Heads up: IMSDK Browser does not work in HighContrast mode. Try it. It's the first app I've used that won't. Resource monitor won't draw its window but it does start. But this is the first the pops a Clsoe App/GPF box.
It should be simple enough to recreate; just start in high contrast mode (win7)
Fault bucket , type 0
Event Name: CLR20r3
Response: Not available
Cab Id: 0
Problem signature:
P1: sdk_browser.exe
P2: 2.5.113.668
P3: 51cb24b4
P4: sdk_browser_controls
P5: 2.5.113.668
P6: 51cb24b2
P7: 48d
P8: ee
P9: System.NullReferenceException
P10:
Thanks for reporting the issue. We will look into this.
Petter
Add: in case it matters this has the D2D / IE10 update installed. After doing that Resource Monitor (taskmgr type thing on win7) won't draw its window so you may need that. This D2D update (brings Win7 closer to WIn8) was also available as a separate KB install, but installing IE10 (or IE11 I suppose) installs that D2D update.
