Is anyone successfully using the encoding/decoding functions of MediaSDK with GStreamer? It seems that MediaSDK's vaapi should work with gstreamer-vaapi. However, I can't get it to work, I keep getting an error that looks like this:
[gst-1.4] [wkatsak@nuc 1.4]$ gst-launch-1.0 filesrc location=somevideo.mp4 ! qtdemux ! vaapidecode ! xvimagesink
libva info: VA-API version 0.35.0 libva info: va_getDriverName() returns 0 libva info: User requested driver 'iHD' libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so libva info: Found init function __vaDriverInit_0_32 libva info: va_openDriver() returns 0 Setting pipeline to PAUSED ... Pipeline is PREROLLING ... Got context from element 'vaapidecode0': gst.vaapi.Display=context, display=(GstVaapiDisplay)NULL; ERROR: from element /GstPipeline:pipeline0/GstVaapiDecode:vaapidecode0: GStreamer error: negotiation problem. Additional debug info: gstvideodecoder.c(2185): gst_video_decoder_chain (): /GstPipeline:pipeline0/GstVaapiDecode:vaapidecode0: decoder not initialized ERROR: pipeline doesn't want to preroll. Setting pipeline to NULL ... Freeing pipeline ...
It seems the key error is "decoder not initialized". Anyone else come up against this?
I am running MediaSDK 2015R5 installed from the official instructions, on CentOS 7.1. I've compiled gstreamer 1.4 and plugins against the git repos, and am running it inside a gst-uninstalled environment. Other things work with gstreamer (for example, I can play the same video using a software decoder from libav, in the same pipeline).
Any insight or even pointers in the right direction would be greatly appreciated.
Thanks!
-Bill
Alright, I was able to solve my issue, but I think it would be cool to get a response from Intel on what their position is.
To make everything clear, here are the steps I followed:
1) Install CentOS 7.1 with the specified package setup ("Development and Creative Workstation").
2) Install MediaSDK 2015R5, following the instructions exactly.
3) At this point vainfo will show the output I pasted above.
4) Used gstreamer-uninstalled to bootstrap an "uninstalled" copy of gstreamer-1.4.
5) Cloned and built the latest version of gstreamer-vaapi inside the gstreamer-uninstalled environment.
At this point, I cannot set up a gstreamer encoding or decoding pipeline, and the output is as I pasted above.
To get it working, I did the following:
1) Cloned and compiled the latest libva from the git repo (installed into the gstreamer-uninstalled prefix directory).
2) Cloned and compiled the latest libva-intel-driver from the git repo (also installed into the gstreamer-uninstalled prefix directory).
3) Set the LIBVA environment variables as follows:
LIBVA_DRIVERS_PATH=/home/<homedir>/gst/1.4/prefix/lib/dri LIBVA_DRIVER_NAME=i965
4) Rebuilt the gstreamer-vaapi package against the new libva.
At this point, vainfo will show the following:
vainfo libva info: VA-API version 0.38.0 libva info: va_getDriverName() returns 0 libva info: User requested driver 'i965' libva info: Trying to open /home/<homedir>/gst/1.4/prefix/lib/dri/i965_drv_video.so libva info: Found init function __vaDriverInit_0_38 libva info: va_openDriver() returns 0 vainfo: VA-API version: 0.38 (libva 1.6.0.pre1) vainfo: Driver version: Intel i965 driver for Intel(R) Haswell Mobile - 1.6.0.pre1 (1.3.2-246-ge797089) vainfo: Supported profile and entrypoints VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Simple : VAEntrypointEncSlice VAProfileMPEG2Main : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointEncSlice VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice VAProfileH264Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointEncSlice VAProfileH264High : VAEntrypointVLD VAProfileH264High : VAEntrypointEncSlice VAProfileH264MultiviewHigh : VAEntrypointVLD VAProfileH264MultiviewHigh : VAEntrypointEncSlice VAProfileH264StereoHigh : VAEntrypointVLD VAProfileH264StereoHigh : VAEntrypointEncSlice VAProfileVC1Simple : VAEntrypointVLD VAProfileVC1Main : VAEntrypointVLD VAProfileVC1Advanced : VAEntrypointVLD VAProfileNone : VAEntrypointVideoProc VAProfileJPEGBaseline : VAEntrypointVLD VAProfileH264MultiviewHigh : VAEntrypointVLD VAProfileH264MultiviewHigh : VAEntrypointEncSlice VAProfileH264StereoHigh : VAEntrypointVLD VAProfileH264StereoHigh : VAEntrypointEncSlice
Also, at this point the gstreamer-vaapi tests will all pass, and the pipeline specified above will run properly.
My assessment? It seems that something is broken in the libva that Intel is shipping with MediaSDK. There is something up with the version numbers mismatching, as I pointed out above, and the libva version in general is pretty old, even though the kernel and libdrm versions are fairly modern.
Can anyone from Intel weigh in on this?
Yes, the vaapi functions do work, for example:
(doing this off the top of my head)
gst-launch-1.0 -v filesrc location=/mnt/share/demo/big_
However, there are issues when using this in conjunction with an RTP stream currently, if you plan to use it that way. I have reported the issue to the gstreamer-vaapi developers.
The error you are seeing is w.r.t. the caps (capabilities) negotiation between filters, not the vaapi elements themselves. Have a look at the caps using gst-inspect-1.0 <elementname> to see what they input/output.
Just to be clear, the VAAPI doesn't really have anything to do with installing/running the MediaSDK. They *may* use the functions underneath, but the whole purpose of the VAAPI is to be a hardware abstraction layer, such that you don't need to care what they do. You can use the Media SDK directly, but you're going to be writing your own gstreamer plugins to do so.
Hi Randy,
Thanks for your input. Yes, I do understand that we don't have to use VAAPI, and can use the underlying functions, but we are trying to build a pipeline that can possibly do accelerated/nonaccelerated/different HW, so we could like to use VAAPI as much as possible.
Back to the problem at hand. I just did a completely clean load of CentOS 7.1 with the MediaSDK, GStreamer 1.4, etc. and I am still seeing the same issue. Here is some output from the command that you described (even with the same movie!):
gst-launch-1.0 -v filesrc location=big_buck_bunny_1080p_h264.mov ! qtdemux ! vaapiparse_h264 ! vaapidecode ! vaapisink libva info: VA-API version 0.35.0 libva info: va_getDriverName() returns 0 libva info: User requested driver 'iHD' libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so libva info: Found init function __vaDriverInit_0_32 libva info: va_openDriver() returns 0 Setting pipeline to PAUSED ... Pipeline is PREROLLING ... Got context from element 'vaapidecode0': gst.vaapi.Display=context, display=(GstVaapiDisplay)NULL; /GstPipeline:pipeline0/GstVaapiH264Parse:vaapih264parse0.GstPad:src: caps = "video/x-h264\,\ stream-format\=\(string\)avc\,\ alignment\=\(string\)au\,\ level\=\(string\)4.1\,\ profile\=\(string\)main\,\ codec_data\=\(buffer\)014d4029ffe10016274d4029a9180f0044fcb8035010101b6c2b5ef7c04001000428de09c8\,\ width\=\(int\)1920\,\ height\=\(int\)1080\,\ framerate\=\(fraction\)24/1\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ parsed\=\(boolean\)true" /GstPipeline:pipeline0/GstVaapiDecode:vaapidecode0.GstPad:sink: caps = "video/x-h264\,\ stream-format\=\(string\)avc\,\ alignment\=\(string\)au\,\ level\=\(string\)4.1\,\ profile\=\(string\)main\,\ codec_data\=\(buffer\)014d4029ffe10016274d4029a9180f0044fcb8035010101b6c2b5ef7c04001000428de09c8\,\ width\=\(int\)1920\,\ height\=\(int\)1080\,\ framerate\=\(fraction\)24/1\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ parsed\=\(boolean\)true" /GstPipeline:pipeline0/GstVaapiH264Parse:vaapih264parse0.GstPad:sink: caps = "video/x-h264\,\ stream-format\=\(string\)avc\,\ alignment\=\(string\)au\,\ level\=\(string\)4.1\,\ profile\=\(string\)main\,\ codec_data\=\(buffer\)014d4029ffe10016274d4029a9180f0044fcb8035010101b6c2b5ef7c04001000428de09c8\,\ width\=\(int\)1920\,\ height\=\(int\)1080\,\ framerate\=\(fraction\)24/1\,\ pixel-aspect-ratio\=\(fraction\)1/1" ERROR: from element /GstPipeline:pipeline0/GstVaapiDecode:vaapidecode0: GStreamer error: negotiation problem. Additional debug info: gstvideodecoder.c(2185): gst_video_decoder_chain (): /GstPipeline:pipeline0/GstVaapiDecode:vaapidecode0: decoder not initialized ERROR: pipeline doesn't want to preroll. Setting pipeline to NULL ... /GstPipeline:pipeline0/GstVaapiDecode:vaapidecode0.GstPad:sink: caps = "NULL" /GstPipeline:pipeline0/GstVaapiH264Parse:vaapih264parse0.GstPad:src: caps = "NULL" /GstPipeline:pipeline0/GstVaapiH264Parse:vaapih264parse0.GstPad:sink: caps = "NULL" /GstPipeline:pipeline0/GstQTDemux:qtdemux0.GstPad:video_0: caps = "NULL" /GstPipeline:pipeline0/GstQTDemux:qtdemux0.GstPad:audio_0: caps = "NULL" Freeing pipeline ...
Is there any way that you can run a similar pipeline and show me what your output looks like?
BTW, I was able to get this working with the "stock" drivers on Ubuntu 14.04. The only thing that I had to add was gstreamer-vaapi from the GIT. There I am able to build/use a complete pipeline.
I would ideally like to get this working on CentOS, because it is the "officially supported" distro, and also because we would like to integrate OpenCL into some of our stuff (and it seems that the Intel OpenCL drivers come from MediaSDK.
Thanks in advance,
Bill
Also, before anyone asks, here is the output of vainfo. I am a little concerned about these <unknown entrypoint>, and also, the discrepancy between the version, and the __vaDriverInit version.
vainfo libva info: VA-API version 0.35.0 libva info: va_getDriverName() returns 0 libva info: User requested driver 'iHD' libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so libva info: Found init function __vaDriverInit_0_32 libva info: va_openDriver() returns 0 vainfo: VA-API version: 0.35 (libva 1.3.1) vainfo: Driver version: 16.4.2.36242-ubit vainfo: Supported profile and entrypoints VAProfileNone : VAEntrypointVideoProc VAProfileNone : <unknown entrypoint> VAProfileMPEG2Simple : VAEntrypointEncSlice VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointEncSlice VAProfileMPEG2Main : VAEntrypointVLD VAProfileH264Baseline : VAEntrypointEncSlice VAProfileH264Baseline : <unknown entrypoint> VAProfileH264Baseline : <unknown entrypoint> VAProfileH264Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointEncSlice VAProfileH264Main : <unknown entrypoint> VAProfileH264Main : <unknown entrypoint> VAProfileH264High : VAEntrypointVLD VAProfileH264High : VAEntrypointEncSlice VAProfileH264High : <unknown entrypoint> VAProfileH264High : <unknown entrypoint> VAProfileVC1Simple : VAEntrypointVLD VAProfileVC1Main : VAEntrypointVLD VAProfileVC1Advanced : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointEncPicture VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice VAProfileH264ConstrainedBaseline: <unknown entrypoint> VAProfileH264ConstrainedBaseline: <unknown entrypoint> VAProfileVP8Version0_3 : VAEntrypointEncSlice VAProfileVP8Version0_3 : VAEntrypointVLD VAProfileVP8Version0_3 : <unknown entrypoint>
Thanks for posting the resolution. Yeah, on Ubuntu 15.04 things work ok, I'll be looking at CentOS in the near future as well for OpenCL capabilities. Was going to suggest the vainfo output, but you beat me to it.
Not sure if you are still in need of this since you seem to have resolved your issue, but here it anyways as requested:
dev@dev-pheonix:~/gstreamer-
libva info: VA-API version 0.37.1
libva info: Trying to open /usr/local/lib/dri/i965_drv_
libva info: Found init function __vaDriverInit_0_37
Redistribute latency...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
For Intel: I'm not sure if there is a way to auto-subscribe to threads, but it would nice to get notified automatically when threads you've replied to get updated
I just signed up for the forum recently, and at least for my own thread, I get updates via email.
Hi William and others,
Thanks for keeping this thread active with your discussions. The steps listed in William's post reflect what is needed to get GStreamer working with QSV. To his question where we modify libva and libdrm, Yes, we do modify them to provide MSS features and stability - going forward we would like to minimize the effort required to do this. But in short term, we provide the patches and code to follow what William did with GStreamer.
Again, thank you for this thread. The information you all have collectively posted and discussed will be valuable for many others.
Hi Sravanthi,
Since I have your attention, maybe you can answer something for me...what is the diff... It is this iHD driver that dosen't seem to work right now.
Thanks!
-Bill
Hi Bill,
That's a very relevant question. iHD is Intel's driver stack for professional QSV use and it includes i915 with our patches folded in, iHD (closed source) and VAAPI and MSDK as the public API. While i965 is the open source version of the graphics driver. So, MSDK is built with iHD and will not run with i965, and cannot guarantee it working on the open source VAAPI.
To use GStreamer with VAAPI, you can simply remove the install MSS portion of your steps and go ahead with the open source driver from the beginning. To use MSS with GStreamer, you will need to write wrapper or special GStreamer plugins using MSDK API.
Hope this helps.
Just to stress an important point: direct usage of VAAPI, even though it may work fine, is not officially supported within MSS stack.
Thanks for all your help and feedback guys. I should make a new thread for this, but since I have your attention, I figured i would ask:
My research group (in a well known Silicon Valley company) is trying to get our hands on one of the new Broadwell desktop/server chips (either Xeon E3-1285v4 or Core i7-5775C) for my project. The retail market on these is super tight right now.
Any idea if it might be possible (or who to talk to) to get a sample of one of these (or even to be able to buy one in a timely manner)?
Thanks!
-Bill
Hi Bill,
Your question was forwarded to the sales team for further information. Thanks!
Hi Bill,
Broadwell CPUs aren't offered as boxed product yet, so you can only get through a distributor. You may contact the largest distributor in your region for quote about the chips. Or if you need a sample, you can contact our field representative for samples.
As a kindly reminder, in future, in case something comes up that is different than the original topic, please start a new thread, so that it will be easier for us to track. Thanks!
