3027 Discussions
Intel Core i5 -6400 centos 7,2 intel mss install problem
John58sk_D_
Hi Everybody
I just bought this cpu for streaming videos by qsv but i cant install mss .. I downloaded CentOS 7,2, modify repos file to download from vault, install mss 2017r2, but after reboot my pc doesnt boot..
what can by wrong ?
thank you
Stav_S_Intel
Hi John,
Can you maybe share the log of failed reboot?
Stav
John58sk_D_
ok, at the begin, sory, my mistake.. Centos seem to be working, but without graphics.. i can see no input signal on the lcd.. by i can ssh to the terminal .. lines from dmesg :
[    1.113064] WARNING: at ../../../../qb/workspace/17023/p4gen/gfx_Development/builds/centos/_rpmbuild_tmp/BUILD/ukmd-16.5.1/drivers/gpu/drm/i915/intel_uncore.c:626 hsw_unclaimed_reg_debug.isra.14+0x70/0x90 [i915]()
[    1.113066] Unclaimed register detected after reading register 0x61114
[    1.113067] Modules linked in: crct10dif_pclmul crct10dif_common crc32c_intel e1000e i915(OE+) ptp serio_raw i2c_algo_bit pps_core drm_ukmd_kms_helper(OE) syscopyarea sysfillrect ahci sysimgblt libahci fb_sys_fops libata drm_ukmd(OE) drm_ukmd_compat(OE) drm(OE) video i2c_hid i2c_core dm_mirror dm_region_hash dm_log dm_mod
[    1.113079] CPU: 2 PID: 321 Comm: kworker/u8:7 Tainted: G           OE  ------------   3.10.0-327.el7.x86_64 #1
[    1.113080] Hardware name: System manufacturer System Product Name/PRIME Z270-K, BIOS 0318 11/22/2016
[    1.113084] Workqueue: events_unbound async_run_entry_fn
[    1.113085]  ffff880226ad3ba8 000000009b1b8361 ffff880226ad3b60 ffffffff816351f1
[    1.113087]  ffff880226ad3b98 ffffffff8107b200 ffff880226af0078 0000000000000000
[    1.113089]  ffff880226af0080 ffff880226af0078 0000000000061114 ffff880226ad3c00
[    1.113091] Call Trace:
[    1.113095]  [<ffffffff816351f1>] dump_stack+0x19/0x1b
[    1.113097]  [<ffffffff8107b200>] warn_slowpath_common+0x70/0xb0
[    1.113099]  [<ffffffff8107b29c>] warn_slowpath_fmt+0x5c/0x80
[    1.113119]  [<ffffffffa0232090>] hsw_unclaimed_reg_debug.isra.14+0x70/0x90 [i915]
[    1.113136]  [<ffffffffa0234f84>] gen9_read32+0x94/0x310 [i915]
[    1.113159]  [<ffffffffa02830ed>] intel_digital_port_connected+0x10d/0x2f0 [i915]
[    1.113180]  [<ffffffffa028ba3e>] intel_hdmi_detect+0x4e/0x130 [i915]
[    1.113184]  [<ffffffffa0151ff0>] drm_helper_probe_single_connector_modes_merge_bits+0x310/0x4d0 [drm_ukmd_kms_helper]
[    1.113188]  [<ffffffffa01521c3>] _ukmd_drm_helper_probe_single_connector_modes+0x13/0x20 [drm_ukmd_kms_helper]
[    1.113191]  [<ffffffffa015cb60>] drm_fb_helper_probe_connector_modes.isra.3+0x50/0x70 [drm_ukmd_kms_helper]
[    1.113195]  [<ffffffffa015e328>] _ukmd_drm_fb_helper_initial_config+0x88/0x3f0 [drm_ukmd_kms_helper]
[    1.113197]  [<ffffffff81013588>] ? __switch_to+0xf8/0x4b0
[    1.113218]  [<ffffffffa026f29b>] intel_fbdev_initial_config+0x1b/0x20 [i915]
[    1.113220]  [<ffffffff810acf49>] async_run_entry_fn+0x39/0x120
[    1.113222]  [<ffffffff8109d5fb>] process_one_work+0x17b/0x470
[    1.113224]  [<ffffffff8109e3cb>] worker_thread+0x11b/0x400
[    1.113226]  [<ffffffff8109e2b0>] ? rescuer_thread+0x400/0x400
[    1.113228]  [<ffffffff810a5aef>] kthread+0xcf/0xe0
[    1.113230]  [<ffffffff810a5a20>] ? kthread_create_on_node+0x140/0x140
[    1.113233]  [<ffffffff81645858>] ret_from_fork+0x58/0x90
[    1.113235]  [<ffffffff810a5a20>] ? kthread_create_on_node+0x140/0x140
[    1.113236] ---[ end trace ed40bc7d69f2c479 ]---
[    1.115966] ata3: SATA link down (SStatus 4 SControl 300)
[    1.115983] ata2: SATA link down (SStatus 4 SControl 300)
[    1.116037] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    1.116358] ata1.00: ATA-8: SPCC Solid State Disk B29, 120703, max UDMA/133
[    1.116360] ata1.00: 62533296 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[    1.116730] ata1.00: configured for UDMA/133
[    1.117007] scsi 0:0:0:0: Direct-Access     ATA      SPCC Solid State 03   PQ: 0 ANSI: 5
[    1.117016] ata5: SATA link down (SStatus 4 SControl 300)
[    1.118076] ata6: SATA link down (SStatus 4 SControl 300)
[    1.119061] ata4: SATA link down (SStatus 4 SControl 300)
[    1.129243] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[    1.129660] acpi device:10: registered as cooling_device4
[    1.129717] input: Video Bus as /devices/LNXSYSTM:00/device:00/PNP0A08:00/LNXVIDEO:00/input/input3
[    1.129884] [drm_ukmd] RC6 disabled, disabling runtime PM support
[    1.129887] [drm_ukmd] Initialized i915 1.6.0 20161215-16.5.1-59511-k686851e for 0000:00:02.0 on minor 0
[    1.289222] ------------[ cut here ]------------
[    1.289252] WARNING: at ../../../../qb/workspace/17023/p4gen/gfx_Development/builds/centos/_rpmbuild_tmp/BUILD/ukmd-16.5.1/drivers/gpu/drm/i915/intel_dp.c:4609 intel_digital_port_connected+0x91/0x2f0 [i915]()
[    1.289253] Missing switch case (4) in g4x_digital_port_connected
[    1.289254] Modules linked in: crct10dif_pclmul crct10dif_common crc32c_intel e1000e i915(OE) ptp serio_raw i2c_algo_bit pps_core drm_ukmd_kms_helper(OE) syscopyarea sysfillrect ahci sysimgblt libahci fb_sys_fops libata drm_ukmd(OE) drm_ukmd_compat(OE) drm(OE) video i2c_hid i2c_core dm_mirror dm_region_hash dm_log dm_mod
[    1.289267] CPU: 2 PID: 321 Comm: kworker/u8:7 Tainted: G        W  OE  ------------   3.10.0-327.el7.x86_64 #1
[    1.289268] Hardware name: System manufacturer System Product Name/PRIME Z270-K, BIOS 0318 11/22/2016
[    1.289271] Workqueue: events_unbound async_run_entry_fn
[    1.289272]  ffff880226ad3c08 000000009b1b8361 ffff880226ad3bc0 ffffffff816351f1
[    1.289274]  ffff880226ad3bf8 ffffffff8107b200 ffff880226af0000 0000000000000002
[    1.289276]  ffff880226992800 000000000000001c ffff8800361330d8 ffff880226ad3c60
[    1.289278] Call Trace:
[    1.289281]  [<ffffffff816351f1>] dump_stack+0x19/0x1b
[    1.289284]  [<ffffffff8107b200>] warn_slowpath_common+0x70/0xb0
[    1.289286]  [<ffffffff8107b29c>] warn_slowpath_fmt+0x5c/0x80
[    1.289308]  [<ffffffffa0283071>] intel_digital_port_connected+0x91/0x2f0 [i915]
[    1.289327]  [<ffffffffa0283658>] intel_dp_detect+0xd8/0x4c0 [i915]
[    1.289332]  [<ffffffffa0151ff0>] drm_helper_probe_single_connector_modes_merge_bits+0x310/0x4d0 [drm_ukmd_kms_helper]
[    1.289335]  [<ffffffffa01521c3>] _ukmd_drm_helper_probe_single_connector_modes+0x13/0x20 [drm_ukmd_kms_helper]
[    1.289339]  [<ffffffffa015cb60>] drm_fb_helper_probe_connector_modes.isra.3+0x50/0x70 [drm_ukmd_kms_helper]
[    1.289342]  [<ffffffffa015e328>] _ukmd_drm_fb_helper_initial_config+0x88/0x3f0 [drm_ukmd_kms_helper]
[    1.289345]  [<ffffffff81013588>] ? __switch_to+0xf8/0x4b0
[    1.289365]  [<ffffffffa026f29b>] intel_fbdev_initial_config+0x1b/0x20 [i915]
[    1.289367]  [<ffffffff810acf49>] async_run_entry_fn+0x39/0x120
[    1.289369]  [<ffffffff8109d5fb>] process_one_work+0x17b/0x470
[    1.289371]  [<ffffffff8109e3cb>] worker_thread+0x11b/0x400
[    1.289372]  [<ffffffff8109e2b0>] ? rescuer_thread+0x400/0x400
[    1.289375]  [<ffffffff810a5aef>] kthread+0xcf/0xe0
[    1.289377]  [<ffffffff810a5a20>] ? kthread_create_on_node+0x140/0x140
[    1.289380]  [<ffffffff81645858>] ret_from_fork+0x58/0x90
[    1.289382]  [<ffffffff810a5a20>] ? kthread_create_on_node+0x140/0x140
[    1.289383] ---[ end trace ed40bc7d69f2c47a ]---
[    1.289386] i915 0000:00:02.0: No connectors reported connected with modes
[    1.289388] [drm_ukmd] Cannot find any crtc or sizes - going 1024x768
[    1.289684] fbcon: inteldrmfb (fb0) is primary device
[    1.454388] tsc: Refined TSC clocksource calibration: 2711.991 MHz
[    1.454390] Switching to clocksource tsc
[    1.465398] ------------[ cut here ]------------
[    1.465424] WARNING: at ../../../../qb/workspace/17023/p4gen/gfx_Development/builds/centos/_rpmbuild_tmp/BUILD/ukmd-16.5.1/drivers/gpu/drm/i915/intel_dp.c:4609 intel_digital_port_connected+0x91/0x2f0 [i915]()
[    1.465424] Missing switch case (4) in g4x_digital_port_connected
[    1.465430] Modules linked in: crct10dif_pclmul crct10dif_common crc32c_intel e1000e i915(OE) ptp serio_raw i2c_algo_bit pps_core drm_ukmd_kms_helper(OE) syscopyarea sysfillrect ahci sysimgblt libahci fb_sys_fops libata drm_ukmd(OE) drm_ukmd_compat(OE) drm(OE) video i2c_hid i2c_core dm_mirror dm_region_hash dm_log dm_mod
[    1.465432] CPU: 2 PID: 181 Comm: kworker/2:2 Tainted: G        W  OE  ------------   3.10.0-327.el7.x86_64 #1
[    1.465432] Hardware name: System manufacturer System Product Name/PRIME Z270-K, BIOS 0318 11/22/2016
[    1.465436] Workqueue: events output_poll_execute [drm_ukmd_kms_helper]
[    1.465437]  ffff88003699bc00 000000007a514023 ffff88003699bbb8 ffffffff816351f1
[    1.465439]  ffff88003699bbf0 ffffffff8107b200 ffff880226af0000 0000000000000002
[    1.465440]  ffff880226992800 000000000000001c ffff8800361330d8 ffff88003699bc58
[    1.465440] Call Trace:
[    1.465443]  [<ffffffff816351f1>] dump_stack+0x19/0x1b
[    1.465444]  [<ffffffff8107b200>] warn_slowpath_common+0x70/0xb0
[    1.465446]  [<ffffffff8107b29c>] warn_slowpath_fmt+0x5c/0x80
[    1.465467]  [<ffffffffa0283071>] intel_digital_port_connected+0x91/0x2f0 [i915]
[    1.465486]  [<ffffffffa0283658>] intel_dp_detect+0xd8/0x4c0 [i915]
[    1.465490]  [<ffffffffa0151ff0>] drm_helper_probe_single_connector_modes_merge_bits+0x310/0x4d0 [drm_ukmd_kms_helper]
[    1.465492]  [<ffffffffa01521c3>] _ukmd_drm_helper_probe_single_connector_modes+0x13/0x20 [drm_ukmd_kms_helper]
[    1.465496]  [<ffffffffa015cb60>] drm_fb_helper_probe_connector_modes.isra.3+0x50/0x70 [drm_ukmd_kms_helper]
[    1.465499]  [<ffffffffa015e136>] _ukmd_drm_fb_helper_hotplug_event+0x76/0x100 [drm_ukmd_kms_helper]
[    1.465518]  [<ffffffffa026f44e>] intel_fbdev_output_poll_changed+0x1e/0x30 [i915]
[    1.465521]  [<ffffffffa0151837>] _ukmd_drm_kms_helper_hotplug_event+0x27/0x30 [drm_ukmd_kms_helper]
[    1.465523]  [<ffffffffa015190d>] output_poll_execute+0x6d/0x1e0 [drm_ukmd_kms_helper]
[    1.465525]  [<ffffffff8109d5fb>] process_one_work+0x17b/0x470
[    1.465526]  [<ffffffff8109e3cb>] worker_thread+0x11b/0x400
[    1.465527]  [<ffffffff8109e2b0>] ? rescuer_thread+0x400/0x400
[    1.465529]  [<ffffffff810a5aef>] kthread+0xcf/0xe0
[    1.465531]  [<ffffffff810a5a20>] ? kthread_create_on_node+0x140/0x140
[    1.465532]  [<ffffffff81645858>] ret_from_fork+0x58/0x90
[    1.465534]  [<ffffffff810a5a20>] ? kthread_create_on_node+0x140/0x140
[    1.465535] ---[ end trace ed40bc7d69f2c47b ]---
[    1.641592] ------------[ cut here ]------------
[    1.641617] WARNING: at ../../../../qb/workspace/17023/p4gen/gfx_Development/builds/centos/_rpmbuild_tmp/BUILD/ukmd-16.5.1/drivers/gpu/drm/i915/intel_dp.c:4609 intel_digital_port_connected+0x91/0x2f0 [i915]()
[    1.641618] Missing switch case (4) in g4x_digital_port_connected
[    1.641624] Modules linked in: crct10dif_pclmul crct10dif_common crc32c_intel e1000e i915(OE) ptp serio_raw i2c_algo_bit pps_core drm_ukmd_kms_helper(OE) syscopyarea sysfillrect ahci sysimgblt libahci fb_sys_fops libata drm_ukmd(OE) drm_ukmd_compat(OE) drm(OE) video i2c_hid i2c_core dm_mirror dm_region_hash dm_log dm_mod
[    1.641625] CPU: 2 PID: 181 Comm: kworker/2:2 Tainted: G        W  OE  ------------   3.10.0-327.el7.x86_64 #1
[    1.641626] Hardware name: System manufacturer System Product Name/PRIME Z270-K, BIOS 0318 11/22/2016
[    1.641629] Workqueue: events output_poll_execute [drm_ukmd_kms_helper]
[    1.641631]  ffff88003699bc00 000000007a514023 ffff88003699bbb8 ffffffff816351f1
[    1.641632]  ffff88003699bbf0 ffffffff8107b200 ffff880226af0000 0000000000000002
[    1.641633]  ffff880226992800 000000000000001c ffff8800361330d8 ffff88003699bc58
[    1.641633] Call Trace:
[    1.641635]  [<ffffffff816351f1>] dump_stack+0x19/0x1b
[    1.641637]  [<ffffffff8107b200>] warn_slowpath_common+0x70/0xb0
[    1.641638]  [<ffffffff8107b29c>] warn_slowpath_fmt+0x5c/0x80
[    1.641660]  [<ffffffffa0283071>] intel_digital_port_connected+0x91/0x2f0 [i915]
[    1.641679]  [<ffffffffa0283658>] intel_dp_detect+0xd8/0x4c0 [i915]
[    1.641682]  [<ffffffffa0151ff0>] drm_helper_probe_single_connector_modes_merge_bits+0x310/0x4d0 [drm_ukmd_kms_helper]
[    1.641685]  [<ffffffffa01521c3>] _ukmd_drm_helper_probe_single_connector_modes+0x13/0x20 [drm_ukmd_kms_helper]
[    1.641688]  [<ffffffffa015cb60>] drm_fb_helper_probe_connector_modes.isra.3+0x50/0x70 [drm_ukmd_kms_helper]
[    1.641691]  [<ffffffffa015e136>] _ukmd_drm_fb_helper_hotplug_event+0x76/0x100 [drm_ukmd_kms_helper]
[    1.641710]  [<ffffffffa026f44e>] intel_fbdev_output_poll_changed+0x1e/0x30 [i915]
[    1.641713]  [<ffffffffa0151837>] _ukmd_drm_kms_helper_hotplug_event+0x27/0x30 [drm_ukmd_kms_helper]
[    1.641715]  [<ffffffffa015190d>] output_poll_execute+0x6d/0x1e0 [drm_ukmd_kms_helper]
[    1.641717]  [<ffffffff8109d5fb>] process_one_work+0x17b/0x470
[    1.641718]  [<ffffffff8109e4cc>] worker_thread+0x21c/0x400
[    1.641719]  [<ffffffff8109e2b0>] ? rescuer_thread+0x400/0x400
[    1.641721]  [<ffffffff810a5aef>] kthread+0xcf/0xe0
[    1.641723]  [<ffffffff810a5a20>] ? kthread_create_on_node+0x140/0x140
[    1.641724]  [<ffffffff81645858>] ret_from_fork+0x58/0x90
[    1.641726]  [<ffffffff810a5a20>] ? kthread_create_on_node+0x140/0x140
[    1.641727] ---[ end trace ed40bc7d69f2c47c ]---
[    1.641804] Console: switching to colour frame buffer device 128x48
[    1.643108] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[    1.647863] sd 0:0:0:0: [sda] 62533296 512-byte logical blocks: (32.0 GB/29.8 GiB)
[    1.647887] sd 0:0:0:0: [sda] Write Protect is off
[    1.647889] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.647896] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.649067]  sda: sda1 sda2
[    1.649879] sd 0:0:0:0: [sda] Attached SCSI disk
[    1.819794] ------------[ cut here ]------------
[    1.819816] WARNING: at ../../../../qb/workspace/17023/p4gen/gfx_Development/builds/centos/_rpmbuild_tmp/BUILD/ukmd-16.5.1/drivers/gpu/drm/i915/intel_dp.c:4609 intel_digital_port_connected+0x91/0x2f0 [i915]()
[    1.819817] Missing switch case (4) in g4x_digital_port_connected
[    1.819826] Modules linked in: sd_mod crc_t10dif crct10dif_generic crct10dif_pclmul crct10dif_common crc32c_intel e1000e i915(OE) ptp serio_raw i2c_algo_bit pps_core drm_ukmd_kms_helper(OE) syscopyarea sysfillrect ahci sysimgblt libahci fb_sys_fops libata drm_ukmd(OE) drm_ukmd_compat(OE) drm(OE) video i2c_hid i2c_core dm_mirror dm_region_hash dm_log dm_mod
[    1.819827] CPU: 1 PID: 282 Comm: plymouthd Tainted: G        W  OE  ------------   3.10.0-327.el7.x86_64 #1
[    1.819828] Hardware name: System manufacturer System Product Name/PRIME Z270-K, BIOS 0318 11/22/2016
[    1.819830]  ffff880036853bb0 0000000085f48a36 ffff880036853b68 ffffffff816351f1
[    1.819831]  ffff880036853ba0 ffffffff8107b200 ffff880226af0000 0000000000000002
[    1.819832]  ffff880226992800 000000000000001c ffff8800361330d8 ffff880036853c08
[    1.819832] Call Trace:
[    1.819836]  [<ffffffff816351f1>] dump_stack+0x19/0x1b
[    1.819838]  [<ffffffff8107b200>] warn_slowpath_common+0x70/0xb0
[    1.819839]  [<ffffffff8107b29c>] warn_slowpath_fmt+0x5c/0x80
[    1.819854]  [<ffffffffa0283071>] intel_digital_port_connected+0x91/0x2f0 [i915]
[    1.819867]  [<ffffffffa0283658>] intel_dp_detect+0xd8/0x4c0 [i915]
[    1.819871]  [<ffffffffa0151ff0>] drm_helper_probe_single_connector_modes_merge_bits+0x310/0x4d0 [drm_ukmd_kms_helper]
[    1.819880]  [<ffffffffa01014be>] ? _object_find+0x6e/0xb0 [drm_ukmd]
[    1.819883]  [<ffffffffa01521c3>] _ukmd_drm_helper_probe_single_connector_modes+0x13/0x20 [drm_ukmd_kms_helper]
[    1.819891]  [<ffffffffa01070d4>] drm_mode_getconnector+0x374/0x3f0 [drm_ukmd]
[    1.819896]  [<ffffffffa00f8d50>] _ukmd_drm_ioctl+0x260/0x510 [drm_ukmd]
[    1.819903]  [<ffffffffa0106d60>] ? drm_mode_getcrtc+0x150/0x150 [drm_ukmd]
[    1.819905]  [<ffffffff811f1ef5>] do_vfs_ioctl+0x2e5/0x4c0
[    1.819907]  [<ffffffff8128bc6e>] ? file_has_perm+0xae/0xc0
[    1.819909]  [<ffffffff811f2171>] SyS_ioctl+0xa1/0xc0
[    1.819911]  [<ffffffff81645909>] system_call_fastpath+0x16/0x1b
[    1.819912] ---[ end trace ed40bc7d69f2c47d ]---
[    2.002078] SGI XFS with ACLs, security attributes, no debug enabled
[    2.003433] XFS (dm-0): Mounting V4 Filesystem
[    2.029018] ------------[ cut here ]------------
[    2.029041] WARNING: at ../../../../qb/workspace/17023/p4gen/gfx_Development/builds/centos/_rpmbuild_tmp/BUILD/ukmd-16.5.1/drivers/gpu/drm/i915/intel_dp.c:4609 intel_digital_port_connected+0x91/0x2f0 [i915]()
[    2.029042] Missing switch case (4) in g4x_digital_port_connected
[    2.029043] Modules linked in: xfs libcrc32c sd_mod crc_t10dif crct10dif_generic crct10dif_pclmul crct10dif_common crc32c_intel e1000e i915(OE) ptp serio_raw i2c_algo_bit pps_core drm_ukmd_kms_helper(OE) syscopyarea sysfillrect ahci sysimgblt libahci fb_sys_fops libata drm_ukmd(OE) drm_ukmd_compat(OE) drm(OE) video i2c_hid i2c_core dm_mirror dm_region_hash dm_log dm_mod
[    2.029057] CPU: 1 PID: 282 Comm: plymouthd Tainted: G        W  OE  ------------   3.10.0-327.el7.x86_64 #1
[    2.029058] Hardware name: System manufacturer System Product Name/PRIME Z270-K, BIOS 0318 11/22/2016
[    2.029059]  ffff880036853bb0 0000000085f48a36 ffff880036853b68 ffffffff816351f1
[    2.029061]  ffff880036853ba0 ffffffff8107b200 ffff880226af0000 0000000000000002
[    2.029063]  ffff880226992800 000000000000001c ffff8800361330d8 ffff880036853c08
[    2.029065] Call Trace:
[    2.029069]  [<ffffffff816351f1>] dump_stack+0x19/0x1b
[    2.029072]  [<ffffffff8107b200>] warn_slowpath_common+0x70/0xb0
[    2.029073]  [<ffffffff8107b29c>] warn_slowpath_fmt+0x5c/0x80
[    2.029090]  [<ffffffffa0283071>] intel_digital_port_connected+0x91/0x2f0 [i915]
[    2.029104]  [<ffffffffa0283658>] intel_dp_detect+0xd8/0x4c0 [i915]
[    2.029109]  [<ffffffffa0151ff0>] drm_helper_probe_single_connector_modes_merge_bits+0x310/0x4d0 [drm_ukmd_kms_helper]
[    2.029118]  [<ffffffffa01014be>] ? _object_find+0x6e/0xb0 [drm_ukmd]
[    2.029122]  [<ffffffffa01521c3>] _ukmd_drm_helper_probe_single_connector_modes+0x13/0x20 [drm_ukmd_kms_helper]
[    2.029130]  [<ffffffffa01070d4>] drm_mode_getconnector+0x374/0x3f0 [drm_ukmd]
[    2.029132]  [<ffffffff811ebd55>] ? do_last+0x635/0x1270
[    2.029138]  [<ffffffffa00f8d50>] _ukmd_drm_ioctl+0x260/0x510 [drm_ukmd]
[    2.029145]  [<ffffffffa0106d60>] ? drm_mode_getcrtc+0x150/0x150 [drm_ukmd]
[    2.029148]  [<ffffffff811f1ef5>] do_vfs_ioctl+0x2e5/0x4c0
[    2.029150]  [<ffffffff8128bc6e>] ? file_has_perm+0xae/0xc0
[    2.029152]  [<ffffffff811f2171>] SyS_ioctl+0xa1/0xc0
[    2.029155]  [<ffffffff81645909>] system_call_fastpath+0x16/0x1b
[    2.029156] ---[ end trace ed40bc7d69f2c47e ]---
[    2.035684] XFS (dm-0): Ending clean mount
[    2.253274] systemd-journald[117]: Received SIGTERM from PID 1 (systemd).
[    2.328062] type=1404 audit(1501068704.223:2): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
[    2.425702] SELinux: 2048 avtab hash slots, 105321 rules.
[    2.437725] SELinux: 2048 avtab hash slots, 105321 rules.
[    2.457774] SELinux:  8 users, 105 roles, 4952 types, 302 bools, 1 sens, 1024 cats
[    2.457777] SELinux:  83 classes, 105321 rules
[    2.461074] SELinux:  Completing initialization.
[    2.461076] SELinux:  Setting up existing superblocks.
[    2.461081] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
[    2.461083] SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts
[    2.461089] SELinux: initialized (dev bdev, type bdev), uses genfs_contexts
[    2.461093] SELinux: initialized (dev proc, type proc), uses genfs_contexts
[    2.461128] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[    2.461147] SELinux: initialized (dev devtmpfs, type devtmpfs), uses transition SIDs
[    2.461494] SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
[    2.461497] SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts
[    2.462152] SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
[    2.462154] SELinux: initialized (dev anon_inodefs, type anon_inodefs), uses genfs_contexts
[    2.462156] SELinux: initialized (dev aio, type aio), not configured for labeling
[    2.462158] SELinux: initialized (dev devpts, type devpts), uses transition SIDs
[    2.462165] SELinux: initialized (dev hugetlbfs, type hugetlbfs), uses transition SIDs
[    2.462169] SELinux: initialized (dev hugetlbfs, type hugetlbfs), uses transition SIDs
[    2.462172] SELinux: initialized (dev mqueue, type mqueue), uses transition SIDs
[    2.462176] SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts
[    2.462183] SELinux: initialized (dev securityfs, type securityfs), uses genfs_contexts
[    2.462186] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
[    2.462443] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[    2.462447] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[    2.462497] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[    2.462515] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[    2.462520] SELinux: initialized (dev pstore, type pstore), uses genfs_contexts
[    2.462521] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[    2.462523] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[    2.462526] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[    2.462528] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[    2.462532] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[    2.462534] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[    2.462536] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[    2.462540] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[    2.462544] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[    2.462547] SELinux: initialized (dev configfs, type configfs), uses genfs_contexts
[    2.462549] SELinux: initialized (dev drm, type drm), not configured for labeling
[    2.462553] SELinux: initialized (dev dm-0, type xfs), uses xattr
[    2.466554] type=1403 audit(1501068704.361:3): policy loaded auid=4294967295 ses=4294967295
[    2.471103] systemd[1]: Successfully loaded SELinux policy in 144.274ms.
[    2.502307] ip_tables: (C) 2000-2006 Netfilter Core Team
[    2.502366] systemd[1]: Inserted module 'ip_tables'
[    2.518312] systemd[1]: Relabelled /dev and /run in 12.458ms.
[    2.679567] SELinux: initialized (dev autofs, type autofs), uses genfs_contexts
[    2.709618] SELinux: initialized (dev hugetlbfs, type hugetlbfs), uses transition SIDs
[    2.712015] [drm_ukmd] RC6 off
[    2.714036] [drm_ukmd] The Ring/GT multiplier is 2
[    2.738810] systemd-journald[504]: Received request to flush runtime journal from PID 1
[    2.834669] wmi: Mapper loaded
[    2.862930] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    2.865054] input: PC Speaker as /devices/platform/pcspkr/input/input4
[    2.879100] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    2.900696] asus_wmi: ASUS WMI generic driver loaded
[    2.903141] asus_wmi: Initialization: 0x0
[    2.903155] asus_wmi: BIOS WMI version: 0.9
[    2.903202] asus_wmi: SFUN value: 0x0
[    2.903381] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input5
[    2.903824] asus_wmi: Backlight controlled by ACPI video driver
[    2.957756] AES CTR mode by8 optimization enabled
[    2.959725] snd_hda_intel 0000:00:1f.3: irq 131 for MSI/MSI-X
[    2.963212] alg: No test for __gcm-aes-aesni (__driver-gcm-aes-aesni)
[    2.965389] Adding 3129340k swap on /dev/mapper/centos-swap.  Priority:-1 extents:1 across:3129340k SSFS
[    2.972998] alg: No test for crc32 (crc32-pclmul)
[    2.976778] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC887-VD: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[    2.976779] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    2.976780] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[    2.976780] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    2.976781] snd_hda_codec_realtek hdaudioC0D0:    dig-out=0x11/0x0
[    2.976781] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    2.976782] snd_hda_codec_realtek hdaudioC0D0:      Front Mic=0x19
[    2.976783] snd_hda_codec_realtek hdaudioC0D0:      Rear Mic=0x18
[    2.976784] snd_hda_codec_realtek hdaudioC0D0:      Line=0x1a
[    2.990334] intel_rapl: Found RAPL domain package
[    2.990335] intel_rapl: Found RAPL domain core
[    2.990335] intel_rapl: Found RAPL domain uncore
[    2.990336] intel_rapl: Found RAPL domain dram
[    3.033264] ------------[ cut here ]------------
[    3.033324] WARNING: at ../../../../qb/workspace/17023/p4gen/gfx_Development/builds/centos/_rpmbuild_tmp/BUILD/ukmd-16.5.1/drivers/gpu/drm/i915/intel_dp.c:4609 intel_digital_port_connected+0x91/0x2f0 [i915]()
[    3.033326] Missing switch case (4) in g4x_digital_port_connected
[    3.033367] Modules linked in: intel_powerclamp coretemp intel_rapl kvm_intel kvm snd_hda_codec_realtek(+) snd_hda_codec_generic crc32_pclmul ghash_clmulni_intel snd_hda_intel aesni_intel snd_hda_codec snd_hda_core lrw snd_hwdep gf128mul snd_seq glue_helper snd_seq_device ablk_helper cryptd snd_pcm eeepc_wmi asus_wmi sparse_keymap rfkill mxm_wmi sg snd_timer snd pcspkr soundcore shpchp wmi acpi_pad acpi_cpufreq ip_tables xfs libcrc32c sd_mod crc_t10dif crct10dif_generic crct10dif_pclmul crct10dif_common crc32c_intel e1000e i915(OE) ptp serio_raw i2c_algo_bit pps_core drm_ukmd_kms_helper(OE) syscopyarea sysfillrect ahci sysimgblt libahci fb_sys_fops libata drm_ukmd(OE) drm_ukmd_compat(OE) drm(OE) video i2c_hid i2c_core dm_mirror dm_region_hash dm_log dm_mod
[    3.033371] CPU: 2 PID: 282 Comm: plymouthd Tainted: G        W  OE  ------------   3.10.0-327.el7.x86_64 #1
[    3.033373] Hardware name: System manufacturer System Product Name/PRIME Z270-K, BIOS 0318 11/22/2016
[    3.033378]  ffff880036853bb0 0000000085f48a36 ffff880036853b68 ffffffff816351f1
[    3.033381]  ffff880036853ba0 ffffffff8107b200 ffff880226af0000 0000000000000002
[    3.033384]  ffff880226992800 000000000000001c ffff8800361330d8 ffff880036853c08
[    3.033385] Call Trace:
[    3.033395]  [<ffffffff816351f1>] dump_stack+0x19/0x1b
[    3.033401]  [<ffffffff8107b200>] warn_slowpath_common+0x70/0xb0
[    3.033405]  [<ffffffff8107b29c>] warn_slowpath_fmt+0x5c/0x80
[    3.033455]  [<ffffffffa0283071>] intel_digital_port_connected+0x91/0x2f0 [i915]
[    3.033496]  [<ffffffffa0283658>] intel_dp_detect+0xd8/0x4c0 [i915]
[    3.033509]  [<ffffffffa0151ff0>] drm_helper_probe_single_connector_modes_merge_bits+0x310/0x4d0 [drm_ukmd_kms_helper]
[    3.033534]  [<ffffffffa01014be>] ? _object_find+0x6e/0xb0 [drm_ukmd]
[    3.033548]  [<ffffffffa01521c3>] _ukmd_drm_helper_probe_single_connector_modes+0x13/0x20 [drm_ukmd_kms_helper]
[    3.033572]  [<ffffffffa01070d4>] drm_mode_getconnector+0x374/0x3f0 [drm_ukmd]
[    3.033593]  [<ffffffffa00f8d50>] _ukmd_drm_ioctl+0x260/0x510 [drm_ukmd]
[    3.033615]  [<ffffffffa0106d60>] ? drm_mode_getcrtc+0x150/0x150 [drm_ukmd]
[    3.033621]  [<ffffffff811f1ef5>] do_vfs_ioctl+0x2e5/0x4c0
[    3.033627]  [<ffffffff8128bc6e>] ? file_has_perm+0xae/0xc0
[    3.033631]  [<ffffffff811f2171>] SyS_ioctl+0xa1/0xc0
[    3.033637]  [<ffffffff81645909>] system_call_fastpath+0x16/0x1b
[    3.033639] ---[ end trace ed40bc7d69f2c47f ]---
[    3.058960] XFS (sda1): Mounting V4 Filesystem
[    3.672398] XFS (sda1): Ending clean mount
[    3.672412] SELinux: initialized (dev sda1, type xfs), uses xattr
[    3.736104] type=1305 audit(1501068705.629:4): audit_pid=654 old=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:auditd_t:s0 res=1
[    3.853446] IPv6: ADDRCONF(NETDEV_UP): enp0s31f6: link is not ready
[    3.948239] e1000e 0000:00:1f.6: irq 129 for MSI/MSI-X
[    4.026509] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input6
[    4.026627] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input7
[    4.026706] input: HDA Intel Line as /devices/pci0000:00/0000:00:1f.3/sound/card0/input8
[    4.027096] input: HDA Intel Line Out as /devices/pci0000:00/0000:00:1f.3/sound/card0/input9
[    4.027304] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input10
[    4.027531] input: HDA Intel HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input11
[    4.049284] e1000e 0000:00:1f.6: irq 129 for MSI/MSI-X
[    4.049409] IPv6: ADDRCONF(NETDEV_UP): enp0s31f6: link is not ready
[    5.579789] e1000e: enp0s31f6 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[    5.579799] e1000e 0000:00:1f.6 enp0s31f6: 10/100 speed: disabling TSO
[    5.579874] IPv6: ADDRCONF(NETDEV_CHANGE): enp0s31f6: link becomes ready
[ 1762.476852] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[ 5365.622113] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[ 8957.937665] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
