Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
How to test the samples?
Li__Desmond
Greetings from a beginner programmer, I've downloaded the samples and the codes are able to build and compile. As I've clicked the application (e.g sample_decode.exe), the console exits itself.
I wonder how I could test the samples where I've found the ones in "_bin/content" folder.
Mihail_P_
Run them from the console window (cmd.exe for example) You will see the output of the samples there.
Li__Desmond
Thanks. As I've input the parameters based on the examples from ReadMe PDFs (e.g sample_encode.exe h264 -i input.yuv -o output.h264 -w 720 -h 480 -hw
Errors showed up in the command prompt with:
[ERROR], sts=MFX_ERR_UNKNOWN(-1), CEncodingPipeline::GetFreeTask, m_TaskPool.SynchronizeFirstTask failed at src\pipeline_encode.cpp:1516
[ERROR], sts=MFX_ERR_UNKNOWN(-1), CEncodingPipeline::Run, m_pmfxENC->EncodeFrameAsync failed at src\pipeline_encode.cpp:1851
[ERROR], sts=MFX_ERR_UNKNOWN(-1), wmain, pPipeline->Run failed at src\sample_encode.cpp:1072
Frame number: 0
Encoding fps: -0
