H.264 Encoder for 4K Videos?
superrudi
will it be possible in the (near) future to encode Videos with higher resolution than 1920x1080? We need an encoder for videos with a 4K resolution (3840 × 2160). Are there plans to support this?
Cheers,
SuperRudi
Markus_Pingel
Hi, at least the current version seems to support 4096x2160, so 3840x2160 should also be possible. I get the warning MFX_WRN_INCOMPATIBLE_VIDEO_PARAM if I select interlaced and the encoder switches to progressive, but the produced stream looks OK. Do you set Width/Height CropH/CropW and the CodecLevel correct?
superrudi
I'm using the DirectShow filter and i thought the resolution 1920x1080 is a limitation of the encoder. Perhaps it is a limitation of the DirectShow filter. I have installed version 3.0.014 GOLD now and i will try to install the newest one.
Chuck_De_Sylva
Which driver version are you using? And which CPU is it?
celli4
My understanding (maybe wrong) is that hardware 4K encoding is not yet available in hardware, correct? Will this likely happen in upcoming CPUs? Thanks
Anthony_P_Intel
Encoding of 4096x2034 is supported. For DirectShow there are variables in the pipeline (graph) that can limit resolution. -Tony
Anthony_P_Intel
HI, I need to clarify that last statement. While it is "supported", is not available "in hardware", as indicated by the "MFX_WRN_PARTIAL_ACCELERATION" result when the Medai SDK encoder is initialized. Sorry for the confusion. -Tony
