Error compiling intel media sdk sample
m_p__leeladharan
I have installed intel media sdk on centos 7 and now I am trying to compile the intel media sdk sample provided here. Below is the error i am getting on executing make, it halts at below error. I have attached the complete make output to this post. Need help to compile the sample
Linking CXX static library ../../__lib/debug/libvpp_plugin.a
Leeladharan
Yi_G_Intel1
I noticed from the output log, some MACROs like MFX_MEMTYPE_FROM_ENC are not defined. Could you double check your environment set up?
