Media (Intel® oneAPI Video Processing Library, Intel Media SDK)
Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
How to handle Decoder Errors.
sumit_j_1
Hi All,
I am getting an error from decode block of simple transcoder for my corrupted mpeg2 stream.
Errors are-MFX_ERR_LOCK_MEMORY,MFX_ERR_INCOMPATIBLE_VIDEO_PARAM,MFX_ERR_INVALID_VIDEO_PARAM.
I am currently resetting Decode by new extracted headers from bit stream to  removes MFX_ERR_LOCK_MEMORY error.
But same doesn't worked for others. In other words, for MFX_ERR_INCOMPATIBLE_VIDEO_PARAM error,  when i trying to reset decoder with new header  then  reset returns MFX_ERR_INVALID_VIDEO_PARAM.
Plz suggest how to handle this. Actually this decoder is a  part of my transcoder so do i need to do something for encoder also.
Sumit Jha
Bjoern_B_Intel
Hi Sumit,
Can you share your corrupted mpeg2 stream so I can replicate what you are seeing?
Bjoern
