Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
3058 Discussions
IMSDK 2017 sample applications fails in initialization
Thushara_Jayakumar
Hi ,
I have installed IMSDK 2017 in my Intel Apollo Lake platform. When I am trying to run the media sdk sample application using the prebuilt binaries, I am getting the following error:
[ERROR], sts=MFX_ERR_MEMORY_ALLOC(-4), CreateAllocator, CreateHWDevice failed at /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK1/git/mdp_msdk-samples/samples/sample_decode/src/pipeline_decode.cpp:1195
[ERROR], sts=MFX_ERR_MEMORY_ALLOC(-4), Init, CreateAllocator failed at /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK1/git/mdp_msdk-samples/samples/sample_decode/src/pipeline_decode.cpp:405
[ERROR], sts=MFX_ERR_MEMORY_ALLOC(-4), main, Pipeline.Init failed at /home/lab_msdk/buildAgentDir/buildAgent_MediaSDK1/git/mdp_msdk-samples/samples/sample_decode/src/sample_decode.cpp:666
I have tried to run the following command:
/opt/intel/mediasdk/samples/_bin/x64/sample_decode h264 -i in.264 -o out.yuv
SDK and sample applications details are as below:
SDK, version 7.0.16073598
Samples, version 7.0.16073598
VA-API version 0.99.0
Please let me know if I am missing something here.
Thushara Jayakumar
Thushara_Jayakumar
I was able to fix this issue. In my image the iHD_drv_video.so library was present in /usr/lib. As the va_openDriver()  tries to locate this library in  /usr/lib/media-libva/ (which is the LIBVA_DRIVERS_PATH env set), it was failing.
Now I am able to execute the binary properly
Thushara
