How to use the Media SDK Tracer on Linux ?
Robby_S
Greetings, I have a question on how to use the Media SDK Tracer on Linux. All the documents and Q/A's I found so far seem to be for the Windows version.
My platform is MSS SDK 2015R6 on CentOS 7.1 (kernel-3.10.0-229.1.2.39163.MSSr4.el7.centos.x86_64) . I tried to follow the file /opt/intel/mediasdk/tools/tracer/README, like this:
1) cd /opt/intel/mediasdk/lib64
2) rm libmfxhw64.so
3) ln -s /opt/intel/mediasdk/tools/tracer/libmfx-tracer.so libmfxhw64.so
4) cd /opt/intel/mediasdk/tools/tracer
5) ./mfx-tracer-config core.type file core.log  /myplace/mfxtracer.log
6) cd /myplace
7) make clean; make;
8) ./my_code
I was expecting to see mfxtracer.log generated in the directory /myplace, but I didn't see it. I repeated the steps above, using the relative path in 3). Still no log file was generated.
What am I missing?
Robby
Surbhi_M_Intel
Hi Robby,
So I am able to successfully generate the tracer file with existing tracer. I did the experiment on a Broadwell system and same mechanism will work on the rest of supported hardware as well. I am following the readme present in tracer tool with small changes according to the latest version and here is the step by step procedure -
Step1
cd /opt/intel/mediasdk/lib64/
rm libmfxhw64.so
mv libmfxhw64-p.so.1.16 libmfxhw64-p-REAL.so.1.16
Step 2-
export LD_LIBRARY_PATH=/opt/intel/mediasdk/tools/tracer:$LD_LIBRARY_PATH
Step3
cd /opt/intel/mediasdk/tools/tracer/
ln -s libmfx-tracer.so libmfxhw64.so
Step4 –
/opt/intel/mediasdk/tools/tracer/mfx-tracer-config --default
/opt/intel/mediasdk/tools/tracer/mfx-tracer-config core.type file
/opt/intel/mediasdk/tools/tracer/mfx-tracer-config core.log ~/mfxtracer.log
/opt/intel/mediasdk/tools/tracer/mfx-tracer-config core.lib /opt/intel/mediasdk/lib64/libmfxhw64-p-REAL.so.1.16
Step5 -
Run the sample application and you will see the output in the folder with above steps.
./sample_decode_drm h264 -i content/test_stream.264 -o out
Hope this will help you! If not then please let me know your exact configuration, I can try on that and we can check if the libraries are present and linkers are set properly on your system.
Surbhi
Robby_S
Hi, could someone help me with this question? Without the tracer, I have to put a lot of msdk_printf() in my code to debug, which is messy, insufficient, and (I believe) not thread-safe. Thanks!
-Robby
Surbhi_M_Intel
Hi Robby,
Similar issue got reported by another customer as well and we have a CQ open for it.
We don't have workaround for this right, will get back to you as soon as I have some information.
For us to to debug- Are you seeing this for particular application because issue got reported only when doing multiple transcode and work in all another scenario.
Surbhi
Robby_S
Hi Surbhi, thanks for telling me that someone else also reported the problem with the tracer. However, in my case, it does not work at all. I tried running the sample_decode as well as my own code. None generated the tracer log file. Do I need to build the code with some specific options?
-Robby
Surbhi_M_Intel
Hi Robby,
Step1
rm libmfxhw64.so
Step 2-
Step3
Step4 –
Step5 -
Surbhi
Robby_S
Hi Surbhi, thanks for the feedback. Comparing your steps with mine, I can see that I did not set the environment variable LD_LIBRARY_PATH. That should be the cause.
I'll test with your steps, and if they work, I'll update here.
[ I probably sub-consciously neglected LD_LIBRARY_PATH as I've heard some negative comments about it. Guess I might have just proven those points. ;-)  ]
Update:
Following the steps you listed, I was able to generate the tracer log file. Thanks!
