Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
2962 Discussions
HEVC 10-bit support on Media Server Studio 2017 Windows vs Media SDK 2018 for Windows
shavkat_n_
Good day,
Please help in clarifying following matter.
As I understand following table describes HEVC decode/encode capability with Media Server Studio 2017 on windows/linux.
Given for Skylake chipset.
                         decode encode
8 bit HW HW
10 bit CPU HW/CPU
With Media SDK 2018 (Windows) this table changes to following
                         decode encode
8 bit HW HW
10 bit GPU(gacc) HW/GPU(gacc)
Question 1 : Am I correct in this assumption ?
Question 2 : If I have following stack:
Windows Server 2016
Intel Media SDK 2018
Intel Xeon 6th generation (SkyLake)
It can support server level quality of HEVC 10-bit decoding(gpu) and encoding(hw/gpu) ?
Mark_L_Intel1
Hi Shavkat,
Q1. No, we should support encoding and decoding with HEVC 10bit, although we might have GACC for VPP function.
Q2. Yes, it should support. But I would prefer you can specific what the "server level quality" mean?
Mark
shavkat_n_
Hello Mark Liu,
Thanks for reply.
To clarify.
-> A1. Do you mean both MSS 2017 and Media SDK 2018 windows support HW decoding and encoding of HEVC 10 bit video ?
Could you give more specific information about which versions of MSD, MSS, 2017, 2018 windows or linux versions support HEVC 10bit encode and decode feature.
ex:
HEVC 10-bit support
Decode
Encode
MSS Essential 2017(windows)
CPU
HW/CPU
MSS Essential 2017(linux)
MSS 2018 (only linux)
MSDK 2018 (windows)
SW/GPU
HW/GPU
HEVC 8-bit support
Decode
Encode
CPU
HW/CPU
MSDK 2018 (windows)
HW/GPU
HW/GPU
Feel free to modify and update those tables.
I have looked up in documentation and release notes but it doesn't always say specific HEVC 10-bit support, but uses general words.
-> A2. I meant above software decode/encoding
shavkat_n_
It is pity that Intel Media Forum doesn't have it's own table-formatting and pasting from word doesn't work well.
Following is pasted from word...
HEVC 10-bit support
Decode
Encode
CPU
HW/CPU
MSDK 2018 (windows)
HW/GPU
HW/GPU
shavkat_n_
Previous table was confusing, so just took screenshot from ms word.
Could you please provide such hevc support table, please? You can add MSS Professional as well ?
Much appreciate,
Thank you
Mark_L_Intel1
Thanks for the details,
But what is the hardware? You could also check it first with the hardware capabilities, this might solve most of your question.
https://en.wikipedia.org/wiki/Intel_Quick_Sync_Video#Hardware_decoding_and_encoding
Yes, it is not easy to answer this question. Sorry for the inconvenience.
Mark
SeongHun_P_
We will buy Skylake hardware 'Intel® Xeon® Processor E3-1585 v5'
Thakn you..
Mark_L_Intel1
This solution should be a good news to your project.
In the previous post, I shared the page to check the hardware capability, there is one more reference you can use to check the driver layer:
https://github.com/Intel/media-driver
At the bottom of the page, it is the driver capability on the Linux system, although there is still possibility we don't support some features at the SDK level(I never know if there is so just the possibility), but it is pretty close.
Mark
SeongHun_P_
HEVC 10-bit Hardware-accelerate unsupport
But, is it possible to HEVC 10-bit decode and encode GPU using 'HEVC codec components' on SDK 2018 or MSS 2018?
Much appreciate,
Thank you..
Mark_L_Intel1
Yes, it should support, you can refer to the following release note:
https://software.intel.com/sites/default/files/managed/e1/63/media_server_studio_hevc_release_notes....
I should mention there is a third method to check the hardware capability, there is a tutorial code in 0.0.4 tutorial release called "simple_codec", you can run it to check the hardware capabilities.
Mark
