Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
2965 Discussions
Fail to install MediaServerStudioEssentials2017R2 on virtualBox
applemax82
I’m SW engineer from JD. I have one question about Intel MSDK. Zachary is on vacation for Chinese New Year now. Therefore, I ask you for some help.
I intend to install MediaServerStudioEssentials2017R2 on virtual machine or some Intel server without Intel GPU, where I can make a building environment.
If I build ffmpeg with libmfx option in that building environment, can ffmpeg do transcoding task with Intel qsv codec in the Intel server with Intel GPU?
I use ‘Oracle VM Virtualbox’ to build one virtual machine, where CentOS 7.2 is installed. According to ‘media_server_studio_getting_started_guide.pdf’, I install MSDK:
1) usermod -a -G video root
2) groups root
3) install_sdk_CentOS.sh
4) rpm -ivh intel-opencl-r4.0-59481.x86_64.rpm
5) rpm -ivh intel-opencl-devel-r4.0-59481.x86_64.rpm
6) rpm -ivh intel-opencl-cpu-r4.0-59481.x86_64.rpm
7) reboot
8) run command vainfo, which reports error
[root@localhost work]# vainfo
libva info: VA-API version 0.99.0
Xlib:  extension "XFree86-DRI" missing on display ":0".
libva info: va_getDriverName() returns -1
libva error: va_getDriverName() failed with unknown libva error,driver_name=(null)
vaInitialize failed with error code -1 (unknown libva error),exit
[root@localhost work]# DISPLAY=:0.0 vainfo
Xlib:  extension "XFree86-DRI" missing on display ":0.0".
Does that means, Intel MSDK can’t be installed on virtual machine?
Thanks!
Andrew
Mark_L_Intel1
Hi Andrew,
We never try to install MSDK in VirtualBox and even you installed it, how could you keep the environment stable. But I heard someone tried on Docker and it works.
So if you want to try it, you have to make sure i915 driver is shared between VM and host.
In case of "vainfo" command, you need to make sure the following environment is set:
LIBVA_DRIVERS_PATH=/usr/lib/x86_64-linux-gnu/dri
LIBVA_DRIVER_NAME=iHD
Mark
