Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
Free memory
hui0305
Hi
I have a question about the release of all memory
Let sample_decode execution in loop
Memory is slowly increasing
Not all free memory
Why memory is slowly increasing?
Nina_K_Intel
This means that there are memory leaks in the sample app. Could you please tell the version you are using?
Nina
hui0305
Hi
Media SDK 2.0 (2.0.12.24071)
Nina_K_Intel
Could you please try with Media SDK 3.0 Beta version? If you still see the memory leak please provide the command line you use to run sample-decode. Are you using software Media SDK library or a hardware one?
Nina
hui0305
Hi
OS : window7 64bit
CPU: I7 2600K
Use Media SDK 2.0 hardware and software have the same result
command (software) : sample_decode.exe h264 -i bs.dsp264
command (hardware) : sample_decode.exe h264 -hw -i bs.dsp264
*Neglected to write yuv file
hui0305
Hi
Use Media SDK 3.0 beta2 hardware and software also have the same result
Nina_K_Intel
Thanks for the info. We will investigate.
Nina
IDZ_A_Intel
Ourinvestigationhas not finished, but here is a status update. There is a deeper issue here which we have been able to reproduceoutside oftheMedia SDK and samples. The good news is that, even with multiple simultaneous sessions, the memory use increaseis slow -- and becomes slower with more iterations.
Thank you for your help with pointing out this issue.
Jeff
Anthony_P_Intel
Newer drivers are available from http://downloadcenter.intel.com that appear to resolve this issue.(select Graphics->Processor Graphics).
Pleaes let us know if you see any other issues and thanks again for the problem report.
-Tony
