I'd like to decode RTP H.264 video stream with Media SDK.
But installation of Media SDK is failed.
Download libva, libva-utils, Gmmlib, media-driver and MediaSDK from github.
Build and install with gcc 8.3.1(devtoolset-8).
libva: https://github.com/intel/libva/releases/tag/2.7.0
libva-utils: https://github.com/intel/libva-utils/releases/tag/2.7.1
Gmmlib: https://github.com/intel/gmmlib/releases/tag/intel-gmmlib-20.1.1
Driver: https://github.com/intel/media-driver/releases/tag/intel-media-20.1.1
Media SDK and Samples: https://github.com/Intel-Media-SDK/MediaSDK/releases/tag/intel-mediasdk-20.1.0
Run vainfo.
# vainfo
error: XDG_RUNTIME_DIR not set in the environment.
error: can't connect to X server!
libva info: VA-API version 1.7.0
libva info: User environment variable requested driver 'iHD'
libva info: Trying to open /usr/local/lib/dri/iHD_drv_video.so
libva info: Found init function __vaDriverInit_1_7
DRM_IOCTL_I915_GEM_APERTURE failed: Invalid argument
Assuming 131072kB available aperture size.
May lead to reduced performance or incorrect rendering.
get chip id failed: -1 [22]
param: 4, val: 0
libva error: /usr/local/lib/dri/iHD_drv_video.so init failed
libva info: va_openDriver() returns 18
vaInitialize failed with error code 18 (invalid parameter),exit
Run vainfo with option "--display drm --device /dev/dri/renderD129" for all of /dev/dri/*.
As a result, it was same error message.
I made following code to initialize.
But device files are not found.
int open_intel_adapter()
std::string adapterPath = "/dev/dri/renderD";
char driverName[5] = {};
mfxU32 nodeIndex = 128;
for (mfxU32 i = 0; i < 16; ++i) {
std::string curAdapterPath = adapterPath + std::to_string(nodeIndex + i);
int fd = open(curAdapterPath.c_str(), O_RDWR);
if (fd < 0) continue;
drm_version_t version = {};
version.name_len = 32;
version.name = driverName;
ioctl(fd, DRM_IOWR(0, drm_version), &version);
if(!strcmp(driverName, "i915")) return fd;
close(fd);
return -1;
My Environment is;
OS
CentOS Linux release 7.6.1810
CPU
Intel(R) Core(TM) i7-6800K CPU @ 3.40GHz
GPU
NVIDIA GeForce GTX 1080
NVIDIA gfx driver is installed.
NVRM version: NVIDIA UNIX x86_64 Kernel Module 450.80.02 Wed Sep 23 01:13:39 UTC 2020
NVIDIA gfx driver is disabled as follows.
# sudo mv /boot/initramfs-$(uname -r).img /boot/initramfs-$(uname -r)-nouveau.img
# sudo dracut --force --omit-drivers nouveau /boot/initramfs-$(uname -r).img $(uname -r)
# echo "blacklist nouveau" | sudo tee /etc/modprobe.d/modprobe.conf
# echo "blacklist nouveau" | sudo tee /etc/modprobe.d/nouveau-blacklist.conf
DRI
# ls /dev/dri
card0 card1 renderD128 renderD129
# cat /sys/kernel/debug/dri/*/name
nvidia-drm dev=0000:03:00.0 unique=0000:03:00.0
nvidia-drm dev=0000:04:00.0 unique=0000:04:00.0
Could you tell me why intel gfx driver is not found?
I plan to try another PC. CPU of that PC is Intel(R) Xeon(R) W-2133 CPU @ 3.60GHz.
Does Media SDK support Xeon W-2133?
Xeon Processors:
For Media SDK, we must make sure “Quick Sync” is included in the integrated GPU. So Xeon W-2133 will not work. We only include GPU in Xeon E3.
i7-6800K should be ok but if Nvidia's GPU takes the primary position, the integrated GPU might not be accessible. Please go through below links:
- https://github.com/Intel-Media-SDK/MediaSDK/issues/167
- https://github.com/Intel-Media-SDK/MediaSDK/issues/1067
- https://github.com/Intel-Media-SDK/MediaSDK/issues/2477
Jaideep
We are investigating your issue at our end and we will get back to you soon.
Jaideep
Xeon Processors:
Jaideep
Thank you for your reply.
Please close this.
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
