HEVC Hardware Accelerated Sample Unable to Run
Soh__Ee_Binn
Hi
My machine is an Intel i7-5850EQ. I have installed the Professional Media SDK and the HEVC Evaluation.
When I tried to run the samples for HEVC encoding, I get errors.
vainfo does not show the HEVC profiles.
May I know if my hardware can support Media SDK?
Mark_L_Intel1
Hi Binn,
You are using Broadwell processor and according to the following release notes, we should support HEVC encoder:
https://software.intel.com/sites/default/files/managed/cf/4d/media_server_studio_sdk_release_notes_linux_2017.pdf
The other way to check it is to run our tutorial code simple_codec, it will report the supported codecs. You can download the tutorial 0.0.4 from following page:
https://software.intel.com/en-us/intel-media-server-studio/code-samples
What is your environment? Linux, Windows, Which MSDK version.
Mark
Soh__Ee_Binn
Hi
I am using MediaServerStudioProfessionalEvaluation2017R3.tar.gz on Linux CentOS 7.
I am able to run the HEVC when the plugin mfxplugin64_hevce_sw is used but it runs into errors when mfxplugin64_hevce_gacc.dll or the hevce_hw are used.
I have intention to purchase the Professional license if it can at least work on my system.
Mark_L_Intel1
Hi Binn,
It should work and I can confirm this by running encoding with windows platform, but I got it failure if I don't have the correct arguments. Could you confirm it with the following command line?
sample_encode.exe h265 -hw -i ..\content\test_stream_176x96.yuv -h 96 -w 176 -o out.265 -p hevce_sw
plugin_loader.h :173 [INFO] Plugin was loaded from GUID: { 0x2f, 0xca, 0x99, 0x74, 0x9f, 0xdb, 0x49, 0xae, 0xb1, 0x21, 0xa5, 0xb6, 0x3e, 0xf5, 0x68, 0xf7 } (Intel (R) Media SDK plugin for HEVC ENCODE)
Encoding Sample Version 8.3.26.352
Input file format       YUV420
Output video            HEVC
Source picture:
        Resolution      176x96
        Crop X,Y,W,H    0,0,176,96
Destination picture:
        Resolution      176x96
Frame rate      30.00
Bit rate(Kbps)  86
Gop size        60
Ref dist        0
Ref number      0
Idr Interval    0
Target usage    balanced
Memory type     system
Media SDK impl          hw
Media SDK version       1.26
Processing started
Frame number: 101
Encoding fps: 506
plugin_loader.h :199 [INFO] MFXBaseUSER_UnLoad(session=0x0000012CA00C52C0), sts=0
Processing finished
Mark Liu
Soh__Ee_Binn
Thank you, it is working
Soh__Ee_Binn
Hi
When I use simple_codec, it tells me that all the H.265 encoders are not closed successfully.
However, when I run sample_encode.exe h265 -hw -i ..\content\test_stream_176x96.yuv -h 96 -w 176 -o out.265 -p (GUID of hevce_gacc64), it can can.
Therefore, I am confused whether the hardware acceleration of the HEVC did actually get executed or not.
Any comments on this?
Mark_L_Intel1
Hi Binn,
To check if the hardware accelerated codec is used, you need to use "-hw" without GUID of GACC. You can also force hardware codec in simple_codec to make sure the hardware codec is used.
Mark
