I have fresh new install of centos 7.1 and trying to install intel media server studio essential 2015 r5.
I follow the steps described in getting started guide., but after install_sdk_umd... finishes installing packages from yum repo and starts installing sdk provided rpm files, I am getting error: mesa-dri-drivers >= 8.0.1 is needed by libva-1.3.1-staging.20130628.36242.el7.x86_64.
I installed that package from yum repo and re-started install_sdk_umd... after installation have finished, I started build_kernel_rpm_CentOS.sh finished ok, I installed newly builded kernel to the system and re-started the system.
Checked if the system is running using the provided kernel and if the module is loaded correctly:
[root@localhost ~]# uname -a
Linux localhost.localdomain 3.10.0-229.1.2.36242.MSSr4.el7.centos.x86_64 #1 SMP Tue May 12 21:14:39 GET 2015 x86_64 x86_64 x86_64 GNU/Linux
[root@localhost ~]# lsmod | grep i915
i915 933912 3
i2c_algo_bit 13413 2 i915,mgag200
drm_kms_helper 98226 2 i915,mgag200
drm 311336 5 ttm,i915,drm_kms_helper,mgag200
i2c_core 40325 6 drm,i915,i2c_i801,drm_kms_helper,mgag200,i2c_algo_bit
video 19263 1 i915
but the vainfo gives, me wrong information.
VAProfileNone : VAEntrypointVideoProc
VAProfileNone : <unknown entrypoint>
VAProfileMPEG2Simple : VAEntrypointEncSlice
VAProfileMPEG2Simple : VAEntrypointVLD
VAProfileMPEG2Main : VAEntrypointEncSlice
VAProfileMPEG2Main : VAEntrypointVLD
VAProfileH264Baseline : VAEntrypointEncSlice
VAProfileH264Baseline : <unknown entrypoint>
VAProfileH264Main : VAEntrypointVLD
VAProfileH264Main : VAEntrypointEncSlice
VAProfileH264Main : <unknown entrypoint>
VAProfileH264High : VAEntrypointVLD
VAProfileH264High : VAEntrypointEncSlice
VAProfileH264High : <unknown entrypoint>
VAProfileVC1Simple : VAEntrypointVLD
VAProfileVC1Main : VAEntrypointVLD
VAProfileVC1Advanced : VAEntrypointVLD
VAProfileJPEGBaseline : VAEntrypointVLD
VAProfileJPEGBaseline : VAEntrypointEncPicture
VAProfileH264ConstrainedBaseline: VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice
VAProfileH264ConstrainedBaseline: <unknown entrypoint>
VAProfileVP8Version0_3 : VAEntrypointEncSlice
VAProfileVP8Version0_3 : VAEntrypointVLD
VAProfileVP8Version0_3 : <unknown entrypoint>
anyone can tell me why I am getting <unknown entrypoint> in vainfo output?
Hi Zurab,
This is not expected, we are looking into this issue. Can you please confirm if the problem exist after re-installing all of the RPMs with --force + reboot as mentioned in getting started guide?
Also, try to run sample application and check if they run smoothly. Let us know the result.
Surbhi
HI Zurab,
After discussing this issue with experts, these <unknown encrypt> msgs is not an installation issue. You shouldn't see any problem with any codec. These msgs means that media sdk are limitations of media stack/vainfo tool & is not exposing to those entrpoints
Hope that answer your question.
Surbhi
Hi Zurab,
I am wondering whether you are able to install CentOS 7.1 and the OpenCL runtime through Intel media server studio essential 2015 r5 successfully. If yes, could I ask you for suggestions to resolve the installation issue I am facing?
I am not able to install the newly built kernel. In particular, I am following these steps (most of the steps are based on the official instructions from Intel).
- Installed CenOS 7.1 using an ISO from: http://isoredirect.centos.org/centos/7/isos/x86_64/CentOS-7-x86_64-DVD-1503-01.iso . I chose "Development and Creative Workstation" base environment and "development tools" add-on during the OS installation. I think it should be the right version of the OS but, still could you tell me the base kernel-version of the CentOS that you installed?
- Installed packages by running install_sdk_UMD_CentOS.sh : it seems to have installed everything fine.
- Built kernel using build_kernel_rpm_CentOS.sh : it took more than an hour and finished with a message- "+exit 0 /MSS INFO... Please find kernel rpm under ./rpmbuild/RPMS folder." I feel that this step is also fine, but I not 100% sure. Please let me know if this message denotes a successful build or not.
- Installing the kernel: this step seems to be the issue because the OS crashes when I reboot the system the system after this step. Actually, this step finished in less than 1 minute for me with the following message. Could you comment on this?
"[root@ultra4 x86_64]# rpm -Uvh kernel-3.10.*.rpm
Preparing... ################################# [100%]
Updating / installing...
1:kernel-3.10.0-229.1.2.36242.MSSr4################################# [ 50%]
Cleaning up / removing...
2:kernel-3.10.0-229.el7 warning: file /lib/modules/3.10.0-229.el7.x86_64/weak-updates: remove failed: No such file or directory
warning: file /lib/modules/3.10.0-229.el7.x86_64/modules.softdep: remove failed: No such file or directory
warning: file /lib/modules/3.10.0-229.el7.x86_64/modules.devname: remove failed: No such file or directory
################################# [100%]"
Before rebooting when I run uname -r command, I see 3.10.0-229.el7.x86_64 version.
Any help or pointer is greatly appreciated.
Thanks and Regards,
Kapil
