Got a problem when runing samples
Wei_F_
After I installed the mediasdk 2015 r3, I ran samples(https://software.intel.com/en-us/intel-media-server-studio-support/code-samples)to test it.
But I got an error when running the sample_decode_drm.
I ran it like this
./sample_decode_drm h264 -i test_stream.264 -o output.yuv
then got
libva info: VA-API version 0.35.0
libva info: va_getDriverName() returns 0
libva info: User requested driver 'iHD'
libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so
libva info: Found init function __vaDriverInit_0_32
libva info: va_openDriver() returns 0
Decoding Sample Version 0.0.000.0000
Input video	AVC
Output format	YUV420
Resolution	176x96
Crop X,Y,W,H	0,0,0,0
Frame rate	30.00
Memory type		system
MediaSDK impl		hw
MediaSDK version	1.13
Decoding started
Frame number:    0, fps: 0.000, fread_fps: 0.000, fwrite_fps: 0.000
Return on error: error code -1,	/home/fw/MediaSamples_Linux_5.0.1604371.71/samples/sample_decode/src/pipeline_decode.cpp	1263
Return on error: error code 1,	/home/fw/MediaSamples_Linux_5.0.1604371.71/samples/sample_decode/src/sample_decode.cpp	398
Is the command I used wrong or I didn't installed the mediasdk correctly?
Wei_F_
By the way
the OS I used is Centos 7 kernel 3.10.0-123.13.2.el7.x86_64
Cpu is Intel(R) Core(TM) i5-4590 CPU @ 3.30GHz
Mother Board is H81M-VG4
Wei_F_
I have just solved the problem.
I removed the kernel 3.10.0-123.13.2.el7.x86_64, 3.10.0-123.13.1.el7.x86_64 and install the MSSr3 on 3.10.0-123.9.3.el7.x86_64.
Now the samples works well.
Sravanthi_K_Intel
Hi Wei - Glad you found the issue. Good luck!
