I am trying to use ffmpeg with h264_qsv. I am following this manual:
When installing intel-linux-media-16.4.4-47109.el7.x86_64.rpm though, I get an error:
Loaded plugins: changelog, fastestmirror Examining intel-linux-media-16.4.4-47109.el7.x86_64.rpm: intel-linux-media-16.4.4-47109.el7.x86_64 Marking intel-linux-media-16.4.4-47109.el7.x86_64.rpm to be installed Examining intel-linux-media-devel-16.4.4-47109.el7.x86_64.rpm: intel-linux-media-devel-16.4.4-47109.el7.x86_64 Marking intel-linux-media-devel-16.4.4-47109.el7.x86_64.rpm to be installed Resolving Dependencies --> Running transaction check ---> Package intel-linux-media.x86_64 0:16.4.4-47109.el7 will be installed --> Processing Dependency: libdrm = 2.4.56-47109.el7 for package: intel-linux-media-16.4.4-47109.el7.x86_64 Rockstor-Testing | 2.9 kB 00:00:00 rockstor | 2.9 kB 00:00:00 Loading mirror speeds from cached hostfile * base: centosmirror.netcup.net * epel: mirror.nl.leaseweb.net * extras: centosmirror.netcup.net * updates: centosmirror.netcup.net ---> Package intel-linux-media-devel.x86_64 0:16.4.4-47109.el7 will be installed --> Finished Dependency Resolution Error: Package: intel-linux-media-16.4.4-47109.el7.x86_64 (/intel-linux-media-16.4.4-47109.el7.x86_64) Requires: libdrm = 2.4.56-47109.el7 Installed: libdrm-2.4.60-3.el7.x86_64 (@anaconda/3) libdrm = 2.4.60-3.el7 You could try using --skip-broken to work around the problem You could try running: rpm -Va --nofiles --nodigest
Here I am stuck. I don't know how to install the cherry-picked version of libdrm.
Can anyone help on this?
About my system:
cat /proc/cpuinfo | grep -i intel vendor_id : GenuineIntel model name : Intel(R) Pentium(R) CPU G3220 @ 3.00GHz vendor_id : GenuineIntel model name : Intel(R) Pentium(R) CPU G3220 @ 3.00GHz [root@homeserver CentOS]# lsmod | grep i915 i915 1212416 2 i2c_algo_bit 16384 1 i915 drm_kms_helper 135168 1 i915 drm 356352 3 i915,drm_kms_helper video 40960 1 i915
Hendrik
Hi Hendrik,
From the release notes for this release:
Intel® Celeron®, Intel® Pentium® and Intel® Atom™ processors are not supported
So, no guarantees that Media SDK will install for this processor. However, if you want to keep trying the install_sdk_UMD_CentOS.sh script and the Getting Started Guide should help with the steps necessary. Part of the install procedure will add a customized libdrm to the system.
