How to enable HEVC HW acceleration in Media Sample?
qin_c_
Hi all
when i ran sample_decode in HEVC HW mode,i got this error:
[root@localhost x64]# ./sample_decode_x11 h265 -i blue_sky.h265 -o blue_sky_h265.yuv -hw -p 33a61c0b4c27454ca8d85dde757c6f8e
plugin_loader.h :153 [ERROR] Failed to load plugin from GUID, sts=-9: { 0x33, 0xa6, 0x1c, 0x0b, 0x4c, 0x27, 0x45, 0x4c, 0xa8, 0xd8, 0x5d, 0xde, 0x75, 0x7c, 0x6f, 0x8e } (Intel (R) Media SDK HW plugin for HEVC DECODE)
Return on error: error code -3,    /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK3/git/mdp_msdk-samples/samples/sample_decode/src/pipeline_decode.cpp    266
Return on error: error code 1,    /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK3/git/mdp_msdk-samples/samples/sample_decode/src/sample_decode.cpp    501
if i ran that in SW mode ,it was OK.
[root@localhost x64]# ./sample_decode_x11 h265 -i blue_sky.h265 -o blue_sky_h265.yuv -sw -p 15dd936825ad475ea34e35f3f54217a6
plugin_loader.h :157 [INFO] Plugin was loaded from GUID
Decoding Sample Version 6.0.16043175.175
Input video	HEVC
Output format	YUV420
Resolution	1920x1088
Crop X,Y,W,H	0,0,0,0
Frame rate	30.00
Memory type		system
MediaSDK impl		sw
MediaSDK version	1.16
Decoding started
Frame number:  217, fps: 22.357, fread_fps: 0.000, fwrite_fps: 24.43199
Decoding finished
plugin_loader.h :183 [INFO] MFXBaseUSER_UnLoad(session=0x0x7fc318e82210), sts=0
then i checked plugin.cfg,didn't find hw_decoder:
[HEVC_Decoder_15dd936825ad475ea34e35f3f54217a6]
GUID = 15dd936825ad475ea34e35f3f54217a6
PluginVersion = 1
APIVersion = 272
Path = /opt/intel/mediasdk/plugins/libmfx_hevcd_sw64.so
Type = 1
CodecID = HEVC
Default = 0
[HEVC_Encoder_e5400a06c74d41f5b12d430bbaa23d0b]
GUID = e5400a06c74d41f5b12d430bbaa23d0b
PluginVersion = 1
APIVersion = 272
Path = /opt/intel/mediasdk/plugins/libmfx_hevce_hw64.so
Type = 2
CodecID = HEVC
Default = 0
[HEVC_Encoder_2fca99749fdb49aeb121a5b63ef568f7]
GUID = 2fca99749fdb49aeb121a5b63ef568f7
PluginVersion = 1
APIVersion = 272
Path = /opt/intel/mediasdk/plugins/libmfx_hevce_sw64.so
Type = 2
CodecID = HEVC
Default = 0
[HEVC_Encoder_87e0e80207375240852515cf4a5edde6]
GUID = 87e0e80207375240852515cf4a5edde6
PluginVersion = 1
APIVersion = 271
Path = /opt/intel/mediasdk/plugins/libmfx_h265fei_hw64.so
Type = 4
CodecID = HEVC
Default = 0
my OS is CentOS 7.1 and the cpu is Intel(R) Core(TM) i7-4700EQ CPU @ 2.40GHz,lspci can get this:
00:02.0 VGA compatible controller: Intel Corporation 4th Gen Core Processor Integrated Graphics Controller (rev 06)
Maybe i do something wrong in HEVC or SDK installation?could anyone help me?
Surbhi_M_Intel
Hi qin,
On Linux, we support only HEVC SW mode, the GUID for that is 15dd936825ad475ea34e34e35f3f54217a6, HEVC HW (Hybrid implementation for HSW and BDW) is not enabled as of now. There is nothing wrong with your install.
Surbhi
Surbhi_M_Intel
Hi qin,
Surbhi
qin_c_
SURBHI M. (Intel) wrote:
Hi qin,
Surbhi
one more thing:i ran HEVC decoder with 15dd936825ad475ea34e34e35f3f54217a6 and  got 25 fps for 1080P.But the <HEVC whitepaper> says that we can get more than 100fps on 1080P.is the Test in <HEVC whitepaper> working on HW mode?
./sample_decode_drm h265 -i blue_sky.h265 -o h265.yuv -sw -p 15dd936825ad475ea34e35f3f54217a6
Input video	HEVC
Frame rate	30.00
Memory type		system
MediaSDK impl		sw
Decoding started
Frame number:  217, fps: 24.931, fread_fps: 0.000, fwrite_fps: 27.74533
Decoding finished
plugin_loader.h :183 [INFO] MFXBaseUSER_UnLoad(session=0x0x7f277ab7a210), sts=0
Table 4B Decoding Speed of HD1080p on Intel® Media Server Studio HEVC Codec in TU1, TU4, TU7 modes
                TU1 Dec Speed          TU4 Dec Speed         TU7 Dec Speed
1  Park_joy       183.16                   205.53              232.34
Surbhi_M_Intel
Hi qin,
The reason of getting low fps in your experiments is due to writing the output out to a file, that's why we have a write fps and hence low fps overall. To know the actual performance of the underlying hw and SDK, it's best not to write the o/p to a file. Please remove the -o cmd and check the o/p on your system.
Did a quick run on 4th generation system, using ducks 1080p bitstream encoded at 10Mbps 30fps -
Input video     HEVC
Frame rate      30.00
Memory type             system
MediaSDK impl           hw
Decoding started
Frame number:  500, fps: 166.074, fread_fps: 0.000, fwrite_fps: 0.000
Surbhi
