Hardware: Intel® NUC NUC5i5MYHE/NUC5i5MYBE
Processor and graphics: i5-5300U and HD 5500
OS: Windows 8.1 and Windows 10
Our application, which is a display wall processor, requires synchronized display of display output so that there is no tearing in video when, for example, one source input is displayed on multiple display devices.
What synchronization tools is/are supported for synchronizing multiple Display Port outputs? For multiple display outputs of one NUC and multiple NUC devices' display outputs. I am looking for how we could do frame sync, frame lock and swap sync of multiple NUC display outputs. Is there something like frame synchronization using openGL Extensions that Nvidia provides?
How do we perform the following operations Nvidia provides support for on the Intel NUC platform:
Frame Synchronizing actually involves two main processes:
• Frame Sync—Synchronizing the displays to a common sync source
• Frame Lock and Swap Sync—Synchronizing applications across multiple displays or windows
Frame Sync
Frame Sync is the process of synchronizing the pixel scanning of displays to an external synchronization source. When several systems are connected together, a sync signal is fed from a master system to the other systems in the network and the displays are synchronized with each other.
Proper synchronization of an application running on multiple displays involves the following two processes:
• Frame Lock
Frame lock involves the use of hardware to synchronize the frames on each display.
When an application is displayed across multiple monitors, frame locked systems help
maintain image continuity to create a virtual canvas. Frame lock is especially critical
for stereo viewing, where the left and right fields must be in sync across all displays.
As with frame sync, frame locking of several systems requires the systems be
connected together, with the sync signal fed from the master to the other systems in the
group. A network of frame locked systems can be synchronized by connecting the
master system to an external synchronization source.
• Swap Sync
Swap sync refers to the synchronization of buffer swaps of multiple application
windows. By means of swap sync, applications running on multiple systems can
synchronize the application buffer swaps between all the systems. Swap sync requires
that the systems are frame locked.
Hi Tibet,
We are looking into possible solutions for what you are asking. These are out of the scope of Media SDK itself, so please give us some time to investigate. I have started an email thread with you on this and we can keep the conversation live there.
Hi Sravanthi, Tibet,
I have these exact same questions - Did you find any solutions?
Best,
