How to handle Decoder Errors.
sumit_j_1
Hi All,
I am getting an error from decode block of simple transcoder for my corrupted mpeg2 stream.
Errors are-MFX_ERR_LOCK_MEMORY,MFX_ERR_INCOMPATIBLE_VIDEO_PARAM,MFX_ERR_INVALID_VIDEO_PARAM.
I am currently resetting Decode by new extracted headers from bit stream to  removes MFX_ERR_LOCK_MEMORY error.
But same doesn't worked for others. In other words, for MFX_ERR_INCOMPATIBLE_VIDEO_PARAM error,  when i trying to reset decoder with new header  then  reset returns MFX_ERR_INVALID_VIDEO_PARAM.
Plz suggest how to handle this. Actually this decoder is a  part of my transcoder so do i need to do something for encoder also.
Sumit Jha
Bjoern_B_Intel
Hi Sumit,
Can you share your corrupted mpeg2 stream so I can replicate what you are seeing?
Bjoern
