Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
HEVC decoder exception
Rob45_
I have a HEVC decoding exception with the attached stream.
Using :
               sample_decode.exe h265 -i panasonic.265 -o out1.yuv -sw
I see the h265_exception for every frame, is there a way to find out what is wrong?
I see it only for Panasonic CCTV camera streams, Axis, Bosch, Dahua work fine.
I think it has something to do with the SPS scaling_list, since thats the only difference i can see with the other camera's.
Exception thrown at 0x00007FF8FE0A4F99 in sample_decode.exe: Microsoft C++ exception: UMC_HEVC_DECODER::h265_exception at memory location 0x000000F3EB8FB080.
plugin_loader.h :185 [INFO] Plugin was loaded from GUID: { 0x15, 0xdd, 0x93, 0x68, 0x25, 0xad, 0x47, 0x5e, 0xa3, 0x4e, 0x35, 0xf3, 0xf5, 0x42, 0x17, 0xa6 } (Intel (R) Media SDK plugin for HEVC DECODE)
pretending that aspect ratio is 1:1
Decoding Sample Version 8.4.27.0
Input video HEVC
Output format NV12
Input:
Resolution 1920x1088
Crop X,Y,W,H 0,0,1920,1080
Output:
Resolution 1920x1080
Frame rate 30.00
Memory type system
MediaSDK impl sw
MediaSDK version 1.34
Decoding started
Frame number: 0, fps: 0.000, fread_fps: 0.000, fwrite_fps: 0.000
Decoding finished
I see the same error on an other machine with these specifications,
Windows 10 Pro, 21H1,19043.1288
Intel i9-11900K
UHD Graphics 750, SDK:1.35.65571, DRV:30.0.100.9955
Any help will be appreciated,
Thanks in advance,
Robert
RahulU_Intel
Since this is a duplicate thread of https://community.intel.com/t5/Media-Intel-oneAPI-Video/HEVC-decoder-exception/m-p/1328384#M14002, we will no longer monitor this thread. We will continue addressing this issue in the other thread.
Thanks and Regards
Rahul
