HEVC support by Intel Media SDK
Igor_R_
According to Release notes Intel Media SDK supports HEVC encoding/decoding 64/32 bit.
After I downloaded a free Intel Media SDK version I found out that unfortunately there are no HEVC plugins downloaded as I saw in case
of Intel Media Server Studio SDK (for example mfxplugin64_hevcd_sw.dll)..
May be there is some paid version of  Intel Media SDK that does include HEVC plugins or I did somthing wrong?
Thanks in advance,
Igor Rivkin
Light_Intel
Hi Igor,
This issue does not belong in this forum. I am going to move it to the Media SDK forum where you can get the help you need.
Noga
Intel Developer Support
Jeffrey_M_Intel1
Hi Igor,
There are 3 different routes to HEVC.
  1. Full HW implementation in the driver for 6th Generation Core/Skylake.  These plugins are distributed with the driver install.  More info here: https://software.intel.com/en-us/forums/intel-media-sdk/topic/593838
  2. A software implementation, distributed as a plugin with the Professional version of Media Server Studio
  3. A hybrid GPU accelerated version (covering a wider range of hardware than option #1) also distributed as a plugin with the professional version of Media Server Studio
Since it looks like you're after option #1, try the instructions in the link provided.  If that does not work the first things to try are
  1. Check your machine -- the full hardware implementation is only available for 6th Generation Core architecture processors with HD/Iris/Iris Pro graphics.
  2. If your HW is the right generation and you can see an Intel graphics adapter in device manager, try updating your graphics driver to the latest version (15.40.x.x) from http://downloadcenter.intel.com.
Hope this helps,
Jeff
li_b_
Hi Lgor, I want to know if Intel® Media Server Studio 2017 - Community Edition includes HEVC plugin(e.g. mfxplugin64_hevcd_sw.dll) , Or I must use Professional version (or other version) if I want to use HEVC Plugin. Thanks.
