I have installed Centos, Intel media sdk 2015R6 and trying to launch samples now.
Sample h264 file #1:
$ ffmpeg -i bunny.264 ffmpeg version n2.6.1 Copyright (c) 2000-2015 the FFmpeg developers ... Input #0, h264, from 'bunny.264': Duration: N/A, bitrate: N/A Stream #0:0: Video: h264 (Constrained Baseline), yuv420p, 240x160, 24 fps, 24 tbr, 1200k tbn, 48 tbc
Sample h264 file #2:
$ ffmpeg -i black.264 ffmpeg version n2.6.1 Copyright (c) 2000-2015 the FFmpeg developers ... Input #0, h264, from 'black.264': Duration: N/A, bitrate: N/A Stream #0:0: Video: h264 (Main), yuv420p, 1280x718 [SAR 1:1 DAR 640:359], 24 fps, 23.98 tbr, 1200k tbn, 47.95 tbc
I have compiled mediasdk-tutorials-0.0.3 and trying to launch simple_decode:
[root@localhost _build]# pwd /root/mediasdk-tutorials-0.0.3/_build [root@localhost _build]# ./simple_decode -hw /root/bunny.264 libva info: VA-API version 0.35.0 libva info: va_getDriverName() returns 0 libva info: User requested driver 'iHD' libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so libva info: Found init function __vaDriverInit_0_32 libva info: va_openDriver() returns 0 Execution time: 0.27 s (5360.67 fps) [root@localhost _build]# ./simple_decode -hw /root/black.264 libva info: VA-API version 0.35.0 libva info: va_getDriverName() returns 0 libva info: User requested driver 'iHD' libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so libva info: Found init function __vaDriverInit_0_32 libva info: va_openDriver() returns 0 Incompatible video parameters. src/simple_decode.cpp 197
What is the problem with Main profile h264 video? Why is it incompatible?
Hi Max,
That's a strange behavior, I don't see this problem at our end, have used same command with an the input which is a main profile h264 bitstream. Can you please check two things here -
1. Try another main profile input and decode using the tutorial and confirm the result.
2. Try the same input with ffmpeg or samples instead of tutorials and confirm the result.
If you still see this issue, please send a short input to replicate the problem at our end.
Surbhi
