Media (Intel® oneAPI Video Processing Library, Intel Media SDK)
Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
Fail to initialize H264 encoder
danielwang1971
Hi
I have a problem  for H264 encoder  with image size 2448 * 2448.
When I compression H264 stream first time , works well.
But MFXVideoENCODE:: Init() return MFX_ERR_MEMORY_ALLOC error when I try to compress second time.
And Ifcompress Full HD image works well without any problem.
Do you have any idea?
Seunghyuk_P_Intel
Hi Daniel,
We need more detail information, like which version of mediasdk, script information you executed, platform.
And if you did not test this with mediasdk samples (ex:sample_encode), please check whether this is working or not from samples, first.
c:\> sample_encode h264 -i "in.yuv" -o "out.264" -w 2448 -h 2448 -hw -d3d -vbr -b 100000 -g 30
Peter.
