Error while executing Sample_Decode for Screen capture
Chintan_M_
I started learning Intel Media SDK a few weeks ago. But I don't seem to be getting a hang of it. I get the following error when I try to run a screen capture plugin:
IntelSWTools\Intel(R)_Media_SDK_2016.0.2\samples\_bin\x64>sample_decode.exe capture -w 400 -h 108 -p "22d62c07e672408fbb4cc20ed7a053e4" -o test1.yuv
plugin_loader.h :157 [INFO] Plugin was loaded from GUID
Return on error: error code -2, src\pipeline_decode.cpp 281
Return on error: error code 1,  src\sample_decode.cpp   501
plugin_loader.h :183 [INFO] MFXBaseUSER_UnLoad(session=0x0000000002868AC0), sts=0
I have tried reinstalling Intel Media SDK after clean boot and updating my drivers for Intel GPU. Generally, HP provides the drivers but for 15.40(Intel Core i5 4th gen) they didn't roll out an update. So I installed the Generic drivers from Intel's website.
Mark_L_Intel1
Hi Chintan,
I think you already solved this issue in the following post:
https://software.intel.com/en-us/forums/intel-media-sdk/topic/610143
Do you think we can close this?
Mark
Chintan_M_
Yes, Mark, you can close this post. The issue was solved in the above-mentioned post.
~Chintan
