Hi All,
I try to set solid 30 fps in Intel H.264 Encoder:
mfxFrameInfo->FrameRateExtN = 30 and
mfxFrameInfo->FrameRateExtD = 1
But I could not have a solid encoder FPS as 30.
Do you have any good idea ?
Can you explain the problem you are having with more detail? Theres not enough information here to understand the problem you are having.
- Is the encoder not initializing when you set those values?
- Can you print out the all the other values that you are trying to initialize the encoder with?
We would be happy to help once we understand what you are experiencing.
Eric
Hi Eric,
As below fragments, I had try to assign the frame rate as 30 FPS, do I need more update ?
HRESULT CEncVideoFilter::CheckInputType(const CMediaType* mtIn)
mfxU32 nFrameRateExtN(0), nFrameRateExtD(0);
sts = ConvertFrameRate(m_pTimeManager->GetFrameRate(), &nFrameRateExtN, &nFrameRateExtD);
CHECK_NOT_EQUAL(sts, MFX_ERR_NONE, sts);
nFrameRateExtN = 30; // set FPS as 30
nFrameRateExtD = 1;
m_mfxParamsVideo.mfx.FrameInfo.FrameRateExtN = nFrameRateExtN;
m_mfxParamsVideo.mfx.FrameInfo.FrameRateExtD = nFrameRateExtD;
void CConfigPropPage::UpdateDialogControls( mfxU32 codecID
, int nPresetDlgCombobox
, int nTGUsageDlgCombobox
, int nBitrateItem
, int nBitrateSpinItem)
mfxU32 fcExtN(0), fcExtD(0);
ConvertFrameRate( (mfxF64)statistics.frame_rate / 100.0
, &fcExtN
, &fcExtD);
fcExtN = 30; // set FPS as 30
fcExtD = 1;
vParam.mfx.FrameInfo.FrameRateExtN = fcExtN;
vParam.mfx.FrameInfo.FrameRateExtD = fcExtD;
HRESULT CDecVideoFilter::CheckInputType(const CMediaType *mtIn)
if (nVideoInfoSize == mtIn->cbFormat || MFX_ERR_NONE != sts)
pmfx->FrameInfo.CropH = (mfxU16)vih2.bmiHeader.biHeight;
pmfx->FrameInfo.CropW = (mfxU16)vih2.bmiHeader.biWidth;
pmfx->FrameInfo.Width = (pmfx->FrameInfo.CropW + 15) &~ 15;
pmfx->FrameInfo.Height = (pmfx->FrameInfo.CropH + 31) &~ 31;
pmfx->FrameInfo.FourCC = MFX_FOURCC_NV12;
pmfx->FrameInfo.ChromaFormat = MFX_CHROMAFORMAT_YUV420;
m_mfxParamsVideo.IOPattern = MFX_IOPATTERN_OUT_SYSTEM_MEMORY;
&pmfx->FrameInfo.FrameRateExtN,
&pmfx->FrameInfo.FrameRateExtD);
pmfx->FrameInfo.FrameRateExtN = 30; // set FPS as 30
pmfx->FrameInfo.FrameRateExtD = 0;
nFrameRateExtD = 1;
, int nBitrateItem
, &fcExtN
, &fcExtD);
fcExtD = 1;
