Hi, Experts
I tested MSDK 2012 for H264 video decoding using HW acclerate.
one channel(1080P) is everything goes well using sample_video_wal.bat file.
My test environments are as following:
- OS: 32bit
- Processor:Intel Core(TM) i5-2400 CPU @3.10GHz
- RAM: 4G(3.41GB available)
CPU's occupancy is less than 1%, GPU MFX is less than 20% and the virtual memory space is less than 70M.
But CPU's occupancy is less than 10%, GPU MFX and virtual memory space is same above.
Also, I tested multi-channels H264 video decoding using sample_video_wal.bat file.
I saw that GPU General's occupany is 95% and H264 decoder's speed is decreased in case of 16 channels.
However, I have a change MSDK source due to decoding H264 bitstream from incoming IP camera.
In one cannel, CPU's occupancy is less than 1%, GPU MFX is less than 7% and the virtual memory space is less than 140M.
In 4 channels, CPU's occupancy is less than 30%, GPU MFX is less than 30% and the virtual memory space is less than 600M.
Experimental results are really odd.
one channel decoding performance excellent, but the CPU and virtual memory size is increasing on decoding.
Anybody explain the reasions?
Best regards
nrson
As more of the hardware accelerated resources are consumed, the CPU must wait for resources to become available and must spend more time checking to see if hardware can process more tasks. In general, the hardware acceleration is optimized to play a single stream with minimal CPU usage.
Hi, Tony
Thank for your reply and I am sorry My english skill is poor.
I think that sample_video_wal.bat file executes like as multi-channel(4, 8, 16, etc) and my source is executed like as bat file.
But test results are odds as above post.
Also I have traced using "Intel Media SDK Tracer V3.0" and next following contests are trace results.
The first is sample test and the other is my source which is rewrited to resize of resolution using VPP.
My trace results show that AsyncDepth is 0, mfxSTATUS MAP's number is much and SyncOperation(D) is o of Unique Surfaces.
Where is the wrong? would you explain it?
best regards,
nrson
1. sample_decode.exe h264 -hw -d3d -i xxx.264 -r
INFO :minAPIVersion(32767.32767) > maxAPIVersion(1.2), minAPIVersion lowered to (1.2)
INFO :MFXInit(MFX_IMPL_HARDWARE|MFX_IMPL_VIA_D3D9,ver=1.1,session=0x001E8800)
INFO :library loaded succesfully
MFXQueryVersion.ver=0.512
INFO :MFXQueryVersion returned: 0, cannot load plugins
SDK DLL File Version=3.13.7.15
SDK DLL Product Version=3.5.28353.61248
SDK DLL File Size=13086080
MFXInit.impl=HARDWARE|VIA_D3D9
MFXInit.ver=1.1
MFXInit.status=MFX_ERR_NONE
MFXQueryVersion.ver=1.4
MFXQueryIMPL.impl=HARDWARE|VIA_D3D9
core.SetHandle.status=MFX_ERR_NONE
core.SetFrameAllocator.status=MFX_ERR_NONE
decode.DecodeHeader.bs(in).DecodeTimeStamp=0x0
decode.DecodeHeader.bs(in).TimeStamp=0x0
decode.DecodeHeader.bs(in).DataOffset=0
decode.DecodeHeader.bs(in).DataLength=0
decode.DecodeHeader.bs(in).MaxLength=1048576
decode.DecodeHeader.bs(in).PicStruct=UNKNOWN(0)
decode.DecodeHeader.bs(in).FrameType=UNKNOWN(0)
decode.DecodeHeader.bs(in).DataFlag=0x0
decode.DecodeHeader.bs(in).NumExtParam=0
decode.DecodeHeader.bs(out).DecodeTimeStamp=0x0
decode.DecodeHeader.bs(out).TimeStamp=0x0
decode.DecodeHeader.bs(out).DataOffset=0
decode.DecodeHeader.bs(out).DataLength=0
decode.DecodeHeader.bs(out).MaxLength=1048576
decode.DecodeHeader.bs(out).PicStruct=UNKNOWN(0)
decode.DecodeHeader.bs(out).FrameType=UNKNOWN(0)
decode.DecodeHeader.bs(out).DataFlag=0x0
decode.DecodeHeader.bs(out).NumExtParam=0
decode.DecodeHeader.par.AsyncDepth=0
decode.DecodeHeader.par.mfx.BRCParamMultiplier=0
decode.DecodeHeader.par.mfx.FrameInfo.FourCC=0x0
decode.DecodeHeader.par.mfx.FrameInfo.Resolution=(0,0)
decode.DecodeHeader.par.mfx.FrameInfo.Crop=(0,0,0,0)
decode.DecodeHeader.par.mfx.FrameInfo.FrameRate=0/0
decode.DecodeHeader.par.mfx.FrameInfo.AspectRatio=0:0
decode.DecodeHeader.par.mfx.FrameInfo.PicStruct=UNKNOWN(0)
decode.DecodeHeader.par.mfx.FrameInfo.ChromaFormat=MONO
decode.DecodeHeader.par.mfx.CodecId=AVC
decode.DecodeHeader.par.mfx.CodecProfile=0
decode.DecodeHeader.par.mfx.CodecLevel=0
decode.DecodeHeader.par.mfx.NumThread=0
decode.DecodeHeader.par.mfx.SliceGroupsPresent=0
decode.DecodeHeader.par.mfx.DecodedOrder=0
decode.DecodeHeader.par.mfx.ExtendedPicStruct=0
decode.DecodeHeader.par.mfx.TimeStampCalc=UNKNOWN
decode.DecodeHeader.par.Protected=0
decode.DecodeHeader.par.IOPattern=UNKNOWN(0)
decode.DecodeHeader.par.NumExtParam=0
decode.DecodeHeader.par.ExtParam=NULL
decode.DecodeHeader.status=MFX_ERR_MORE_DATA
decode.DecodeHeader.bs(in).DataLength=1048576
decode.DecodeHeader.bs(out).DataOffset=650
decode.DecodeHeader.bs(out).DataLength=1047926
decode.DecodeHeader.par.mfx.FrameInfo.FourCC=NV12
decode.DecodeHeader.par.mfx.FrameInfo.Resolution=(1920,1088)
decode.DecodeHeader.par.mfx.FrameInfo.Crop=(0,0,1920,1080)
decode.DecodeHeader.par.mfx.FrameInfo.FrameRate=5000000/208542
decode.DecodeHeader.par.mfx.FrameInfo.PicStruct=PROGRESSIVE
decode.DecodeHeader.par.mfx.FrameInfo.ChromaFormat=4:2:0
decode.DecodeHeader.par.mfx.CodecProfile=100
decode.DecodeHeader.par.mfx.CodecLevel=41
decode.DecodeHeader.status=MFX_ERR_NONE
decode.Query.in.AsyncDepth=1
decode.Query.in.mfx.BRCParamMultiplier=0
decode.Query.in.mfx.FrameInfo.FourCC=NV12
decode.Query.in.mfx.FrameInfo.Resolution=(1920,1088)
decode.Query.in.mfx.FrameInfo.Crop=(0,0,1920,1080)
decode.Query.in.mfx.FrameInfo.FrameRate=5000000/208542
decode.Query.in.mfx.FrameInfo.AspectRatio=0:0
decode.Query.in.mfx.FrameInfo.PicStruct=PROGRESSIVE
decode.Query.in.mfx.FrameInfo.ChromaFormat=4:2:0
decode.Query.in.mfx.CodecId=AVC
decode.Query.in.mfx.CodecProfile=100
decode.Query.in.mfx.CodecLevel=41
decode.Query.in.mfx.NumThread=0
decode.Query.in.mfx.SliceGroupsPresent=0
decode.Query.in.mfx.DecodedOrder=0
decode.Query.in.mfx.ExtendedPicStruct=0
decode.Query.in.mfx.TimeStampCalc=UNKNOWN
decode.Query.in.Protected=0
decode.Query.in.IOPattern=OUT_VIDEO_MEMORY
decode.Query.in.NumExtParam=0
decode.Query.in.ExtParam=NULL
decode.Query.out.AsyncDepth=1
decode.Query.out.mfx.BRCParamMultiplier=0
decode.Query.out.mfx.FrameInfo.FourCC=NV12
decode.Query.out.mfx.FrameInfo.Resolution=(1920,1088)
decode.Query.out.mfx.FrameInfo.Crop=(0,0,0,0)
decode.Query.out.mfx.FrameInfo.FrameRate=5000000/208542
decode.Query.out.mfx.FrameInfo.AspectRatio=0:0
decode.Query.out.mfx.FrameInfo.PicStruct=PROGRESSIVE
decode.Query.out.mfx.FrameInfo.ChromaFormat=4:2:0
decode.Query.out.mfx.CodecId=AVC
decode.Query.out.mfx.CodecProfile=100
decode.Query.out.mfx.CodecLevel=41
decode.Query.out.mfx.NumThread=0
decode.Query.out.mfx.SliceGroupsPresent=0
decode.Query.out.mfx.DecodedOrder=0
decode.Query.out.mfx.ExtendedPicStruct=0
decode.Query.out.mfx.TimeStampCalc=UNKNOWN
decode.Query.out.Protected=0
decode.Query.out.IOPattern=OUT_VIDEO_MEMORY
decode.Query.out.NumExtParam=0
decode.Query.out.ExtParam=NULL
decode.Query.status=MFX_ERR_NONE
decode.QueryIOSurf.par.AsyncDepth=1
decode.QueryIOSurf.par.mfx.BRCParamMultiplier=0
decode.QueryIOSurf.par.mfx.FrameInfo.FourCC=NV12
decode.QueryIOSurf.par.mfx.FrameInfo.Resolution=(1920,1088)
decode.QueryIOSurf.par.mfx.FrameInfo.Crop=(0,0,0,0)
decode.QueryIOSurf.par.mfx.FrameInfo.FrameRate=5000000/208542
decode.QueryIOSurf.par.mfx.FrameInfo.AspectRatio=0:0
decode.QueryIOSurf.par.mfx.FrameInfo.PicStruct=PROGRESSIVE
decode.QueryIOSurf.par.mfx.FrameInfo.ChromaFormat=4:2:0
decode.QueryIOSurf.par.mfx.CodecId=AVC
decode.QueryIOSurf.par.mfx.CodecProfile=100
decode.QueryIOSurf.par.mfx.CodecLevel=41
decode.QueryIOSurf.par.mfx.NumThread=0
decode.QueryIOSurf.par.mfx.SliceGroupsPresent=0
decode.QueryIOSurf.par.mfx.DecodedOrder=0
decode.QueryIOSurf.par.mfx.ExtendedPicStruct=0
decode.QueryIOSurf.par.mfx.TimeStampCalc=UNKNOWN
decode.QueryIOSurf.par.Protected=0
decode.QueryIOSurf.par.IOPattern=OUT_VIDEO_MEMORY
decode.QueryIOSurf.par.NumExtParam=0
decode.QueryIOSurf.par.ExtParam=NULL
decode.QueryIOSurf.request.Info.FourCC=NV12
decode.QueryIOSurf.request.Info.Resolution=(1920,1088)
decode.QueryIOSurf.request.Info.Crop=(0,0,0,0)
decode.QueryIOSurf.request.Info.FrameRate=5000000/208542
decode.QueryIOSurf.request.Info.AspectRatio=0:0
decode.QueryIOSurf.request.Info.PicStruct=PROGRESSIVE
decode.QueryIOSurf.request.Info.ChromaFormat=4:2:0
decode.QueryIOSurf.request.Type=DXVA2_DECODER_TARGET|FROM_DECODE|EXTERNAL_FRAME
decode.QueryIOSurf.request.NumFrameMin=6
decode.QueryIOSurf.request.NumFrameSuggested=6
decode.QueryIOSurf.status=MFX_ERR_NONE
decode.Init.par.AsyncDepth=1
decode.Init.par.mfx.BRCParamMultiplier=0
decode.Init.par.mfx.FrameInfo.FourCC=NV12
decode.Init.par.mfx.FrameInfo.Resolution=(1920,1088)
decode.Init.par.mfx.FrameInfo.Crop=(0,0,0,0)
decode.Init.par.mfx.FrameInfo.FrameRate=5000000/208542
decode.Init.par.mfx.FrameInfo.AspectRatio=0:0
decode.Init.par.mfx.FrameInfo.PicStruct=PROGRESSIVE
decode.Init.par.mfx.FrameInfo.ChromaFormat=4:2:0
decode.Init.par.mfx.CodecId=AVC
decode.Init.par.mfx.CodecProfile=100
decode.Init.par.mfx.CodecLevel=41
decode.Init.par.mfx.NumThread=0
decode.Init.par.mfx.SliceGroupsPresent=0
decode.Init.par.mfx.DecodedOrder=0
decode.Init.par.mfx.ExtendedPicStruct=0
decode.Init.par.mfx.TimeStampCalc=UNKNOWN
decode.Init.par.Protected=0
decode.Init.par.IOPattern=OUT_VIDEO_MEMORY
decode.Init.par.NumExtParam=0
decode.Init.par.ExtParam=NULL
core.FrameAllocator.Alloc.request.Info.FourCC=NV12
core.FrameAllocator.Alloc.request.Info.Resolution=(1920,1088)
core.FrameAllocator.Alloc.request.Info.Crop=(0,0,0,0)
core.FrameAllocator.Alloc.request.Info.FrameRate=5000000/208542
core.FrameAllocator.Alloc.request.Info.AspectRatio=0:0
core.FrameAllocator.Alloc.request.Info.PicStruct=PROGRESSIVE
core.FrameAllocator.Alloc.request.Info.ChromaFormat=4:2:0
core.FrameAllocator.Alloc.request.Type=DXVA2_DECODER_TARGET|FROM_DECODE|EXTERNAL_FRAME
core.FrameAllocator.Alloc.request.NumFrameMin=6
core.FrameAllocator.Alloc.request.NumFrameSuggested=6
core.FrameAllocator.Alloc.response.NumFrameActual=6
core.FrameAllocator.Alloc.status=MFX_ERR_NONE
decode.Init.status=MFX_ERR_NONE
core.FrameAllocator.Alloc.request.Type=DXVA2_DECODER_TARGET|SYSTEM_MEMORY|FROM_DECODE|EXTERNAL_FRAME
decode.NumExternalFrames=6
core.FrameAllocator.Free.status=MFX_ERR_NONE
=====mfxSTATUS MAP=====
DecodeFrameAsync: EXTERNAL : MFX_ERR_MORE_SURFACE (8)
DecodeFrameAsync: EXTERNAL : MFX_ERR_MORE_DATA (10)
DecodeFrameAsync: EXTERNAL : MFX_ERR_NONE (550)
DecodeFrameAsync: EXTERNAL : MFX_WRN_VIDEO_PARAM_CHANGED (3)
SyncOperation(D): EXTERNAL : MFX_ERR_NONE (550)
====Unique Surfaces====
DecodeFrameAsync : 6
SyncOperation(D) : 6
RunFrameVPPAsync(IN) : 0
RunFrameVPPAsync(OUT) : 0
SyncOperation(VPP_IN) : 0
SyncOperation(VPP_OUT): 0
EncodeFrameAsync : 0
SyncOperation(E) : 0
SDK_ANALYZER unloaded: C:\Program Files\Intel\Media SDK 2014 for Clients\tools\mediasdk_tracer\tracer_core32.dll
2. my souce using trace results
INFO :MFXInit(MFX_IMPL_HARDWARE|MFX_IMPL_VIA_D3D9,ver=1.1,session=0x000CEBB8)
MFXQueryVersion.ver=0.0
MFXInit.ver=1.1
decode.DecodeHeader.bs(in).DataLength=102481
decode.DecodeHeader.bs(in).MaxLength=4194304
decode.DecodeHeader.bs(out).DataLength=102481
decode.DecodeHeader.bs(out).MaxLength=4194304
decode.DecodeHeader.par.mfx.FrameInfo.FrameRate=30000/2002
decode.DecodeHeader.par.mfx.FrameInfo.AspectRatio=1:1
decode.DecodeHeader.par.mfx.CodecProfile=77
decode.DecodeHeader.par.mfx.CodecLevel=40
decode.DecodeHeader.par.IOPattern=IN_SYSTEM_MEMORY|OUT_SYSTEM_MEMORY
decode.QueryIOSurf.par.AsyncDepth=0
decode.QueryIOSurf.par.mfx.FrameInfo.Crop=(0,0,1920,1080)
decode.QueryIOSurf.par.mfx.FrameInfo.FrameRate=30000/2002
decode.QueryIOSurf.par.mfx.FrameInfo.AspectRatio=1:1
decode.QueryIOSurf.par.mfx.CodecProfile=77
decode.QueryIOSurf.par.mfx.CodecLevel=40
decode.QueryIOSurf.par.IOPattern=IN_SYSTEM_MEMORY|OUT_SYSTEM_MEMORY
decode.QueryIOSurf.request.Info.Crop=(0,0,1920,1080)
decode.QueryIOSurf.request.Info.FrameRate=30000/2002
decode.QueryIOSurf.request.Info.AspectRatio=1:1
decode.QueryIOSurf.request.Type=SYSTEM_MEMORY|FROM_DECODE|EXTERNAL_FRAME
decode.QueryIOSurf.request.NumFrameMin=4
decode.QueryIOSurf.request.NumFrameSuggested=4
vpp.QueryIOSurf.par.AsyncDepth=0
vpp.QueryIOSurf.par.vpp.In.FourCC=NV12
vpp.QueryIOSurf.par.vpp.In.Resolution=(1920,1088)
vpp.QueryIOSurf.par.vpp.In.Crop=(0,0,1920,1080)
vpp.QueryIOSurf.par.vpp.In.FrameRate=30000/2002
vpp.QueryIOSurf.par.vpp.In.AspectRatio=1:1
vpp.QueryIOSurf.par.vpp.In.PicStruct=PROGRESSIVE
vpp.QueryIOSurf.par.vpp.In.ChromaFormat=4:2:0
vpp.QueryIOSurf.par.vpp.Out.FourCC=NV12
vpp.QueryIOSurf.par.vpp.Out.Resolution=(960,544)
vpp.QueryIOSurf.par.vpp.Out.Crop=(0,0,960,540)
vpp.QueryIOSurf.par.vpp.Out.FrameRate=30/1
vpp.QueryIOSurf.par.vpp.Out.AspectRatio=1:1
vpp.QueryIOSurf.par.vpp.Out.PicStruct=PROGRESSIVE
vpp.QueryIOSurf.par.vpp.Out.ChromaFormat=4:2:0
vpp.QueryIOSurf.par.Protected=0
vpp.QueryIOSurf.par.IOPattern=IN_SYSTEM_MEMORY|OUT_SYSTEM_MEMORY
vpp.QueryIOSurf.par.NumExtParam=0
vpp.QueryIOSurf.par.ExtParam=NULL
vpp.QueryIOSurf.request[0].Info.FourCC=NV12
vpp.QueryIOSurf.request[0].Info.Resolution=(1920,1088)
vpp.QueryIOSurf.request[0].Info.Crop=(0,0,1920,1080)
vpp.QueryIOSurf.request[0].Info.FrameRate=30000/2002
vpp.QueryIOSurf.request[0].Info.AspectRatio=1:1
vpp.QueryIOSurf.request[0].Info.PicStruct=PROGRESSIVE
vpp.QueryIOSurf.request[0].Info.ChromaFormat=4:2:0
vpp.QueryIOSurf.request[0].Type=SYSTEM_MEMORY|FROM_VPPIN|EXTERNAL_FRAME
vpp.QueryIOSurf.request[0].NumFrameMin=7
vpp.QueryIOSurf.request[0].NumFrameSuggested=7
vpp.QueryIOSurf.request[1].Info.FourCC=NV12
vpp.QueryIOSurf.request[1].Info.Resolution=(960,544)
vpp.QueryIOSurf.request[1].Info.Crop=(0,0,960,540)
vpp.QueryIOSurf.request[1].Info.FrameRate=30/1
vpp.QueryIOSurf.request[1].Info.AspectRatio=1:1
vpp.QueryIOSurf.request[1].Info.PicStruct=PROGRESSIVE
vpp.QueryIOSurf.request[1].Info.ChromaFormat=4:2:0
vpp.QueryIOSurf.request[1].Type=SYSTEM_MEMORY|FROM_VPPOUT|EXTERNAL_FRAME
vpp.QueryIOSurf.request[1].NumFrameMin=7
vpp.QueryIOSurf.request[1].NumFrameSuggested=7
vpp.QueryIOSurf.status=MFX_ERR_NONE
decode.Init.par.AsyncDepth=0
decode.Init.par.mfx.FrameInfo.Crop=(0,0,1920,1080)
decode.Init.par.mfx.FrameInfo.FrameRate=30000/2002
decode.Init.par.mfx.FrameInfo.AspectRatio=1:1
decode.Init.par.mfx.CodecProfile=77
decode.Init.par.mfx.CodecLevel=40
decode.Init.par.IOPattern=IN_SYSTEM_MEMORY|OUT_SYSTEM_MEMORY
vpp.Init.par.AsyncDepth=0
vpp.Init.par.vpp.In.FourCC=NV12
vpp.Init.par.vpp.In.Resolution=(1920,1088)
vpp.Init.par.vpp.In.Crop=(0,0,1920,1080)
vpp.Init.par.vpp.In.FrameRate=30000/2002
vpp.Init.par.vpp.In.AspectRatio=1:1
vpp.Init.par.vpp.In.PicStruct=PROGRESSIVE
vpp.Init.par.vpp.In.ChromaFormat=4:2:0
vpp.Init.par.vpp.Out.FourCC=NV12
vpp.Init.par.vpp.Out.Resolution=(960,544)
vpp.Init.par.vpp.Out.Crop=(0,0,960,540)
vpp.Init.par.vpp.Out.FrameRate=30/1
vpp.Init.par.vpp.Out.AspectRatio=1:1
vpp.Init.par.vpp.Out.PicStruct=PROGRESSIVE
vpp.Init.par.vpp.Out.ChromaFormat=4:2:0
vpp.Init.par.Protected=0
vpp.Init.par.IOPattern=IN_SYSTEM_MEMORY|OUT_SYSTEM_MEMORY
vpp.Init.par.NumExtParam=0
vpp.Init.par.ExtParam=NULL
vpp.Init.status=MFX_ERR_NONE
decode.Close.status=MFX_ERR_NONE
decode.perf.frames=660
decode.perf.async_exec_time=0.000416783 (s/f)
decode.perf.async_exec_rate=0.032225 (s/f)
vpp.Close.status=MFX_ERR_NONE
vpp.perf.frames=330
vpp.perf.async_exec_time=3.12144e-005 (s/f)
vpp.perf.async_exec_rate=0.064291 (s/f)
vpp.perf.frames_sync=660
vpp.perf.exec_time=7754.63 (s/f)
decode.Close.status=MFX_ERR_NOT_INITIALIZED
vpp.Close.status=MFX_ERR_NOT_INITIALIZED
vpp.perf.frames=330
transcode.perf.frames=660
transcode.perf.exec_time=0.0327184 (s/f)
DecodeFrameAsync: EXTERNAL : MFX_ERR_MORE_DATA (660)
DecodeFrameAsync: EXTERNAL : MFX_ERR_NONE (660)
DecodeFrameAsync: EXTERNAL : MFX_WRN_VIDEO_PARAM_CHANGED (26)
RunFrameVPPAsync: EXTERNAL : MFX_ERR_MORE_SURFACE (330)
RunFrameVPPAsync: EXTERNAL : MFX_ERR_NONE (330)
SyncOperation(V): EXTERNAL : MFX_ERR_NONE (660)
DecodeFrameAsync : 1
SyncOperation(D) : 0
RunFrameVPPAsync(IN) : 1
RunFrameVPPAsync(OUT) : 1
SyncOperation(VPP_IN) : 1
SyncOperation(VPP_OUT): 1
