HW HEVC encode failed
Gang_B_
Hi, Experts
I try to run sample_encode under Intel Media SDK Samples 2016 6.0.0.142.
​It works well when I encode AVC, but failed when I encode HEVC.
Do you know why?
The log is as follows:
.\sample_encode.exe h265 -i pedestrian_area_1080p25.yuv -o pedestrian_area_1080p25.265 -w 1920 -h 1080 -u speed -hw
plugin_loader.h :164 [INFO] Plugin was loaded from GUID: { 0x6f, 0xad, 0xc7, 0x91, 0xa0, 0xc2, 0xeb, 0x47, 0x9a, 0xb6, 0xdc, 0xd5, 0xea, 0x9d, 0xa3, 0x47 } (Intel (R) Media SDK HW plugin for HEVC ENCODE)
Return on error: error code -3, src\pipeline_encode.cpp 595
Return on error: error code -3, src\pipeline_encode.cpp 1193
Return on error: error code -3, src\pipeline_encode.cpp 1117
Return on error: error code 1,  src\sample_encode.cpp   744
Frame number: 0
Encoding fps: -0plugin_loader.h :190 [INFO] MFXBaseUSER_UnLoad(session=0x013A9B38), sts=0
My environment is as follows:
 Graphics Devices: Intel(R) HD Graphics 6000 Version 20.19.15.4624
CPU: Intel(R) Core(TM) I5-5250u CPU @1.60GHz
OS: Microsoft Windows 10
Arch: 64
Installed Media SDK packages: Intel(R) Media SDK 2016 R2
ViCue_S_
to get hardware hevc encoding you need at leat Skylake, which is 6th generation. Yours is 5th generation Broadwell. you may use software or upgrade
