I hope I am not missing something obvious, but I cannot get the H264 encoder to create a stream with open GOPs that has a SPS/PPS pair at everyGOP start as required by the Blu-Ray spec. Only the IDR frames are preceded bySPS/PPS. Is there a way/workaround other than creating only closed GOPs?
Markus
Markus
Hi Markus,
It is not possible to achieve this with MSDK 2012 Beta5 SW encoder and unfortunately it's too late to include a fix in the Gold release. We will add a fix in the MSDK 2012 Gold update. Meanwhile you may test this with HW Media SDK library for SandyBridge platform. It insert SPSPPS per each GOP/I frame.
Nina
Hi Markus,
Nina
