Handling of the emulation prevention byte in the H264 encoder
Daniel_E-B
I'm using the H264 encoder to encode video and some SEI registered and unregistered data.
I would like to now if it is our reponsability (in the case of the insertion of a SEI unregistered timecode for instance) to generate the emulation prevention byte or if is done by the Media SDK's encoder.
Thanks!
Petter_L_Intel
Hi Daniel,
It is the responsibility of the application to insert custom SEI payloads. There is a chapter in the Media SDK Developers Guide document showcasing an example on how to insert SEI messages into encoded streams.
Petter
Daniel_E-B
Hi Petter,
I'm aware that it is the application's responsability to insert the SEI payloads. In fact, I have read the Developpers Guide and done accordingly in my code. However, in the Developpers Guide there's no mention of the "emulation prevention byte".
The ITU-T H.264 specification recommends to add this byte of value 0x03 to a NAL unit in order to ensure that no sequence of consecutive bytes in the NAL unit contains a start code prefix.
For instance: if in my SEI payload I have a value equivalent to a start code prefix: 0x000001, the last byte should be changed to 0x03 so a potential decoder wouldn't mistake the presence of these bytes as the beginning of a new NAL unit.
Now my question:
Is it the application's responsabilty to add this byte in the payload of a NAL unit? Or does the Media SDK do a sort of check on the received payload to add the emulation byte?
Thanks!
Petter_L_Intel
Hi Daniel,
I just realized your question was never answered.  Sorry for the delay.  Media SDK will apply EPB automatically to SEI messages which are added by application as payload during encode.
Petter
