Error in sample example with the use of "-rdynamic" option in gcc.
sumit_j_1
I was trying out sample example with following setting in gcc.
g++ -ggdb -rdynamic  -o $(EXEC) $(SRCS) $(CFLAGS) $(LFLAGS)
With this change, code gets stuck.
GDB summary,
(gdb) bt
#0  0x00007ffff59a5c10 in MFXInit () from /opt/intel/mediasdk/lib64/libmfxhw64-p.so.1.15
#1  0x00000000004152df in MFX_DISP_HANDLE::LoadSelectedDLL(char const*, eMfxImplType, int, int, mfxInitParam&) ()
#2  0x00000000004129a5 in MFXInitEx ()
#3  0x0000000000413a7b in MFXInit ()
#4  0x000000000040c90e in MFXVideoSession::Init (this=0x7fffffffe250, impl=3, ver=0x7fffffffe200) at /opt/intel/mediasdk//include/mfxvideo++.h:45
#5  0x000000000040d891 in Initialize (impl=3, ver=..., pSession=0x7fffffffe250, pmfxAllocator=0x0, bCreateSharedHandles=false)
    at ../common/common_utils_linux.cpp:28
#6  0x000000000040c6ff in main (argc=1, argv=0x7fffffffe5b8) at src/simple_session.cpp:47
Why after MFX_DISP_HANDLE, MFXInit() calls is made again.
WIthout "rdynamic"  code is working fine.
Sumit Jha
Bjoern_B_Intel
Hi Sumit,
I am investigating as I can reproduce it on my system as well.
Please give me a few days to come back to you.
Bjoern
Bjoern_B_Intel
Hi Sumit,
MFXInit() function name (and symbol) is used in dispatcher libmfx.a as well as in dynamic libmfxhw64-p.so. This leads to a naming conflict during runtime when using rdynamic compiler flag. The two MFXInit functions you are seeing actually belong to different libraries.
I escalated the issue to our SDK engineering team, asking for a solution/fix.
Thanks for bringing this issue up.
Best,
Bjoern
Greg_H_1
Is there a status update for this issue?  It seems to still occur with the 2017 version.  -rdynamic is useful to make backtrace_symbols() work correctly.
