How to use Intel HW Accelerators
Giri_b_
I followed the steps mentioned in the getting started guide for installing the Intel media server studio SDK.
Version used: MediaServerStudioEssentials2016.tar.gz
Here are details about system:
 x86_64 CPU op-mode(s): 32-bit, 64-bit
Model name: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz (SKYLAKE PROCESSOR)
Skylake PC
CentOS Linux release 7.1.1503
I checked few basic steps like :
uname –r
checked booted into the correct kernel or not.
lspci –nn | grep VGA
Checked if the Intel® Integrated Graphics
lsmod | grep i915
Checked if the i915 DRM module is installed
I find some problem while running vainfo as follow.
[skylake@localhost user]$ vainfo
error: failed to initialize display
Aborted (core dumped)
How to solve above problem, can any one please help me ..
Thanks&Regards,
Jeffrey_M_Intel1
The Media Server Studio 2016 downloadable today does not include 6th Generation Core (Skylake) support.  It is intended for  4th and 5th Generation (Haswell and Broadwell) systems.  If you'd like you can use the client release of Media SDK for Windows on 6th Generation Core machines to preview new hardware features.  While we don't have any timeline specifics for Linux yet, this forum is one of the best places to watch for announcements.
BTW, Media Server Studio only supports 64 bit.
Regards, Jeff
Giri_b_
Dear Jeffrey M,
Thank you very much,
I tried on 4th generation Haswell system,
i) my system details are as follows:
 - Intel(R) Core(TM) i7-4700MQ CPU @ 2.40GHz
 - Linux 7.1 version
 but still i am getting some issues like:
When i run vainfo , getting like:
1) [user@localhost ffmpeg-3.0]# vainfo
libva info: VA-API version 0.99.0
Xlib:  extension "XFree86-DRI" missing on display ":0".
libva info: va_getDriverName() returns -1
libva error: va_getDriverName() failed with unknown libva error,driver_name=(null)
vaInitialize failed with error code -1 (unknown libva error),exit
2) trying to decode using h264_qsv , getting like
[user@localhost ffmpeg-3.0]$ ./ffmpeg -i /home/xyz/tractor.264 -vcodec h264_qsv /home/xyz/out1.yuv
ffmpeg version 3.0 Copyright (c) 2000-2016 the FFmpeg developers
  built with gcc 4.8.5 (GCC) 20150623 (Red Hat 4.8.5-4)
  configuration: --enable-libmfx --enable-nonfree
  libavutil      55. 17.103 / 55. 17.103
  libavcodec     57. 24.102 / 57. 24.102
  libavformat    57. 25.100 / 57. 25.100
  libavdevice    57.  0.101 / 57.  0.101
  libavfilter     6. 31.100 /  6. 31.100
  libswscale      4.  0.100 /  4.  0.100
  libswresample   2.  0.101 /  2.  0.101
[h264 @ 0x23a6380] Stream #0: not enough frames to estimate rate; consider increasing probesize
Input #0, h264, from '/home/xyz/tractor.264':
  Duration: N/A, bitrate: N/A
    Stream #0:0: Video: h264 (High), yuv420p, 1280x720, 25 fps, 25 tbr, 1200k tbn, 50 tbc
[h264_qsv @ 0x245d4c0] mfx init: /dev/dri/renderD128 fd open failed
[h264_qsv @ 0x245d4c0] mfx init: /dev/dri/renderD129 fd open failed
[h264_qsv @ 0x245d4c0] mfx init: /dev/dri/renderD130 fd open failed
[h264_qsv @ 0x245d4c0] mfx init: /dev/dri/card0 vaInitialize failed
[h264_qsv @ 0x245d4c0] mfx init: /dev/dri/card1 fd open failed
[h264_qsv @ 0x245d4c0] mfx init: /dev/dri/card2 fd open failed
[h264_qsv @ 0x245d4c0] Selected ratecontrol mode is not supported by the QSV runtime. Choose a different mode.
Output #0, rawvideo, to '/home/xyz/out1.yuv':
    Stream #0:0: Video: h264, none, q=2-31, 128 kb/s, 25 fps
    Metadata:
      encoder         : Lavc57.24.102 h264_qsv
Stream mapping:
  Stream #0:0 -> #0:0 (h264 (native) -> h264 (h264_qsv))
Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
can you please help me regarding above issues.
Giri.
Giri_b_
* Linux CentOS 7.1 version
Giri_b_
one thing I forgot to mentioned that:
Installing CentOS 7.1 in VM Ware Workstation 11.1.0
HSW system, Intel(R) Core(TM) i7-4700MQ CPU @ 2.40GHz
Jeffrey_M_Intel1
Just closing out this thread.  As Surbhi mentioned here, VMWare workstation isn't a supported form of virtualization.  For more on virtualization support see https://software.intel.com/en-us/articles/how-to-setup-media-server-studio-r6-on-vt-d.
Bo_M_
hi,
I find the same problem.
Version used: MediaServerStudioEssentials2017.tar.gz
[test@localhost ~]$ vainfo
error: can't connect to X server!
system :
 Intel(R) Xeon(R) CPU E5-2640 v4 @ 2.40GHz
[test@localhost ~]$ lspci -nn -s 0:02.0
00:02.0 PCI bridge [0604]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D PCI Express Root Port 2 [8086:6f04] (rev 01)
OS:CentOS 7.2 1511
Does not My system  support Media Server Studio 2017 R1?
