Hello
I'm running the decode_sample using different H.264 streams on a Windows 7 computer (Intel HD Graphics 4000) and Windows 10 computer, using the latest graphic driver.
I've modified the sample to use the feature level to D3D_FEATURE_LEVEL_11_1 to get the VideoDevice interface from the d3d device.
I'm getting the error MFX_ERR_DEVICE_FAILED after a 3-4 calls to DecodeFrameAsync.
The sample works perfectly using Direct3D9 with the same input streams.
Is Direct3D11 supported on Windows 7 ? (Our company still needs to support this OS as our customer base is not planning to upgrade yet.)
Thanks for your support.
Hi Pascall,
Yes, Direct3D11 feature, which decode_sample requires, is not supported on Windows 7. It is supported from Windows 8 onwards.
On Windows 7, you can use either D3D9 memory or System memory for decode only purpose. If you want to do rendering also then use D3D9 only.
