Access community support with transcoding, decoding, and encoding in applications using media tools from Intel. This includes Intel® oneAPI Video Processing Library and Intel® Media SDK.
2965 Discussions
I can't run the sample_camera which is one of the samples of MediaSDK with the argb16 input format
yue_c_
i run the sample_camera with the command line , the params :
sample_camera_d.exe -i camera\single\b_ff.argb16 -f argb16 -w 1280 -h 720 -o camera\single\out_b_ff_16_n_
i use the argb16 format as input, then i get the error info:
Return on error: error code -3, d:\program_project\mediasdk_samples_git\samples-
f7b203bc2e5d601079721aca3508522ce025e1c5\samples\sample_camera\src\pipeline_came
ra.cpp  1053
Return on error: error code 1,  d:\program_project\mediasdk_samples_git\samples-
f7b203bc2e5d601079721aca3508522ce025e1c5\samples\sample_camera\src\sample_camera
.cpp    625
when i use the bayer file as input ,the sample can run successfully.
the command line:sample_camera_d.exe -i camera\single\test_RAW14.bin -f rggb -w 5494 -h 4114 -b 14 -o camera\single\out_test_RAW14_
result:
Input format    R16
Resolution      5504x4128
Crop X,Y,W,H    0,0,5494,4114
Frame rate      24.00
Output format   RGB4
Frame rate      24.00
Input memory type               system
Output memory type              d3d
MediaSDK impl           hw
MediaSDK version        1.19
Camera pipe started
Total frames 1
Total time   1.59 sec
Total FPS    0.63 fps
Camera pipe finished
sample version:2016 6.0.0.142   OS:win7 64bit    VS2015
Does this sample support argb16 input?
Could someone help me with this problem?
yue_c_
i still havn't solved this problem...
