Hi everyone. I'm using the Intel media sdk to decode an H.264 live video stream for broadcasting with an Intel graphics card, on an x64 Windows 7.
The streaming process meets serious handle leaks when it keeps initializing the decoder, decoding with it, and then closing it.
The handle count can grow up to more than 20 throusand and keeps growing.
I use 64-bit WinDbg to track down the leaks. I find that the huge amount of handles are mostly handles to Windows events, and WinDbg reveals the increasing event handles are opened by OpenEvent() function in the function invocation herarchy under MFXVideoDECODE_Init().
Here's WinDbg commands I use to track down the problem, and their outputs.
The following is the status of handles after the process has run for a while.
<code>
0:055> !handle
929 Handles
Type Count
None 5
Event 656
Section 14
File 51
Directory 2
Mutant 14
WindowStation 2
Semaphore 76
Key 12
Thread 71
Desktop 1
IoCompletion 9
Timer 3
KeyedEvent 1
TpWorkerFactory 12
</code>
And the following is the status of one of the increasing handles to the event. Apparently the handle count of the event is too large.
<code>
0:055> !handle 718 f
Handle 718
Type Event
Attributes 0x10
GrantedAccess 0x1f0002:
Delete,ReadControl,WriteDac,WriteOwner,Synch
ModifyState
HandleCount 502
PointerCount 509
Name \BaseNamedObjects\IGFXKMDNotifyBatchBuffersComplete
Object Specific Information
</code>
And the call stack of the thread opening the event. In the listing, we see the increasing handles are opened by OpenEvent() function, while MFXVideoCORE_GetHandle() is under invocation.
<code>
0:055> !htrace 718
Handle = 0x0000000000000718 - OPEN
Thread ID = 0x0000000000000258, Process ID = 0x0000000000000d3c
0x0000000076fc171a: ntdll!NtOpenEvent+0x000000000000000a
0x000007fefd1c74aa: KERNELBASE!OpenEventA+0x00000000000000da
0x000007fedffef126: igdumdim64!OpenAdapter+0x000000000025e126
0x000007fedff26d95: igdumdim64!OpenAdapter+0x0000000000195d95
0x000007fedfef1a23: igdumdim64!OpenAdapter+0x0000000000160a23
0x000007fedfed74b2: igdumdim64!OpenAdapter+0x00000000001464b2
0x000007fee4326320: d3d9!DebugSetLevel+0x000000000006e500
0x000007fee42c4b61: d3d9!DebugSetLevel+0x000000000000cd41
0x000007fee42d66fd: d3d9!DebugSetLevel+0x000000000001e8dd
0x000007fef8985c8a: dxva2!DXVA2CreateVideoService+0x000000000000216a
0x000007fef898549f: dxva2!DXVA2CreateVideoService+0x000000000000197f
0x0000000005841ddb: libmfxhw64!MFXVideoVPP_GetVPPStat+0x000000000016679b
0x00000000056d220a: libmfxhw64!MFXVideoCORE_GetHandle+0x000000000001219a
0x00000000056d1b93: libmfxhw64!MFXVideoCORE_GetHandle+0x0000000000011b23
</code>
I set a break point in the bottom of the stack, where MFXVideoCORE_GetHandle() is located, and find out it is only called under one function invocation hierarchy:
<code>
0:055> bp libmfxhw64!MFXVideoCORE_GetHandle+0x0000000000011b23
0:055> g
Breakpoint 0 hit
*** ERROR: Symbol file could not be found. Defaulted to export symbols for C:\Program Files (x86)\Intel\Media SDK\libmfxhw64.dll -
libmfxhw64!MFXVideoCORE_GetHandle+0x11b23:
00000000`06e01b93 8bf8 mov edi,eax
0:033> kb
RetAddr : Args to Child : Call Site
00000000`06e2db48 : 00000000`04f54310 00000000`04f54030 00000000`04a50698 00000000`00000000 : libmfxhw64!MFXVideoCORE_GetHandle+0x11b23
00000000`06e059ba : 00000000`00000000 00000000`01df4ed0 00000000`00000001 00000000`04f55f10 : libmfxhw64!MFXVideoVPP_GetVPPStat+0x22508
000007fe`f799fb4b : 00000000`0465aeb0 00000000`00000000 00000000`0f1bf9d0 00000000`0f1bf1f0 : libmfxhw64!MFXVideoDECODE_Init+0x1aa
000007fe`f799e32a : 00000000`01deffd0 00000000`01df4ed0 00000000`01df4ed0 cccccccc`cccccccc : IntelMediaDecoder!MFXVideoDECODE::Init+0x3b
</code>
I extracted the main operation procedure of the source code as follows.
<code>
while (m_isRunning)
mfxStatus sts = MFX_ERR_NONE;
MFXVideoDECODE *m_pMFXDecoder = new MFXVideoDECODE(m_mfxSession);
mfxVideoParam m_mfxVideoParams;
MSDK_ZERO_MEMORY(m_mfxVideoParams);
m_mfxVideoParams.mfx.CodecId = MFX_CODEC_AVC;
m_mfxVideoParams.IOPattern = (mfxU16)MFX_IOPATTERN_OUT_VIDEO_MEMORY;
m_mfxVideoParams.AsyncDepth = 1;
sts = m_pMFXDecoder->DecodeHeader(&m_mfxBS, &m_mfxVideoParams);
sts = m_pMFXDecoder->Query(&m_mfxVideoParams, &m_mfxVideoParams);
sts = m_pMFXDecoder->QueryIOSurf(&m_mfxVideoParams, &Request);
sts = m_pMFXDecoder->Init(&m_mfxVideoParams);
// decoding...
MSDK_SAFE_DELETE(m_pMFXDecoder);
</code>
So can someone help me find out how to stop the handles from endlessly increasing and ensure the streaming still functions properly?
Thanks!
Hi Darrell,
Which product are you using ? Media Server Studio ?
For better understand your system. Please send mediasdk_system_analyzer log to me, you can find mediasdk_system_analyzer under following folder.
<installed folder>\mediasdk\tools\mediasdk_system_analyzer.
Zachary
Jiandong Z. (Intel) wrote:
Hi Darrell,
Zachary
Hi Zachary. I am not using Media Server Studio. I directly copied the SDK lib files libmfx.lib, libmfxmd.lib, and libmfxsw64.dll, and associated SDK header files into my Visual Studio project and then compiled them.
I list the mediasdk_system_analyzer log of the system running the decoder below:
Intel Media SDK System Analyzer (64 bit)
The following versions of Media SDK API are supported by platform/driver:
Version Target Supported Dec Enc
1.0 HW Yes X
1.0 SW No
1.1 HW Yes X
1.1 SW No
1.3 HW Yes X
1.3 SW No
1.4 HW Yes X
1.4 SW No
1.5 HW Yes X
1.5 SW No
1.6 HW Yes X
1.6 SW No
1.7 HW No
1.7 SW No
1.8 HW No
1.8 SW No
Graphics Devices:
Name Version State
Intel(R) HD Graphics 9.18.10.3071 Active
System info:
CPU: Intel(R) Celeron(R) CPU 1037U @ 1.80GHz
OS: Microsoft Windows 7
Installed Media SDK packages (be patient...processing takes some time):
Tips:
- SW target does not work: make sure Media SDK DLL (e.g. libmfxsw64.dll)
is located in your executable path or in system path
Analysis complete... [press ENTER]
Hi everyone. I modified the SDK sample sample_decode, making it continually invoke MFXVideoDECODE_Init() and MFXVideoDECODE_Close().
When sample_decode is running, I see the handles in the process keep increasing, and with WinDbg I see the huge amount of handles are still opened with OpenEvent() in MFXVideoDECODE_Init().
The product I installed is w_inde_2015.2.027.exe, and the sample version is MediaSamples_Windows_6.0.0.68.msi.
The modified code is as below. Would someone please help me with this problem? Thanks!
#if defined(_WIN32) || defined(_WIN64)
int _tmain(int argc, TCHAR *argv[])
#else
int main(int argc, char *argv[])
#endif
sInputParams Params; // input parameters from command line
mfxStatus sts = MFX_ERR_NONE; // return value check
sts = ParseInputString(argv, (mfxU8)argc, &Params);
MSDK_CHECK_PARSE_RESULT(sts, MFX_ERR_NONE, 1);
bool con = true;
while (con)
CDecodingPipeline Pipeline; // pipeline for decoding, includes input file reader, decoder and output file writer
if (Params.bIsMVC)
Pipeline.SetMultiView();
sts = Pipeline.Init(&Params);
MSDK_CHECK_RESULT(sts, MFX_ERR_NONE, 1);
// print stream info
/*Pipeline.PrintInfo();
msdk_printf(MSDK_STRING("Decoding started\n"));*/
Sleep(1);
/*for (;;)
sts = Pipeline.RunDecoding();
if (MFX_ERR_INCOMPATIBLE_VIDEO_PARAM == sts || MFX_ERR_DEVICE_LOST == sts || MFX_ERR_DEVICE_FAILED == sts)
if (MFX_ERR_INCOMPATIBLE_VIDEO_PARAM == sts)
msdk_printf(MSDK_STRING("\nERROR: Incompatible video parameters detected. Recovering...\n"));
else
msdk_printf(MSDK_STRING("\nERROR: Hardware device was lost or returned unexpected error. Recovering...\n"));
sts = Pipeline.ResetDevice();
sts = Pipeline.ResetDecoder(&Params);
continue;
else
break;
msdk_printf(MSDK_STRING("\nDecoding finished\n"));
return 0;
by the way, the command I use to run the sample is
sample_decode h264 -i test.h264 -o output.yuv -d3d -hw
Hi Darrell,
It looks like your graphic driver is not an up-to-date one.
Can you please download from following URL and setup up-to-date driver ?
https://downloadcenter.intel.com/product/81505 select "Intel® HD Graphics Production Driver for Windows* 7/8.1 64-bit (N-Series)".
Let's see if the same issue still happened.
Zachary
Hi Zachary,
I've upgraded the graphics driver to version 10.18.10.4276, published on Aug 17th 2015.
Now I modified sample_decode and made it repeat the procedure of initializing the decoder, decoding with it, and closing it.
The handles are still increasing, but via WinDbg, I see they are not opened by OpenEvent() in MFXVideoDECODE_Init(), the new handles are opened by CreateEvent() in MFXVideoDECODE_DecodeFrameAsync().
The code in sample_decode I modified is as below.
#else
#endif
bool con = true;
while (con)
if (Params.bIsMVC)
for (;;)
else
continue;
else
break;
Sleep(1);
return 0;
The new analyzer log is as follows.
1.0 HW Yes X
1.0 SW No
1.1 HW Yes X
1.1 SW No
1.3 HW Yes X
1.3 SW No
1.4 HW Yes X
1.4 SW No
1.5 HW Yes X
1.5 SW No
1.6 HW Yes X
1.6 SW No
1.7 HW Yes X
1.7 SW No
1.8 HW Yes X
1.8 SW No
Graphics Devices:
Name Version State
Intel(R) HD Graphics 10.18.10.4276 Active
System info:
Tips:
Please help me check on this problem. Thanks.
Hi Darrell,
Thank you for bring this issue to our attention. We were able to reproduce this issue and it is a driver bug. We will further investigate this issue and hope to fix with our next driver update.
Harsh Jain (Intel) wrote:
Hi Darrell,
Hi Harsh.
OK, reply received, waiting for your driver update.
Thank you very much.
Hi Harsh,
can you just develop and send me a temporary version of the driver first? A version with which the handle leaking bug is fixed.
Because my project is urgent and I must have this issue fixed with it as soon as possible.
Hi Darrell,
Thank you for letting us know time requirement for fix on this issue. Currently, our Driver team have been notified on this issue. I will update once, I have any more information.
Thank you,
Hi Harsh,
OK, thank you, I wait for your reply.
I also see a memory leak that seems to be originated from inside the MFX functions.
By using an i7-3770K processor, I decode 12SD+4HD live channels in realtime. DecodeFrameAsync and delayed SyncOperation mainly. Memory increases gradually, Windows debugging tool UMDH.exe shows the following backtrace. Intel sys_trace output also included.
Driver version is the same as the handle leaking one. Is this the same driver issue, which is to be fixed with the next release?
Altuğ
+ 8e7b4a ( 90e084 - 2653a) 487042 allocs BackTraceD0CBEE0
+ 473da5 ( 487042 - 1329d) BackTraceD0CBEE0 allocations
ntdll!MD5Final+0000A63D
igdumdim64!OpenAdapter+0009FDAF
igdumdim64!OpenAdapter+000A06F7
igdumdim64!OpenAdapter+000A169E
igdumdim64!OpenAdapter+00101E14
igdumdim64!OpenAdapter+0010034D
igdumdim64!OpenAdapter+000F9691
igdumdim64!OpenAdapter+0011673D
igdumdim64!OpenAdapter+000BC375
d3d9!DecodeExecuteLH+0000014E
d3d9!CDecodeDevice::DecodeExecute+00000136
dxva2!DXVA2CreateVideoService+00002CD2
igfxcmrt64!CmDevice_RT::LoadProgram+00000128
igfxcmrt64!CmQueue_RT::Enqueue+00000299
igfxcmrt64!CmQueue_RT::EnqueueCopyGPUToCPUFullStride+0000002E
libmfxhw64!???+00000000 : 7FEE29E3ACE
libmfxhw64!MFXVideoCORE_GetHandle+0000BB4F
libmfxhw64!MFXVideoCORE_GetHandle+0000B7DC
libmfxhw64!MFXVideoVPP_GetVPPStat+00004EBE
libmfxhw64!MFXVideoVPP_GetVPPStat+00073869
libmfxhw64!MFXVideoVPP_GetVPPStat+0000C35C
libmfxhw64!MFXVideoVPP_GetVPPStat+003A6713
libmfxhw64!MFXVideoVPP_GetVPPStat+003A68BA
kernel32!BaseThreadInitThunk+0000000D
ntdll!RtlUserThreadStart+00000021
+ 8e7b4a ( 90e084 - 2653a) 487042 allocs BackTraceD0CBC60
+ 473da5 ( 487042 - 1329d) BackTraceD0CBC60 allocations
igdumdim64!OpenAdapter+000F9675
+ 8e7b36 ( 90e084 - 2654e) 487042 allocs BackTrace12CFCD20
+ 473d9b ( 487042 - 132a7) BackTrace12CFCD20 allocations
libmfxhw64!MFXVideoVPP_GetVPPStat+000ED31E
libmfxhw64!MFXVideoVPP_GetVPPStat+000ED616
libmfxhw64!MFXVideoVPP_GetVPPStat+000ED79B
+ 8e7b34 ( 90e084 - 26550) 487042 allocs BackTrace12CFCAA0
+ 473d9a ( 487042 - 132a8) BackTrace12CFCAA0 allocations
C:\Users\User\Desktop\ms2>C:\Users\User\Desktop\shared\msdk2013-tools\mediasdk_sys_analyzer\x64\sys_
analyzer.exe
1.0 HW Yes X X
1.0 SW No
1.1 HW Yes X X
1.1 SW No
1.3 HW Yes X X
1.3 SW No
1.4 HW Yes X X
1.4 SW No
1.5 HW Yes X X
1.5 SW No
1.6 HW Yes X X
1.6 SW No
Graphics Devices:
Name Version State
Intel(R) HD Graphics 4000 10.18.10.4276 Active
VNC Mirror Driver 1.7.0.0 08
System info:
CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
OS: Microsoft Windows 7 Professional
Arch: 64-bit
Installed Media SDK DirectShow filters:
Installed Intel Media Foundation Transforms:
Intel« Hardware M-JPEG Decoder MFT : {00C69F81-0524-48C0-A353-4DD9D54F9A6E}
Intel« Hardware VC-1 Decoder MFT : {059A5BAE-5D7A-4C5E-8F7A-BFD57D1D6AAA}
Intel« Hardware H.264 Decoder MFT : {45E5CE07-5AC7-4509-94E9-62DB27CF8F96}
Intel« Hardware MPEG-2 Decoder MFT : {CD5BA7FF-9071-40E9-A462-8DC5152B1776}
Intel« Quick Sync Video H.264 Encoder MFT : {4BE8D3C0-0515-4A37-AD55-E4BAE19AF471}
Intel« Hardware Preprocessing MFT : {EE69B504-1CBF-4EA6-8137-BB10F806B014}
Tips:
Hi Altug,
Apologies that you are seeing this issue. With every driver release supports 2 hardware generations (current and previous). Current is Skylake (6th gen) and previous is Broadwell (5th gen) along with Haswell (4th gen) Win10 support. You are using i7-3770K (IvyBridge/3rd gen) processor which is three generations old . Unfortunately we have limited support on 3rd gen and could take longer turn around time for fix. Hence, to resolve this issue, I suggest following pointers 1) Workaround it in your application or 2) Upgrading to latest hardware.
Any further questions please start a new thread on Media forum - https://software.intel.com/en-us/forums/intel-media-sdk, it will be easier for us to track and respond.
