Does the SDK for Linux server rely on E3 1285lv2 or Core Gen3 absolutely? I just want to try the SDK. My laptop is Core Gen3. Is that ok?BTW, does wubi-installed ubuntu work for the SDK?
Hi, 3rd gen Core is supported, should be ok to try on your laptop. Wubi installed ubuntu should be fine as long as it is Ubuntu 12.04 and kernel and libs requirements are met, please check out the release notes document for those.
Nina
Thank you for your answer, Nina.
