 28
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 2, index = 29
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 3, index = 0
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 3, index = 1
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 3, index = 2
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 3, index = 3
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 3, index = 5
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 3, index = 6
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 3, index = 7
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 3, index = 8
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 3, index = 9
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 3, index = 20
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 3, index = 21
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 3, index = 22
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 3, index = 23
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 3, index = 24
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 3, index = 25
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 3, index = 26
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 3, index = 27
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 3, index = 28
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 3, index = 29
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 4, index = 0
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 4, index = 1
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 4, index = 2
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 4, index = 3
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 4, index = 4
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 4, index = 6
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 4, index = 7
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 4, index = 8
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 4, index = 9
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 4, index = 20
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 4, index = 21
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 4, index = 22
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 4, index = 23
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 4, index = 24
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 4, index = 25
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 4, index = 26
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 4, index = 27
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 4, index = 28
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 4, index = 29
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 5, index = 0
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 5, index = 1
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 5, index = 2
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 5, index = 3
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 5, index = 4
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 5, index = 5
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 5, index = 7
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 5, index = 8
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 5, index = 9
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 5, index = 20
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 5, index = 21
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 5, index = 22
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 5, index = 23
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 5, index = 24
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 5, index = 25
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 5, index = 26
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 5, index = 27
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 5, index = 28
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 5, index = 29
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 6, index = 0
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 6, index = 1
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 6, index = 2
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 6, index = 3
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 6, index = 4
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 6, index = 5
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 6, index = 6
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 6, index = 8
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 6, index = 9
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 6, index = 20
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 6, index = 21
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 6, index = 22
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 6, index = 23
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 6, index = 24
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 6, index = 25
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 6, index = 26
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 6, index = 27
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 6, index = 28
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 6, index = 29
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 7, index = 0
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 7, index = 1
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 7, index = 2
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 7, index = 3
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 7, index = 4
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 7, index = 5
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 7, index = 6
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 7, index = 7
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 7, index = 9
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 7, index = 20
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 7, index = 21
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 7, index = 22
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 7, index = 23
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 7, index = 24
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 7, index = 25
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 7, index = 26
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 7, index = 27
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 7, index = 28
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 7, index = 29
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 8, index = 0
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 8, index = 1
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 8, index = 2
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 8, index = 3
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 8, index = 4
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 8, index = 5
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 8, index = 6
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 8, index = 7
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 8, index = 8
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 8, index = 20
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 8, index = 21
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 8, index = 22
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 8, index = 23
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 8, index = 24
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 8, index = 25
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 8, index = 26
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 8, index = 27
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 8, index = 28
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 8, index = 29
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 9, index = 0
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 9, index = 1
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 9, index = 2
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 9, index = 3
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 9, index = 4
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 9, index = 5
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 9, index = 6
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 9, index = 7
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 9, index = 8
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 9, index = 9
INFO :loaded Path : C:\Intel\INDE\media_sdk_6.0.0.308\tools\mediasdk_tracer\tracer_core64.dll
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 9, index = 21
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 9, index = 22
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 9, index = 23
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 9, index = 24
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 9, index = 25
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 9, index = 26
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 9, index = 27
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 9, index = 28
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 9, index = 29
INFO :loading library C:\Intel\INDE\media_sdk_6.0.0.308\tools\mediasdk_tracer\tracer_core64.dll
INFO :invoking LoadLibrary(C:\Intel\INDE\media_sdk_6.0.0.308\tools\mediasdk_tracer\tracer_core64.dll)
INFO :can't find DLL: GetLastErr()=0xc1
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 20, index = 0
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 20, index = 1
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 20, index = 2
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 20, index = 3
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 20, index = 4
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 20, index = 5
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 20, index = 6
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 20, index = 7
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 20, index = 8
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 20, index = 9
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 20, index = 20
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 20, index = 22
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 20, index = 23
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 20, index = 24
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 20, index = 25
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 20, index = 26
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 20, index = 27
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 20, index = 28
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 20, index = 29
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 21, index = 0
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 21, index = 1
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 21, index = 2
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 21, index = 3
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 21, index = 4
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 21, index = 5
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 21, index = 6
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 21, index = 7
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 21, index = 8
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 21, index = 9
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 21, index = 20
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 21, index = 21
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 21, index = 23
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 21, index = 24
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 21, index = 25
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 21, index = 26
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 21, index = 27
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 21, index = 28
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 21, index = 29
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 22, index = 0
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 22, index = 1
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 22, index = 2
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 22, index = 3
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 22, index = 4
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 22, index = 5
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 22, index = 6
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 22, index = 7
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 22, index = 8
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 22, index = 9
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 22, index = 20
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 22, index = 21
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 22, index = 22
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 22, index = 24
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 22, index = 25
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 22, index = 26
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 22, index = 27
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 22, index = 28
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 22, index = 29
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 23, index = 0
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 23, index = 1
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 23, index = 2
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 23, index = 3
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 23, index = 4
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 23, index = 5
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 23, index = 6
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 23, index = 7
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 23, index = 8
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 23, index = 9
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 23, index = 20
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 23, index = 21
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 23, index = 22
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 23, index = 23
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 23, index = 25
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 23, index = 26
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 23, index = 27
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 23, index = 28
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 23, index = 29
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 24, index = 0
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 24, index = 1
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 24, index = 2
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 24, index = 3
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 24, index = 4
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 24, index = 5
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 24, index = 6
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 24, index = 7
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 24, index = 8
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 24, index = 9
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 24, index = 20
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 24, index = 21
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 24, index = 22
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 24, index = 23
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 24, index = 24
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 24, index = 26
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 24, index = 27
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 24, index = 28
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 24, index = 29
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 25, index = 0
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 25, index = 1
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 25, index = 2
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 25, index = 3
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 25, index = 4
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 25, index = 5
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 25, index = 6
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 25, index = 7
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 25, index = 8
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 25, index = 9
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 25, index = 20
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 25, index = 21
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 25, index = 22
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 25, index = 23
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 25, index = 24
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 25, index = 25
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 25, index = 27
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 25, index = 28
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 25, index = 29
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 26, index = 0
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 26, index = 1
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 26, index = 2
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 26, index = 3
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 26, index = 4
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 26, index = 5
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 26, index = 6
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 26, index = 7
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 26, index = 8
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 26, index = 9
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 26, index = 20
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 26, index = 21
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 26, index = 22
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 26, index = 23
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 26, index = 24
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 26, index = 25
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 26, index = 26
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 26, index = 28
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 26, index = 29
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 27, index = 0
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 27, index = 1
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 27, index = 2
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 27, index = 3
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 27, index = 4
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 27, index = 5
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 27, index = 6
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 27, index = 7
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 27, index = 8
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 27, index = 9
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 27, index = 20
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 27, index = 21
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 27, index = 22
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 27, index = 23
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 27, index = 24
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 27, index = 25
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 27, index = 26
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 27, index = 27
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x1, lastindex = 27, index = 29
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 28, index = 0
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 28, index = 1
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 28, index = 2
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 28, index = 3
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 28, index = 4
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 28, index = 5
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 28, index = 6
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 28, index = 7
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 28, index = 8
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 28, index = 9
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 28, index = 20
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 28, index = 21
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 28, index = 22
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 28, index = 23
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 28, index = 24
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 28, index = 25
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 28, index = 26
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 28, index = 27
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 28, index = 28
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 29, index = 0
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 29, index = 1
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 29, index = 2
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 29, index = 3
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 29, index = 4
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 29, index = 5
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 29, index = 6
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 29, index = 7
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 29, index = 8
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 29, index = 9
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 29, index = 20
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 29, index = 21
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 29, index = 22
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 29, index = 23
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 29, index = 24
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 29, index = 25
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 29, index = 26
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 29, index = 27
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 29, index = 28
INFO :merit conflict: lastMerit = 0x1, requiredMerit = 0x1, libraryMerit = 0x0, lastindex = 29, index = 29
INFO :Inspecting HKEY_LOCAL_MACHINE\Software\Intel\MediaSDK\Dispatch
INFO :found subkey: iHSW_0402
INFO :opened key: iHSW_0402
INFO :loaded DeviceID : 0x402
INFO :loaded Merit : 134217748
INFO :DeviceID conflict, actual = 0x166 : required = 0x402
INFO :found subkey: iHSW_0406
INFO :opened key: iHSW_0406
INFO :loaded DeviceID : 0x406
INFO :DeviceID conflict, actual = 0x166 : required = 0x406
INFO :found subkey: iHSW_040A
INFO :opened key: iHSW_040A
INFO :loaded DeviceID : 0x40a
INFO :DeviceID conflict, actual = 0x166 : required = 0x40a
INFO :found subkey: iHSW_0412
INFO :opened key: iHSW_0412
INFO :loaded DeviceID : 0x412
INFO :DeviceID conflict, actual = 0x166 : required = 0x412
INFO :found subkey: iHSW_0416
INFO :opened key: iHSW_0416
INFO :loaded DeviceID : 0x416
INFO :DeviceID conflict, actual = 0x166 : required = 0x416
INFO :found subkey: iHSW_041A
INFO :opened key: iHSW_041A
INFO :loaded DeviceID : 0x41a
INFO :DeviceID conflict, actual = 0x166 : required = 0x41a
INFO :found subkey: iHSW_041E
INFO :opened key: iHSW_041E
INFO :loaded DeviceID : 0x41e
INFO :DeviceID conflict, actual = 0x166 : required = 0x41e
INFO :found subkey: iHSW_0A06
INFO :opened key: iHSW_0A06
INFO :loaded DeviceID : 0xa06
INFO :DeviceID conflict, actual = 0x166 : required = 0xa06
INFO :found subkey: iHSW_0A0E
INFO :opened key: iHSW_0A0E
INFO :loaded DeviceID : 0xa0e
INFO :DeviceID conflict, actual = 0x166 : required = 0xa0e
INFO :found subkey: iHSW_0A16
INFO :opened key: iHSW_0A16
INFO :loaded DeviceID : 0xa16
INFO :DeviceID conflict, actual = 0x166 : required = 0xa16
INFO :found subkey: iHSW_0A1E
INFO :opened key: iHSW_0A1E
INFO :loaded DeviceID : 0xa1e
INFO :DeviceID conflict, actual = 0x166 : required = 0xa1e
INFO :found subkey: iHSW_0A26
INFO :opened key: iHSW_0A26
INFO :loaded DeviceID : 0xa26
INFO :DeviceID conflict, actual = 0x166 : required = 0xa26
INFO :found subkey: iHSW_0A2E
INFO :opened key: iHSW_0A2E
INFO :loaded DeviceID : 0xa2e
INFO :DeviceID conflict, actual = 0x166 : required = 0xa2e
INFO :found subkey: iHSW_0D22
INFO :opened key: iHSW_0D22
INFO :loaded DeviceID : 0xd22
INFO :DeviceID conflict, actual = 0x166 : required = 0xd22
INFO :found subkey: iHSW_0D26
INFO :opened key: iHSW_0D26
INFO :loaded DeviceID : 0xd26
INFO :DeviceID conflict, actual = 0x166 : required = 0xd26
INFO :found subkey: iIVB_0152
INFO :opened key: iIVB_0152
INFO :loaded DeviceID : 0x152
INFO :DeviceID conflict, actual = 0x166 : required = 0x152
INFO :found subkey: iIVB_0156
INFO :opened key: iIVB_0156
INFO :loaded DeviceID : 0x156
INFO :DeviceID conflict, actual = 0x166 : required = 0x156
INFO :found subkey: iIVB_0162
INFO :opened key: iIVB_0162
INFO :loaded DeviceID : 0x162
INFO :DeviceID conflict, actual = 0x166 : required = 0x162
INFO :found subkey: iIVB_0166
INFO :opened key: iIVB_0166
INFO :loaded Path : C:\Program Files\Intel\Media SDK\libmfxhw32.dll
INFO :found subkey: iIVB_016A
INFO :opened key: iIVB_016A
INFO :loaded DeviceID : 0x16a
INFO :DeviceID conflict, actual = 0x166 : required = 0x16a
INFO :[WINREG]: EnumKey with index=20: RegEnumKeyExW()==0x103
INFO :loading library C:\Program Files\Intel\Media SDK\libmfxhw32.dll
INFO :invoking LoadLibrary(C:\Program Files\Intel\Media SDK\libmfxhw32.dll)
INFO :loaded module C:\Program Files\Intel\Media SDK\libmfxhw32.dll
INFO :Can't find API function "MFXVideoENC_Query"
INFO :Can't find API function "MFXVideoENC_QueryIOSurf"
INFO :Can't find API function "MFXVideoENC_Init"
INFO :Can't find API function "MFXVideoENC_Reset"
INFO :Can't find API function "MFXVideoENC_Close"
INFO :Can't find API function "MFXVideoENC_ProcessFrameAsync"
INFO :Can't find API function "MFXVideoVPP_RunFrameVPPAsyncEx"
MFXQueryVersion.ver=1.7
INFO :MFXQueryVersion returned API: 1.7
INFO :library loaded succesfully
INFO :loading library C:\Users\zonkey\Documents\Intel Media Samples 6.0.0.98947\_build\Win32\Release\libmfxsw32.dll
INFO :invoking LoadLibrary(C:\Users\zonkey\Documents\Intel Media Samples 6.0.0.98947\_build\Win32\Release\libmfxsw32.dll)
INFO :can't find DLL: GetLastErr()=0x7e
INFO :loading default library libmfxhw32.dll
INFO :invoking LoadLibrary(libmfxhw32.dll)
INFO :MFXInit(MFX_IMPL_HARDWARE|MFX_IMPL_VIA_D3D9,ver=1.1,session=0x004A4BF8)
INFO :[WINREG]: Opening key "UNSUPPORTED_KEY\Plugin" : RegOpenKeyExW()==0x2
INFO :[WINREG]: Opening key "HKEY_CURRENT_USER\Software\Intel\MediaSDK\Plugin" : RegOpenKeyExW()==0x2
INFO :[WINREG]: Opening key "HKEY_LOCAL_MACHINE\Software\Intel\MediaSDK\Plugin" : RegOpenKeyExW()==0x2
INFO :MFXClose(0x0) returned 0
SDK DLL File Version=4.13.10.3
SDK DLL Product Version=4.0.1533427.69359
SDK DLL File Size=17164944
MFXInit.impl=HARDWARE|VIA_D3D9
MFXInit.ver=1.1
MFXInit.status=MFX_ERR_NONE
encode.Close.status=MFX_ERR_NOT_INITIALIZED
encode.QueryIOSurf.par.AsyncDepth=4
encode.QueryIOSurf.par.mfx.BRCParamMultiplier=0
encode.QueryIOSurf.par.mfx.FrameInfo.BitDepthLuma=(0)
encode.QueryIOSurf.par.mfx.FrameInfo.BitDepthChroma=(0)
encode.QueryIOSurf.par.mfx.FrameInfo.Shift=(0)
encode.QueryIOSurf.par.mfx.FrameInfo.FourCC=NV12
encode.QueryIOSurf.par.mfx.FrameInfo.Resolution=(1920,1088)
encode.QueryIOSurf.par.mfx.FrameInfo.Crop=(0,0,1920,1080)
encode.QueryIOSurf.par.mfx.FrameInfo.FrameRate=30/1
encode.QueryIOSurf.par.mfx.FrameInfo.AspectRatio=0:0
encode.QueryIOSurf.par.mfx.FrameInfo.PicStruct=PROGRESSIVE
encode.QueryIOSurf.par.mfx.FrameInfo.ChromaFormat=4:2:0
encode.QueryIOSurf.par.mfx.CodecId=AVC
encode.QueryIOSurf.par.mfx.CodecProfile=0
encode.QueryIOSurf.par.mfx.CodecLevel=0
encode.QueryIOSurf.par.mfx.NumThread=0
encode.QueryIOSurf.par.mfx.TargetUsage=7
encode.QueryIOSurf.par.mfx.GopPicSize=0
encode.QueryIOSurf.par.mfx.GopRefDist=0
encode.QueryIOSurf.par.mfx.GopOptFlag=0
encode.QueryIOSurf.par.mfx.IdrInterval=0
encode.QueryIOSurf.par.mfx.RateControlMethod=CBR
encode.QueryIOSurf.par.mfx.InitialDelayInKB=0
encode.QueryIOSurf.par.mfx.TargetKbps=10000
encode.QueryIOSurf.par.mfx.MaxKbps=0
encode.QueryIOSurf.par.mfx.BufferSizeInKB=0
encode.QueryIOSurf.par.mfx.NumSlice=0
encode.QueryIOSurf.par.mfx.NumRefFrame=0
encode.QueryIOSurf.par.mfx.EncodedOrder=0
encode.QueryIOSurf.par.Protected=0
encode.QueryIOSurf.par.IOPattern=IN_SYSTEM_MEMORY
encode.QueryIOSurf.par.NumExtParam=0
encode.QueryIOSurf.par.ExtParam=NULL
encode.QueryIOSurf.request.Info.BitDepthLuma=(0)
encode.QueryIOSurf.request.Info.BitDepthChroma=(0)
encode.QueryIOSurf.request.Info.Shift=(0)
encode.QueryIOSurf.request.Info.FourCC=NV12
encode.QueryIOSurf.request.Info.Resolution=(1920,1088)
encode.QueryIOSurf.request.Info.Crop=(0,0,1920,1080)
encode.QueryIOSurf.request.Info.FrameRate=30/1
encode.QueryIOSurf.request.Info.AspectRatio=1:1
encode.QueryIOSurf.request.Info.PicStruct=PROGRESSIVE
encode.QueryIOSurf.request.Info.ChromaFormat=4:2:0
encode.QueryIOSurf.request.Type=SYSTEM_MEMORY|FROM_ENCODE|EXTERNAL_FRAME
encode.QueryIOSurf.request.NumFrameMin=6
encode.QueryIOSurf.request.NumFrameSuggested=6
encode.QueryIOSurf.status=MFX_ERR_NONE
encode.Init.par.AsyncDepth=4
encode.Init.par.mfx.BRCParamMultiplier=0
encode.Init.par.mfx.FrameInfo.BitDepthLuma=(0)
encode.Init.par.mfx.FrameInfo.BitDepthChroma=(0)
encode.Init.par.mfx.FrameInfo.Shift=(0)
encode.Init.par.mfx.FrameInfo.FourCC=NV12
encode.Init.par.mfx.FrameInfo.Resolution=(1920,1088)
encode.Init.par.mfx.FrameInfo.Crop=(0,0,1920,1080)
encode.Init.par.mfx.FrameInfo.FrameRate=30/1
encode.Init.par.mfx.FrameInfo.AspectRatio=0:0
encode.Init.par.mfx.FrameInfo.PicStruct=PROGRESSIVE
encode.Init.par.mfx.FrameInfo.ChromaFormat=4:2:0
encode.Init.par.mfx.CodecId=AVC
encode.Init.par.mfx.CodecProfile=0
encode.Init.par.mfx.CodecLevel=0
encode.Init.par.mfx.NumThread=0
encode.Init.par.mfx.TargetUsage=7
encode.Init.par.mfx.GopPicSize=0
encode.Init.par.mfx.GopRefDist=0
encode.Init.par.mfx.GopOptFlag=0
encode.Init.par.mfx.IdrInterval=0
encode.Init.par.mfx.RateControlMethod=CBR
encode.Init.par.mfx.InitialDelayInKB=0
encode.Init.par.mfx.TargetKbps=10000
encode.Init.par.mfx.MaxKbps=0
encode.Init.par.mfx.BufferSizeInKB=0
encode.Init.par.mfx.NumSlice=0
encode.Init.par.mfx.NumRefFrame=0
encode.Init.par.mfx.EncodedOrder=0
encode.Init.par.Protected=0
encode.Init.par.IOPattern=IN_SYSTEM_MEMORY
encode.Init.par.NumExtParam=0
encode.Init.par.ExtParam=NULL
encode.Init.status=MFX_ERR_NONE
MFXQueryIMPL.impl=HARDWARE|VIA_D3D9
encode.Close.status=MFX_ERR_NONE
encode.perf.frames=2097153
encode.perf.async_exec_time=1.55557e-005 (s/f)
encode.perf.async_exec_rate=0.00532255 (s/f)
encode.perf.frames_sync=2097149
encode.perf.exec_time=0.016019 (s/f)
encode.perf.frames=1
encode.perf.async_exec_time=1.81934e-005 (s/f)
encode.perf.async_exec_rate=0 (s/f)
James
Sravanthi_K_Intel
Hi James,
Thanks for the tracer log - I see quite a few flags that are raised here which could cause the issue. Since you are using INDE, I am going to point you to our INDE Media SDK engineer - Harsh. He will take a look at this question.
(Meantime, out of curiosity -  any particular reason why you not working with the latest Intel's processors? The Media SDK that is released today works well with 5th gen cores and even 6th gen (for Media SDK for Client)).
In general regarding discrete graphics - when there is dGfx in the system apart from Intel's iGfx, there are known limitations how D3DX handles them. If your monitor is connected to dGfx and your MSDK session is using iGfx, D3D9 will fail. D3D9 wants the gfx connected to monitor to do the processing, In D3D11, this issue was addressed. Basically, if you are using D3D11 and have monitor connected to dGfx, specifying to MSDK to use MFX_IMPL_AUTO_ANY|MFX_IMPL_VIA_D3D11 should ensure you are picking iGfx for the media session.
James_C_5
Hi SRAVANTHI,
Thanks for your response. The relevant project was for Industrial PC with 3th gen processor. We can't replace the processor casually. About the d3d problem, we do not use dGfx on the platform to connect monitor.
James
Harshdeep_B_Intel
Hi James,
Thank you for clarifying the issue and providing us the logs, this definitely helps us better understand this issue and your system environment. . Please let me know if this is correct description of the issue you are seeing: " You donot have dfx on your platform, only have intel graphics device(igd). MFX_ERR_DEVICE_FAILED  error is seen after long time encode currently on 3rd generation machine (i7-3632QM) and issue is reproducible with samples."
Yes, then lets first start with following updates:
After updating above steps, please run the sample_encode by adding "-d3d"
Command line: sample_encode  h264 -i test1.yuv -o output.h264 -w 1920 -h 1080 -b 10000 -f 30 -u speed -hw -d3d
Let me know your results after following above updates and steps.
James_C_5
Hi Harsh,
Thanks for your help. Yes, your description is correct. I will follow the updates and test d3d option.
James
