H.264 Encoder inserts extra bytes before User Data SEI
Rotem
I am Using sample_encode for encoding H.264 and inserting "User Data Unregistered SEI".
I am getting unexpected result:
It looks like the encoder inserts few redundant (unexplained) extra bytes before the User Data.
For testing, I created an input file in NV12 format using FFmpeg CLI:
ffmpeg -f lavfi -i testsrc=size=320x256:rate=1:duration=50 -pix_fmt nv12 -f rawvideo in.nv12
I used the following command for encoding the raw video, and adding the User Data:
sample_encode.exe h264 -nv12 -f 1 -n 50 -b 100 -g 10 -hw -async 1 -avbr -d3d11 -usei 4142434445464748494A4B4C4D4E4F50:0:MSDK -i in.nv12 -o out.264 -w 320 -h 256
The UUID is ABCDEFGHIJKLMNOP, and the data is MSDK.
When inspecting out.264, I see that the encoder inserts few extra bytes before the user data.
  • Inserts 6 extra bytes when encoding a key frame.
  • Inserts 3 extra bytes when encoding a P/B frame.
The issue is reproduced with Hardware encoder and Software encoder, and in Intel Core i7 Gen 6, and Core i5 Gen 3 CPUs, using Windows 10.
Our customer is unable to decode the user data with the "extra bytes"...
The first User Data NAL Unit (applies key frame) looks as follows:
00 00 00 01 06 00 01 C0 01 01 04 05 14 41 42 43 44 45 46 47 48 49 4A 4B 4C 4D 4E 4F 50 4D 53 44 4B
The second User Data NAL Unit (applies non-key frame) looks as follows:
00 00 00 01 06 01 01 04 05 14 41 42 43 44 45 46 47 48 49 4A 4B 4C 4D 4E 4F 50 4D 53 44 4B
00 00 00 01 - Start code prefix
06 - Header byte
6 or 3 bytes in bold are redundant (unexplained)
05 - NAL Unit type
14 - Data length
41 42 43 44 45 46 47 48 49 4A 4B 4C 4D 4E 4F 50 4D 53 44 4B - UUID and User Data
Using the debugger, I saw that the Payload excludes the extra bytes:
In.pCtrl->Payload[0].Data = "x5x14ABCDEFGHIJKLMNOPMSDK<u+200e><u+200e><u+200e><u+200e>"
 nbsp;d[0].Data = "x5x14ABCDE
The extra bytes are inserted by theLMNOPMSDK<u+200e><u+200e><u+ nbsp;tra bytes are inserted m_pmfxENC-bytes are inserted by theLMN>gt;fxENC-bytes are inserted EncodeFrameAsync, without user (programmer) control.
Using FFmpeg as reference, the user data looks as it supposed to be:
ffmpeg -y -f lavfi -i testsrc=size=192x108:rate=1:duration=10 -vcodec libx264 -g 2 -pix_fmt yuv420p -bsf:v dump_extra=all,h264_metadata=sei_user_data='4142434445464748494A4B4C4D4E4F50+MSDK' vid.264
User data NAL Unit (FFmpeg result):
00 00 01 06 05 15 41 42 43 44 45 46 47 48 49 4A 4B 4C 4D 4E 4F 50 4D 53 44 4B
Is it a bug, or am I missing something?
Labels (2)
Rahila_T_Intel
Thanks for posting in Intel communities.
Thanks for sharing all the details. We are working on this case internally. We will get back to u soon.
Rotem
I did some research, and realized that the inserted bytes matches the H.264 standard specification.
According to the specification, few SEI "data units" are allowed to be concatenated - placed one after the other in the same NAL unit.
01 01 04 matches the following definitions:
  • 01 - Data type
  • 01 - Data length
  • 0C - Data (one byte)
01 01 04 - The next 3 bytes applies the next unit:
  • 01 - Data type
  • 01 - Data length
  • 04 - Data (one byte)
After the two "data units", comes our "data unit": 05 14 41 42 43 44 45 46 ...
05 - Data type
14 - Data length
Followed by 20 bytes of data.
I realized that the format matches the specification.
Thank you
Rahila_T_Intel
Glad to know that your issue is resolved. Thanks for sharing the solution with us.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
