FRC unsupported error only when using HW
Forsythe__Kenneth
I'm using the H264Encoder DirectShow library and notice a problem only when HW is enabled. When I make the call to MFXVideoPP::QueryIOSurf() I see a trace statement in the output window: FRC Unsupported. The return status code, however, reveals no error. But encoding does not work and later on down the pipeline an MFX_ERR_ABORT is returned from the call to MFXVideoSession::SyncOperation().
Now if i change Init to choose MFX_IMPL_SOFTWARE explicitly this error goes away and the encoding works as expected (but of course we are looking to use the HW capabilities of the computer).
Searching for FRC shows this is FrameRateControl, however I don't know why that would come up.
Analyzer and Tracer logs are attached.
System Specs:
Intel NUC
Graphics Devices:
    Name                                         Version             State
    Intel(R) HD Graphics 4000                    10.18.10.3958       Active
System info:
    CPU:    Intel(R) Core(TM) i5-3427U CPU @ 1.80GHz
    OS:    Microsoft Windows 8.1 Enterprise
    Arch:    64-bit
Forsythe__Kenneth
Just in case anyone is interested this particular problem, and I think quite a few of other similar problems on this forum, were corrected by targetting latest version of the Media SDK API (1.13). I would recommend to Intel to udpate the sample applications (especially the DirectShow plugins sample) to update the target API version. Right now they are all requesting 1.1!
But none-the-less... thanks for a great product. The HW encoding is excellent.
Sravanthi_K_Intel
Thanks for the workaround Kenneth. Going forward, we will  make sure our samples reflect the right APIs.
Hai_P_1
Sorry to resurrect this thread. I also encounter exactly the same problem. Setting the SDK target to the latest version (e.g. 1.13) does not address the root cause of the problem, because that just enforces MFX_IMPL_SOFTWARE (it is likely that the Intel Graphics driver installed on your machine has an version earlier than 1.13, which makes the SDK picks the Software implementation instead of Hardware one).
I also use  Intel(R) HD Graphics 4000 (MacBook Air Mid 2012).
Is it a driver issue? I tried to turn off FRC by adding MFX_EXTBUFF_VPP_FRAME_RATE_CONVERSION into m_tabDoNotUseAlg, but that did not help. I still see the message "FRC Unsupported" in the output window.
Surbhi_M_Intel
Hi there,
Can you please send us these following details to debug the issue you have reported above -
  • System information - use system analyze present in the installed folder, under tools directory.
  • Which FRC algorithm are you using?
  • Are you using any samples, where you see this issue on your hardware?
  • Which Media SDK version do you have?
Surbhi
Hai_P_1
Hi Surbhi,
Thanks for getting back. Attached is the system information file.
I did not use any FRC algorithm. In fact I even tried to turn them off by using MFX_EXTBUFF_VPP_DONOTUSE, just in case they are on by default. However in both case (with or without using  MFX_EXTBUFF_VPP_DONOTUSE), I still see an output trace "FRC unsupported" when stepping through function QueryIOSurf(). I am not 100% sure if that is related to SyncOperation returning MFX_ERR_ABORT later on, but since Kenneth encoutered exactly the same thing, I would assume that is the case.
I am using h264_enc_filter sample in Intel Media Samples 6.0.0.98947 (that was the last version of the Samples before the DirectShow filters were taken out). My SDK is media_sdk_6.0.0.349 in Intel INDE Package.
Any advice?
Pham.
Forsythe__Kenneth
Pham is right, it did end up putting the encoder in MFX_IMPL_SOFTWARE. We did end up getting the encoder working well enough in HARDWARE mode, but we still saw the warning in the debug output. But ultimately I ended up dropping support for the DirectShow filter supplied with the samples pack, now that Intel has deprecated the DirectShow plugins (which is very upsetting news since DirectShow is so convenient to use on Windows for Media applications..... hint hint Intel).
Surbhi_M_Intel
Hi Hai,
It is not very clear from  the thread that if you would like to use FRC or not.
If you are planning to use FRC, we can decouple the problem by testing FRC support through sample_vpp, If you still see similar issue then we can handle that problem separately.
If you are not planning to use FRC, please make sure the input and o/p frame rate is same and the VPP FRC related operations are not being used. If your VPP in params matches with output params, VPP should not be triggered.
m_bUseVPP = memcmp(&m_mfxParamsVPP.vpp.In, &m_mfxParamsVPP.vpp.Out, sizeof(mfxFrameInfo)) ? true : false;
Hope this helps. If you already gone through the above steps, then please send us a reproducer to your issue.
Surbhi
P.S. Since we have deprecated the support for these filter, directshow samples were never tested on windows 10 and with latest Media SDK version. So cannot guarantee them to work well.
Surbhi_M_Intel
Hi Kenneth,
Thanks for the feedback. I know it was disappointing for quite some customers, I will definitely pass your comment to the decision makers.
-Surbhi
