Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
H264 decode problem
Zurab_T_
When i am transcoding from mpeg2 to h264 everything is working fine, but when I am transcoding from H264 to H264 then I am getting some strange scenario.
Some constant frame keeps showing all the time between some other frames. I can't finalize what happens please help :)
Anthony_P_Intel
Are you seeing any issue using sample_multi_transcode example application?
If issue is only with your application, you can use the "mediasdk_tracer"  tool to capture a log that may help us understand what you are asking the Media SDK API to do.
Zurab_T_
Hi Tony
thank you for reply.
I have build my program using libdispatcher-trace.a, but when I am xecuting it I get only
INFO:    MFXInit (impl=MFX_IMPL_HARDWARE, pVer=0.0 session=0x0x7fffe1a8f540
INFO:    invoking LoadLibrary(INFO:    MFXInit(MFX_IMPL_HARDWARE,ver=1.8,session=0x0x708020)
this two line of log. Can you tell me what is necessary to add?
Zurab_T_
Here is attached my video file. it is in mkv file I just renamed to mp4 because the upload restriction. and there is one image file which is that wrong frame showing all the time in this sample video.
So when I start transcoding transcoder will catch some frame at the beginning and in transcode process that frame is showing continuously.
Anthony_P_Intel
I have not seen that behavior before.
I'm just guessing, but could be issue with decode, or with frame rate conversion, or with general buffer usage.
Is the output video's framerate the same as the input?
Can you capture the *.Init parameters of Decode, VPP, and Encode ?
Zurab_T_
The frame rate is same. It's 25. Tomorrow I will copy allvmy init commands with parameterset. Thank you.
Zurab_T_
Hi Tony,
Here is init params of decoder, vpp and encoder.
decoder params begin========================
t->dec_params @0x7fffffffe248 mfxVideoParam
 AsyncDepth 1 mfxU16
 ExtParam 0x0 mfxExtBuffer **
 IOPattern 16 mfxU16
 NumExtParam 0 mfxU16
 Protected 0 mfxU16
 mfx @0x7fffffffe258 mfxInfoMFX
  #10  {...}
   InterleavedDec 0 mfxU16
   JPEGChromaFormat 0 mfxU16
   JPEGColorFormat 0 mfxU16
   Rotation 0 mfxU16
   reserved3 @0x7fffffffe2ce mfxU16 [9]
    [0] 0 mfxU16
    [1] 0 mfxU16
    [2] 0 mfxU16
    [3] 0 mfxU16
    [4] 0 mfxU16
    [5] 0 mfxU16
    [6] 0 mfxU16
    [7] 0 mfxU16
    [8] 0 mfxU16
  #11  {...}
   Interleaved 0 mfxU16
   Quality 0 mfxU16
   RestartInterval 0 mfxU16
   reserved5 @0x7fffffffe2cc mfxU16 [10]
    [0] 0 mfxU16
    [1] 0 mfxU16
    [2] 0 mfxU16
    [3] 0 mfxU16
    [4] 0 mfxU16
    [5] 0 mfxU16
    [6] 0 mfxU16
    [7] 0 mfxU16
    [8] 0 mfxU16
    [9] 0 mfxU16
  #5  {...}
   #6  union {...}
    Accuracy 0 mfxU16
    InitialDelayInKB 0 mfxU16
    QPI 0 mfxU16
   #7  union {...}
    ICQQuality 0 mfxU16
    QPP 0 mfxU16
    TargetKbps 0 mfxU16
   #8  union {...}
    Convergence 0 mfxU16
    MaxKbps 0 mfxU16
    QPB 0 mfxU16
   BufferSizeInKB 0 mfxU16
   EncodedOrder 0 mfxU16
   GopOptFlag 0 mfxU16
   GopPicSize 0 mfxU16
   GopRefDist 0 mfxU16
   IdrInterval 0 mfxU16
   NumRefFrame 0 mfxU16
   NumSlice 0 mfxU16
   RateControlMethod 0 mfxU16
   TargetUsage 0 mfxU16
  #9  {...}
   DecodedOrder 0 mfxU16
   ExtendedPicStruct 0 mfxU16
   SliceGroupsPresent 0 mfxU16
   TimeStampCalc 0 mfxU16
   reserved2 @0x7fffffffe2ce mfxU16 [9]
    [0] 0 mfxU16
    [1] 0 mfxU16
    [2] 0 mfxU16
    [3] 0 mfxU16
    [4] 0 mfxU16
    [5] 0 mfxU16
    [6] 0 mfxU16
    [7] 0 mfxU16
    [8] 0 mfxU16
  BRCParamMultiplier 0 mfxU16
  CodecId 541283905 mfxU32
  CodecLevel 30 mfxU16
  CodecProfile 77 mfxU16
  FrameInfo @0x7fffffffe278 mfxFrameInfo
   AspectRatioH 11 mfxU16
   AspectRatioW 12 mfxU16
   BitDepthChroma 0 mfxU16
   BitDepthLuma 0 mfxU16
   ChromaFormat 1 mfxU16
   CropH 0 mfxU16
   CropW 0 mfxU16
   CropX 0 mfxU16
   CropY 0 mfxU16
   FourCC 842094158 mfxU32
   FrameId @0x7fffffffe290 mfxFrameId
    #2  {...}
     DependencyId 0 mfxU16
     QualityId 0 mfxU16
    #3  {...}
     ViewId 0 mfxU16
    PriorityId 0 mfxU16
    TemporalId 0 mfxU16
   FrameRateExtD 2 mfxU32
   FrameRateExtN 50 mfxU32
   Height 576 mfxU16
   PicStruct 0 mfxU16
   Shift 0 mfxU16
   Width 720 mfxU16
   reserved @0x7fffffffe278 mfxU32 [4]
    [0] 0 mfxU32
    [1] 0 mfxU32
    [2] 0 mfxU32
    [3] 0 mfxU32
   reserved2 0 mfxU16
   reserved3 0 mfxU16
   reserved4 0 mfxU16
  NumThread 0 mfxU16
  reserved @0x7fffffffe258 mfxU32 [7]
   [0] 0 mfxU32
   [1] 0 mfxU32
   [2] 0 mfxU32
   [3] 0 mfxU32
   [4] 0 mfxU32
   [5] 0 mfxU32
   [6] 0 mfxU32
  reserved4 0 mfxU16
 reserved @0x7fffffffe248 mfxU32 [3]
  [0] 0 mfxU32
  [1] 0 mfxU32
  [2] 0 mfxU32
 reserved2 0 mfxU16
 reserved3 0 mfxU16
 vpp @0x7fffffffe258 mfxInfoVPP
decoder params end========================
vpp params begin========================
t->vpp_params @0x7fffffffe3e8 mfxVideoParam
 AsyncDepth 1 mfxU16
 ExtParam @0x7fffffffe4b8 mfxExtBuffer
  BufferId 1163089230 mfxU32
  BufferSz 24 mfxU32
 IOPattern 17 mfxU16
 NumExtParam 1 mfxU16
 Protected 0 mfxU16
 mfx @0x7fffffffe3f8 mfxInfoMFX
  #10  {...}
   Rotation 0 mfxU16
   reserved3 @0x7fffffffe46e mfxU16 [9]
    [0] 0 mfxU16
    [1] 0 mfxU16
    [2] 0 mfxU16
    [3] 0 mfxU16
    [4] 0 mfxU16
    [5] 0 mfxU16
    [6] 0 mfxU16
    [7] 22094 mfxU16
    [8] 12849 mfxU16
  #11  {...}
   Quality 0 mfxU16
   reserved5 @0x7fffffffe46c mfxU16 [10]
    [0] 0 mfxU16
    [1] 0 mfxU16
    [2] 0 mfxU16
    [3] 0 mfxU16
    [4] 0 mfxU16
    [5] 0 mfxU16
    [6] 0 mfxU16
    [7] 0 mfxU16
    [8] 22094 mfxU16
    [9] 12849 mfxU16
  #5  {...}
   #6  union {...}
    Accuracy 0 mfxU16
    QPI 0 mfxU16
   #7  union {...}
    ICQQuality 0 mfxU16
    QPP 0 mfxU16
    TargetKbps 0 mfxU16
   #8  union {...}
    MaxKbps 0 mfxU16
    QPB 0 mfxU16
   EncodedOrder 12849 mfxU16
   GopOptFlag 0 mfxU16
   GopPicSize 0 mfxU16
   GopRefDist 0 mfxU16
   NumRefFrame 22094 mfxU16
   NumSlice 0 mfxU16
  #9  {...}
   reserved2 @0x7fffffffe46e mfxU16 [9]
    [0] 0 mfxU16
    [1] 0 mfxU16
    [2] 0 mfxU16
    [3] 0 mfxU16
    [4] 0 mfxU16
    [5] 0 mfxU16
    [6] 0 mfxU16
    [7] 22094 mfxU16
    [8] 12849 mfxU16
  CodecId 0 mfxU32
  CodecLevel 0 mfxU16
  CodecProfile 0 mfxU16
  FrameInfo @0x7fffffffe418 mfxFrameInfo
   CropH 576 mfxU16
   CropW 720 mfxU16
   CropX 0 mfxU16
   CropY 0 mfxU16
   FrameId @0x7fffffffe430 mfxFrameId
    #2  {...}
     QualityId 0 mfxU16
    #3  {...}
     ViewId 0 mfxU16
    PriorityId 0 mfxU16
    TemporalId 0 mfxU16
   Height 576 mfxU16
   PicStruct 0 mfxU16
   Shift 0 mfxU16
   Width 720 mfxU16
   reserved @0x7fffffffe418 mfxU32 [4]
   reserved2 0 mfxU16
   reserved3 0 mfxU16
   reserved4 0 mfxU16
  NumThread 0 mfxU16
  reserved @0x7fffffffe3f8 mfxU32 [7]
   [0] 0 mfxU32
   [1] 0 mfxU32
   [2] 0 mfxU32
   [3] 0 mfxU32
   [4] 0 mfxU32
   [5] 0 mfxU32
   [6] 0 mfxU32
  reserved4 0 mfxU16
 reserved @0x7fffffffe3e8 mfxU32 [3]
  [0] 0 mfxU32
  [1] 0 mfxU32
  [2] 0 mfxU32
 reserved2 0 mfxU16
 reserved3 0 mfxU16
 vpp @0x7fffffffe3f8 mfxInfoVPP
  In @0x7fffffffe418 mfxFrameInfo
   CropH 576 mfxU16
   CropW 720 mfxU16
   CropX 0 mfxU16
   CropY 0 mfxU16
    #13  {...}
     QualityId 0 mfxU16
    #14  {...}
     ViewId 0 mfxU16
    PriorityId 0 mfxU16
    TemporalId 0 mfxU16
   Height 576 mfxU16
   PicStruct 0 mfxU16
   Shift 0 mfxU16
   Width 720 mfxU16
    [0] 0 mfxU32
    [1] 0 mfxU32
    [2] 0 mfxU32
    [3] 0 mfxU32
   reserved2 0 mfxU16
   reserved3 0 mfxU16
   reserved4 0 mfxU16
  Out @0x7fffffffe45c mfxFrameInfo
   CropH 576 mfxU16
   CropW 720 mfxU16
   CropX 0 mfxU16
   CropY 0 mfxU16
   FrameId @0x7fffffffe474 mfxFrameId
    #16  {...}
     QualityId 0 mfxU16
    #17  {...}
     ViewId 0 mfxU16
    PriorityId 0 mfxU16
    TemporalId 0 mfxU16
   Height 576 mfxU16
   PicStruct 1 mfxU16
   Shift 0 mfxU16
   Width 720 mfxU16
   reserved @0x7fffffffe45c mfxU32 [4]
    [0] 0 mfxU32
    [1] 0 mfxU32
    [2] 0 mfxU32
    [3] 0 mfxU32
   reserved2 0 mfxU16
   reserved3 0 mfxU16
   reserved4 0 mfxU16
  reserved @0x7fffffffe3f8 mfxU32 [8]
   [0] 0 mfxU32
   [1] 0 mfxU32
   [2] 0 mfxU32
   [3] 0 mfxU32
   [4] 0 mfxU32
   [5] 0 mfxU32
   [6] 0 mfxU32
   [7] 0 mfxU32
vpp params end========================
encoder params begin========================
t->enc_params @0x7fffffffe318 mfxVideoParam
 AsyncDepth 1 mfxU16
 IOPattern 1 mfxU16
 Protected 0 mfxU16
 mfx @0x7fffffffe328 mfxInfoMFX
  #10  {...}
   JPEGChromaFormat 7 mfxU16
   JPEGColorFormat 1 mfxU16
   Rotation 50 mfxU16
   reserved3 @0x7fffffffe39e mfxU16 [9]
    [0] 0 mfxU16
    [1] 2 mfxU16
    [2] 0 mfxU16
    [3] 0 mfxU16
    [4] 4000 mfxU16
    [5] 0 mfxU16
    [6] 0 mfxU16
    [7] 0 mfxU16
    [8] 0 mfxU16
  #11  {...}
   Interleaved 7 mfxU16
   Quality 50 mfxU16
   RestartInterval 1 mfxU16
   reserved5 @0x7fffffffe39c mfxU16 [10]
    [0] 0 mfxU16
    [1] 0 mfxU16
    [2] 2 mfxU16
    [3] 0 mfxU16
    [4] 0 mfxU16
    [5] 4000 mfxU16
    [6] 0 mfxU16
    [7] 0 mfxU16
    [8] 0 mfxU16
    [9] 0 mfxU16
  #5  {...}
   #6  union {...}
    Accuracy 0 mfxU16
    QPI 0 mfxU16
   #7  union {...}
    ICQQuality 4000 mfxU16
    QPP 4000 mfxU16
    TargetKbps 4000 mfxU16
   #8  union {...}
    MaxKbps 0 mfxU16
    QPB 0 mfxU16
   GopOptFlag 0 mfxU16
   GopPicSize 50 mfxU16
   GopRefDist 1 mfxU16
   NumSlice 0 mfxU16
   RateControlMethod 2 mfxU16
   TargetUsage 7 mfxU16
  #9  {...}
   DecodedOrder 7 mfxU16
   ExtendedPicStruct 50 mfxU16
   TimeStampCalc 1 mfxU16
   reserved2 @0x7fffffffe39e mfxU16 [9]
    [0] 0 mfxU16
    [1] 2 mfxU16
    [2] 0 mfxU16
    [3] 0 mfxU16
    [4] 4000 mfxU16
    [5] 0 mfxU16
    [6] 0 mfxU16
    [7] 0 mfxU16
    [8] 0 mfxU16
  BRCParamMultiplier 1 mfxU16
  CodecLevel 0 mfxU16
  FrameInfo @0x7fffffffe348 mfxFrameInfo
   CropH 576 mfxU16
   CropW 720 mfxU16
   CropX 0 mfxU16
   CropY 0 mfxU16
   FrameId @0x7fffffffe360 mfxFrameId
    #2  {...}
     QualityId 0 mfxU16
    #3  {...}
     ViewId 0 mfxU16
    PriorityId 0 mfxU16
    TemporalId 0 mfxU16
   Height 576 mfxU16
   PicStruct 1 mfxU16
   Shift 0 mfxU16
   Width 720 mfxU16
   reserved @0x7fffffffe348 mfxU32 [4]
    [0] 0 mfxU32
    [1] 0 mfxU32
    [2] 0 mfxU32
    [3] 0 mfxU32
   reserved2 0 mfxU16
   reserved3 0 mfxU16
   reserved4 0 mfxU16
  NumThread 0 mfxU16
  reserved @0x7fffffffe328 mfxU32 [7]
   [0] 0 mfxU32
   [1] 0 mfxU32
   [2] 0 mfxU32
   [3] 0 mfxU32
   [4] 0 mfxU32
   [5] 0 mfxU32
   [6] 0 mfxU32
  reserved4 0 mfxU16
 reserved @0x7fffffffe318 mfxU32 [3]
  [0] 0 mfxU32
  [1] 0 mfxU32
  [2] 0 mfxU32
 reserved2 0 mfxU16
 reserved3 0 mfxU16
 vpp @0x7fffffffe328 mfxInfoVPP
  In @0x7fffffffe348 mfxFrameInfo
   CropH 576 mfxU16
   CropW 720 mfxU16
   CropX 0 mfxU16
   CropY 0 mfxU16
    #13  {...}
     QualityId 0 mfxU16
    #14  {...}
     ViewId 0 mfxU16
    PriorityId 0 mfxU16
    TemporalId 0 mfxU16
   Height 576 mfxU16
   PicStruct 1 mfxU16
   Shift 0 mfxU16
   Width 720 mfxU16
    [0] 0 mfxU32
    [1] 0 mfxU32
    [2] 0 mfxU32
    [3] 0 mfxU32
   reserved2 0 mfxU16
   reserved3 0 mfxU16
   reserved4 0 mfxU16
  Out @0x7fffffffe38c mfxFrameInfo
   AspectRatioH 0 mfxU16
   AspectRatioW 0 mfxU16
   BitDepthChroma 2 mfxU16
   CropH 0 mfxU16
   CropW 0 mfxU16
   CropX 0 mfxU16
   CropY 0 mfxU16
   FourCC 0 mfxU32
   FrameId @0x7fffffffe3a4 mfxFrameId
    #16  {...}
     QualityId 0 mfxU16
    #17  {...}
     ViewId 0 mfxU16
    PriorityId 4000 mfxU16
    TemporalId 0 mfxU16
   FrameRateExtD 0 mfxU32
   FrameRateExtN 0 mfxU32
   Height 0 mfxU16
   PicStruct 0 mfxU16
   Shift 0 mfxU16
   Width 0 mfxU16
   reserved @0x7fffffffe38c mfxU32 [4]
    [0] 541283905 mfxU32
    [1] 0 mfxU32
    [2] 458752 mfxU32
    [3] 65586 mfxU32
   reserved2 0 mfxU16
   reserved3 0 mfxU16
   reserved4 0 mfxU16
  reserved @0x7fffffffe328 mfxU32 [8]
   [0] 0 mfxU32
   [1] 0 mfxU32
   [2] 0 mfxU32
   [3] 0 mfxU32
   [4] 0 mfxU32
   [5] 0 mfxU32
   [6] 0 mfxU32
   [7] 65536 mfxU32
encoder params end========================
Zurab_T_
Hi Tony,
I have resolved the problem,
I have removed MFX_BITSTREAM_COMPLETE_FRAME flag from decoder bitsream and the sequence of frames are ok.
Ramashankar
New Contributor III
Hi Zurab, Tony,
In relation with your issue, Recently i had also faced an issue where my output decoded frames from h264 decoder were getting corrupted. Then just by doing hit n trial mechanism i removed this flag  and issue got solved. Then i tried to back track and understand the concept of this flag. As name suggest, i think when this  flag is set, decoder expect a complete frame to be inputted for decoding. But i could not get clarity of how to identify a complete frame or that logical unit of frame which should be provided as input to decoder, specially in case of SPS and PPS. Whether it should be provided to decoder along with a complete frame, or it should be provided separately.
I have two different h264 streams and output behavior is different of both in above two cases and when this flag is set or not set.
So any input from your side??
