Community
cancel
Showing results for
Search instead for
Did you mean:
Geng__Penghe
Fresh installation of Intel Media SDK reports MFX_ERR_NULL_PTR(-2)
Jump to solution
I am using Ubuntu 20.04 beta:
$ lsb_release -a
No LSB modules are available.
Distributor ID:	Ubuntu
Description:	Ubuntu Focal Fossa (development branch)
Release:	20.04
Codename:	focal
Running the example code from https://github.com/Intel-Media-SDK/MediaSDK/wiki/Intel-media-stack-on-Ubuntu gives me this error:
$ /usr/share/mfx/samples/sample_encode h264   -w 176 -h 144 -f 30 -cqp -qpi 30 -qpp 30 -qpb 30 -qsv-ff    -i AUD_MW_E.yuv -o encoded_AUD_MW_E.264
[ERROR], sts=MFX_ERR_NULL_PTR(-2), Init, f pointer is NULL at /build/intel-mediasdk-UBsAHl/intel-mediasdk-20.1.0/samples/sample_common/src/sample_utils.cpp:142
[ERROR], sts=MFX_ERR_NULL_PTR(-2), Init, m_FileReader.Init failed at /build/intel-mediasdk-UBsAHl/intel-mediasdk-20.1.0/samples/sample_encode/src/pipeline_encode.cpp:1654
[ERROR], sts=MFX_ERR_NULL_PTR(-2), main, pPipeline->Init failed at /build/intel-mediasdk-UBsAHl/intel-mediasdk-20.1.0/samples/sample_encode/src/sample_encode.cpp:1627
Accepted Solutions
Mark_L_Intel1
Hi Penghe,
Sorry for the late response.
From the log messages, it seems the input file has a problem and input file was missing.
Could you double check?
Mark
Mark_L_Intel1
Hi Penghe,
Mark
Geng__Penghe
Hi Mark,
You are right. I tried it again and it works this time with the yuv file provided. Thanks a lot for the help!
Penghe
