I'm trying to encode HEVC using Kaby Lake 7700k with LA HW plugin, in the sample it show that i can encode with la_ext h264 and hevc
here my command line options
C:\Users\Administrador\Documents\Samples for Intel Media Server Studio 2017\_bin
\x64>sample_multi_transcode -i::vc1 C:\Users\Administrador\Desktop\VIDEO.vc1 -o:
:h265 C:\Users\Administrador\Desktop\VIDEO.hevc -w 1920 -h 1080 -hw -b 7750 -u 1
-la_ext -lad 100 -gop_size 24 -dist 4 -num_ref 4 -bref -ec::nv12 -dc::nv12
Multi Transcoding Sample Version 6.0.0.226
OpenCL or chroma conversion is present at least in one session. External memory
allocator will be used for all sessions .
plugin_loader.h :166 [ERROR] Failed to load plugin from GUID, sts=-9: { 0x58, 0x
8f, 0x11, 0x85, 0xd4, 0x7b, 0x42, 0x96, 0x8d, 0xea, 0x37, 0x7b, 0xb5, 0xd0, 0xdc
, 0xb4 } (Intel (R) Media SDK plugin for LA ENC)
plugin_loader.h :170 [INFO] Plugin was loaded from GUID: { 0x6f, 0xad, 0xc7, 0x9
1, 0xa0, 0xc2, 0xeb, 0x47, 0x9a, 0xb6, 0xdc, 0xd5, 0xea, 0x9d, 0xa3, 0x47 } (Int
el (R) Media SDK HW plugin for HEVC ENCODE)
[ERROR], sts=MFX_ERR_UNSUPPORTED(-3), TranscodingSample::CTranscodingPipeline::E
ncodePreInit, m_pmfxENC->Query failed at src\pipeline_transcode.cpp:445
[ERROR], sts=MFX_ERR_UNSUPPORTED(-3), TranscodingSample::CTranscodingPipeline::I
nit, EncodePreInit failed at src\pipeline_transcode.cpp:3073
[ERROR], sts=MFX_ERR_UNSUPPORTED(-3), TranscodingSample::Launcher::Init, pThread
Pipeline->pPipeline->Init failed at src\sample_multi_transcode.cpp:313
plugin_loader.h :196 [INFO] MFXBaseUSER_UnLoad(session=0x0000000001D27290), sts=
0
[ERROR], sts=MFX_ERR_UNSUPPORTED(-3), wmain, transcode.Init failed at src\sample
_multi_transcode.cpp:682
Someone know what the problem can be? I also tryed with h264 encoding and show same error
Hi Celio,
Sorry for the delay in reply.
it seems like the plug in couldnt be found- can you supply more details about the system (CPU, what kind of OS) and the MSDK version?
you said you had the same issue with h264- did you still get the same plug error?
Stav
Hi Celio, Is it issue on KBL only or SKL showing the same problem?
Just to make sure, do you have plugin in your working folder?
