HEVC FEI SW/HW
Maksym_K_
Hi.
I'm new to this SDK, so I would like to ask obvious question about HEVC FEI API.
I don't understand by the SDK documentation a way of using the mfxFEIH265Output structur in the MFXVideoENCODE_EncodeFrameAsync.
Maybe someone can point to me to the correct direction of usage ?
Sravanthi_K_Intel
Hi Maksym - Did you take a look at the sample code provided for hevc fei? It shows how to use the mfxFEIH265Output  structure. You can find it here (sample_h265_gaa) in the package: https://software.intel.com/en-us/intel-media-server-studio-support/code-samples
Sravanthi_K_Intel
Also, this thread may be of relevance to your question - https://software.intel.com/en-us/forums/intel-media-sdk/topic/600764
Maksym_K_
Hi Sravanthi.
Yes, I looked into example. But it shows only how to do pre-processing.
That thread (https://software.intel.com/en-us/forums/intel-media-sdk/topic/600764) is exactly what I'm asking.
Thank you for pointing. Then my question is the following:
Can I use Intel Encode SDK to reuse output of FEI GAA API ? Or I need to implement rest of the encoder by myself ?
Sravanthi_K_Intel
HI Makyum - Yes, you need to implement the encoder yourself.
