Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
How to Use CQP?
lonely_hearts_club
I have set the variable m_EncoderParams in CH264EncVideoFilter::SetDefaultParams() to:
 m_EncoderParams.level_idc                      = Params::LL_13;
m_EncoderParams.profile_idc                    = Params::PF_H264_BASELINE;
m_EncoderParams.pc_control                     = Params::PC_FRAME;
m_EncoderParams.ps_control.GopPicSize          = 32;
 m_EncoderParams.ps_control.GopRefDist          =1;
 m_EncoderParams.ps_control.NumSlice            = 0; // autoselect
 m_EncoderParams.rc_control.rc_method           = IConfigureVideoEncoder::Params::RCControl::RC_CQP;
    m_EncoderParams.target_usage                   = MFX_TARGETUSAGE_UNKNOWN;
 m_EncoderParams.frame_control.width            = 384;
m_EncoderParams.frame_control.height           = 216;
and in CopyEncoderToMFXParams() function, I set
pMFXInfo->QPI = 25;
pMFXInfo->QPP = 25;
I also removed the "CodecPreset::VParamsFromPreset()" call in this function.
I tried different QPI and QPP values, and I observed that the bitrate went down as the QPI and QPP was set to higher values. However, the video image quality remained poor all the time(moving part is very vague) with different QP values.
Why didn't the image quality  change at all?
Anthony_P_Intel
Hi, Please ensure that the code involving the pMFXInfo is not using any members that are not used for CQP, as the QPI, QPP, and QPB members are shared (with union) with InitialDelayInKB, Accuracy, TargetKbps, MaxKbps, and Convergence. If there is any code setting these it will overwrite your QP values. If you have an example of your encoded output, it can be anaylyzed to see if it is really the desired QPI or QPP. -Tony
lonely_hearts_club
-Tony
Hi,Tony! Thank you for your reply. I had analyzed the encoded output stream and found out that the real QPP was always 51--the same value as the target bitrate which showed on the property page. I traced the"m_mfxParamsVideo" variable in the sample code and dicovered that in CheckInputType() function, TargetKbps and MaxKbps was set to the following: if (m_mfxParamsVideo.mfx.TargetKbps < nBitrateMin * nFramerateCoeff || m_mfxParamsVideo.mfx.TargetKbps > nBitrateMax * nFramerateCoeff) { m_mfxParamsVideo.mfx.MaxKbps = (mfxU16)(nBitrateRecommended * nFramerateCoeff); m_mfxParamsVideo.mfx.TargetKbps = m_mfxParamsVideo.mfx.MaxKbps; } According to your hint, this has actually changed the value of QPI and QPP. I had just simply cancelled these two statements and the problem was solved. -Patrick
