I'm using Intel MSS 2015 R6 on Windows 7 64bit, Core i5 4590 processor with very recent driver. And latest Intel Media Samples 6.0.0.68.
When I tried to modify sample_encode to enable QP adjustment per-frame, I found it success when encoding with H.264 but failure when encoding with HEVC - no matter using HEVC SW plugin or HEVC HW plugin (i.e. GAcc mode).
My test case was like this:
I used Const QP mode with -qpi 25 -qpp 28 -qpb 29, and then encoded a yuv to a bitstream (A).
Then in the same conditions, I added a few code to enable mfxEncodeCtrl parameter to the EncodeFrameAsync() function calls, e.g. I set the "QP" parameter to 22 and encoded the same yuv to a bitstream (B).
By byte-to-byte comparison, I found bitstream A and B are exactly the same, which suggests that the QP adjustment in mfxEncodeCtrl doesn't work at all with HEVC encoding! -In contrast, if switching my command line to corresponding H.264 cases, it can be proved that per-frame QP does work.
Please correct me if anything wrong, and let me know in case per-frame QP adjustment is possible with HEVC?
Thanks!
Thanks for reporting this issue. I've replicated the behavior you've described and will get back to you soon (hopefully tomorrow) with next steps.
I have an update for you.
Regards, Jeff
