Hyper Encode not supported
ShiYue
Help me!
It's aways returned MFX_ERR_INVALID_VIDEO_PARAM with mfxExtHyperModeParam,
auto ret = MFXVideoENCODE_Init(m_session, par);
I can't use hyper encode on my computer.
there is my computer info:
Labels (3)
AlekhyaV_Intel
Thank you for posting in Intel Communities. We would like to have some information from your end to resolve your issue.
1) OS details & Processor details
2) Did you make any modifications to already available code? Please attach the code.
3) Did you follow this documentation? If not, please try all the steps and see if the issue still persists. https://github.com/oneapi-src/oneVPL-intel-gpu/blob/main/doc/HyperEncode_FeatureDeveloperGuide.md
Alekhya
AlekhyaV_Intel
Please give us an update regarding this issue.
Alekhya
ShiYue
I read the source code of the sample_encode. I compared the code and found that I didn't set accelerationMode. I set the parameter accelerationMode to MFX_ACCEL_MODE_VIA_D3D11, and everything is normal. So I think it may be caused by this parameter.However, it seems that hevc still does not support hyperencode.
AlekhyaV_Intel
We are working on this internally. We will get back to you soon with an update.
Alekhya
AlekhyaV_Intel
We got an update from the admin team. Hyper Encode supports HEVC. However, a very well-known issue with our API is that it is very picky about parameters.
Please follow the command line given in the documentation(https://github.com/oneapi-src/oneVPL-intel-gpu/blob/main/doc/HyperEncode_FeatureDeveloperGuide.md#running-sample_encode-with-onevpl-runtime) for Hyper Encode. sample_encode command line with the given parameters is known to work.
Alekhya
ShiYue
I tried the following three sample_encode command line, only sample_encode command line with h265 return not supported.
./sample_encode av1 -i input.yuv -o output.h264 -dGfx -dual_gfx::on -w 1920 -h 1080 -nv12 -idr_interval 0 -d3d11 -async 30 -g 30 -r 1 -u 4 -lowpower:on -perf_opt 10 -n 2000
./sample_encode h264 -i input.yuv -o output.h264 -dGfx -dual_gfx::on -w 1920 -h 1080 -nv12 -idr_interval 0 -d3d11 -async 30 -g 30 -r 1 -u 4 -lowpower:on -perf_opt 10 -n 2000
./sample_encode h265 -i input.yuv -o output.h264 -dGfx -dual_gfx::on -w 1920 -h 1080 -nv12 -idr_interval 0 -d3d11 -async 30 -g 30 -r 1 -u 4 -lowpower:on -perf_opt 10 -n 2000
The following pictures are the test results, and the attachment is my computer information:
ShiYue
I also found some problems on my computer, using "-dGfx" with the following command.
The occupancy rate of the integrated graphics card is about 100%, and the occupancy rate of the discrete graphics card is about 30%.
When I change "-dualgfx::on" to "-dualgfx::off"(the Hyper Encode is turned off) ,  will only occupy the discrete graphics card and faster than Hyper Encode on, because the discrete graphics card is more efficient
how can I make the discrete graphics card the main adapter?
I'm sorry my English is not very good, can you give me some advice if you can understand my description.
ShiYue
I mean using a discrete graphics card is faster than turning on Hyper Encode
roy5
Thanks for your patience. We investigated this case and here is my response:
Currently, in the sample_encode example, "-idr_interval 0" is not supported by HEVC Hyper Encode. Please try the following command instead:
./sample_encode h265 -i input.yuv -o output.h264 -dGfx -dual_gfx::on -w 1920 -h 1080 -nv12 -idr_interval 1 -d3d11 -async 30 -g 30 -r 1 -u 4 -lowpower:on -perf_opt 10 -n 2000
Rupak
